We are beginning a new adventure, building our fisrt small boat and would like to share with you our progress....
1- The choice of the project: The Cat Boat C12:
2 - From the road to the sea
In order to fulfil this dream, we have sold an old VW TL 1970 and invest the amount of money we've got in this project. This is for this reason that the name of this boat will be TL70.
3- Our Shipyard
4 - Fisrt day of work: May 16th
We have designed on the plywood the bottom one side of the bottom panel, seat tops and frames. For the bottom panel, we add to adapt the piece division according to brazilian plywood dimension: 220 x 160 mm. We intend to project this form after cutting it on another plywood in order to get the second piece of the bottom side.
This is it for today, we will try to keep you inform to share the full process
