After reading the plans every night for the last two weeks, I am ready to start. I went and bought a load of the Meranti 6566 today. Tomorrow afternoon I will start laying the parts and maybe Saturday actually do some cutting.
When I get to the actual build process I will start posting some pictures.
Now for the first question of millions to come.
When I am gluing up the transom along with the clamping board, can I use a series of bolts put through all of the pieces to help keep them aligned?
Dave
Dave's OP21 Project
That sounds pretty elegant. I just gooped some butter on both sides, set one on top of the other, and used the SHS clamp (some heavy stuff). But there are many paths. BTW, I'll be in Santa Fe this summer for a few days, where you be? The OP 21 is a fine looking thing. . . does your wife know how good looking she is?
Don't do like old Dougster
Layed out the transom today that went real well without any problems. I started to lay out station F and I ran into a real big problem. When I was reading the palns from sheet D250/4 I realized there was something I could not figure out.
The length of my plywood 2442 mm and the plans call for the outside of station F to be at 1233 from the centerline . On the nesting plans it does show staion F to be larger than the sheet of plywood. Is there an error on the plans or I am missing something simple?
Dave
About the FL12. I am trying to my FL12 back from my ex. It is still unfinished and just sitting there
Shaping up...
Hardwood Dowels are very handy. You don't need many at all. Just use them in key positions. Three in the transom (two at the upper ends, one at the bottom where you will drill out the drain plug). The same two at the top can also hold the clamping board if it is full length, else maybe two more to hold that. Completely stops the sliding around, and you don't need to go back and fill screw holes later. 1/4 inch dowels do the job, as they don't really hold anything together, but only keep it aligned while curing. Keeping things aligned is a good thing.
Dowels make multiple layer laminates easy in one bonding session... after lots of crazed mixing...
Build well!
Build well!
Users browsing this forum: Yandex [Bot] and 5 guests
