This is my first boat build everything went together fairly easily, only thing took time was the fairing. i decided to wrap the whole outside of the hull with 9oz cloth. I Had a question in regards of the skeg. Is the skeg only nessesary if you row the boat? Do you really need it if your boat will be powered by an outboard? I just aquired a honda 2hp outboard for the boat and don't plan on rowing it unless in a emergency. Thanks for your help. I did graphite the bottom already primed and put on the first coat of paint. Also one last question any ideas on making a transom plate or something similar to protect the transom from wear where the outboard clamps on? Thanks. here are some pictures of the build.
fl12 build
- littlesandy
I decided to go with gk's idea on the transom pads. I cut them to size and coated it with epoxy layed plastic over it and rolled out the bubbles <poor mans peel ply>
I also got my 2nd coat on. Im using interlux brightside as my paint. I know i should've gone with a 2 part paint but our local boat dealer didn't have the primer or reducers for the 2 part interlux paints and my only other option was awlgrip but the price was a little to steep. I wet sanded it and polished it out and im pleased with the results.
Also installed some lift handles to make it easier to carry the boat. And got the hatch installed.
Just gotta wait till the epoxy cures then 5200 it to the transom. Overall this boat was a great learning experience.
