I can finally post the address to my blog, very amateurish, sorry, but at least there are some pics. The boat fills my shop.
http://cruisinghouseboat.blogspot.com/
My GT23/22 Blog
Now that the hull is flipped I have been at work glassing in the stringers. I was puzzled at first how to space them and hold them upright but found a solution. I first put all of the frames and stringers into the hull. Second I spot welded the stringers in place with 2' long shallow fillets between every other frame, putting the fillet on each side of the frame, let it cure overnight and removed all frames and the stringers stand tall and solid awaiting full fillets and then two layers of tape on each side. When I have finished that (only time today to do one stringer) I will reinstall the frames and fillet and tape them in. A bit tedious but more fun than fairing. I cant wait to put the sole down. I have decided to skip the foam. Twenty eight or so completely sealed water tight compartments under the sole work for me. I might consider foam up under the gunnels for upright floatation but cant imagine holing enough of those compartments to make the boat sink....., I can only go hull speed after all.
Daddy
Daddy
Glassing in the frames, stringers finished. Trying the "glassing off the boat" method of wetting out the glass. Not sure if I like it or not but it is definitely faster. Actually I am glassing in the boat, have set up a saw horse with a tray lined with heavy plastic sheeting. That part works well, the problem is that the glass "grabs" and is not as easy to slide around as when the area is wetted out first. I need to be patient and get the hang if it.
Daddy
Daddy
Users browsing this forum: No registered users and 23 guests
