Sort of launch today - the outboard had some issues at mid- to full throttle so a couple of short loops at about 1/2 speed then back to shore was it.
[youtube]https://youtu.be/6mzy_GJCyAI[/youtube]
SOBX Solo Flats Skiff SK14
- BrianC
Re: SOBX Solo Flats Skiff SK14
Congratulations! That's a beautiful skiff!
Sweet!
BrianC, Congratulations on the launch!!! Looks like you did great even with all of the boat traffic!! Sorry about the motor but I am sure you will get it right for the next launch!!! Jeff
- BB Sig
Looks good! You seemed pretty steady after you got on your feet.
Post another video when you get the motor worked out...
- New Poster
What are those black blocks (I assume some sort of weight) holding the internal frame components in place?
Thanks!
Thanks!
- BrianC
Those are weights salvaged from an old weight lifting machine. The plastic covering keeps them from scratching or gouging the wood surface and they interlock so stacking them is easy.larryasmin@gmail.com wrote: ↑Tue Apr 30, 2019 1:35 pm What are those black blocks (I assume some sort of weight) holding the internal frame components in place?
