Looking at building a mast for it possibly before spring and then have the plans finalized for beams and outriggers by spring with all supplies ordered to start as soon as epoxy curing temperatures start.
My rough idea is a 10-12ish ft total beam and roughly 200lbs flotation from each of the 12ft long outriggers made from 1 sheet of 4mm apiece.
Not sure if the box beams will be plywood or 1x4s, the advantage of the 1x4s is I could get them in 12ft sticks and not need any splicing..... will have to figure it out
Still doing a little rough research on the mast but I like the basics behind this hollow one,
https://www.idniyra.org/old/articles/mast_made_easy.htm
I have never touched a sail, or even looked at one up close..... so will wait till it is here and I can touch and look at it to make sure my head is fully wrapped around the luff track and dimensions of the boltrope etc....
I think I may modify the idea I linked a little in making it slightly wider at the trailing edge and using pex tubing embedded a little deeper, wrapping the whole thing in glass then cutting the groove on my table saw.
I talked to the park historian here and even though we live on a huge 60 mile long lake he doesn't have any record of sailing taking place, he has pictures of some old Bristol Bay double enders modified with engines, but none with masts or sails (showing in the picture). He assumes that there may have been some small primitive sailing on canoes but again no actual records showing it. All kind of interesting considering how big a body of water we live on.
