READY TO GRIND IT OUT - LITERALLY
AFTER A COUPLE OF EFFORTS IN 90+ DEGREE AUGUST HEAT WE GOT THE NASTY JOB FINISHED!
THERE WERE 3 LAYERS OF PAINT AND GEL COAT ON THE INTERIOR. GOT THE WORST OF IT OFF AND SMOOTHED DOWN.
AFTER A HOT, HUMID AND BUSY AUGUST PLUS SWEATING OUT STORMS, MY ORDER OF MATERIALS HAS FINALLY ARRIVED AND THE WEATHERS COOLING DOWN, NOW IS THE PERFECT TIME TO "GIT 'ER DONE"!
CUT OUT AND FIT THE TRANSOM AND 3 MAIN STRINGERS YESTERDAY PM SEPTEMBER 16TH.
TRANSOM IS INSTALLED!
I TAPED OVER ALL THE HOLES AND THEY FILLED IN NICELY.
IT WENT BETTER THAN I THOUGHT, I FIRST COATED BOTH BOAT AND INNER TRANSOM SIDE WITH EPOXY, THAN APPLIED THICKENED EPOXY WITH A TILE MUD SPREADER TO FILL IN. LOTS OOZED OUT. FILLETED WITH THICKER MATERIAL USING THE CAKE DECORATING TECHNIQUE. WORKED OUT PRETTY WELL.
OCTOBER 1ST AND THE GOOD WEATHERS HOLDING. BEEN ABLE TO WORK ON THE BOAT EVERY DAY THIS LAST WEEK.
THE TRANSOM TABBED AND COVERED WITH 2 LAYERS OF 16OZ BIAX.
CUT AND GLUED IN THE 3 STRINGERS, THEN CLEATED THEM WITH 3/4 X 3/4. NOT SHOWN ARE 2 SMALL CROSS FRAMES THAT WILL BE LOCATED BELOW DECKS WHERE THE FRONT SEAT BACK AND THE REAR BULKHEAD MEET THE FLOOR.
TORE OUT THE OLD DASHBOARD THAT SOMEONE ELSE REPLACED IN THE PAST, THEY HAD GLUED AND TABBED IN WITH POLYESTER. I WAS ABLE TO EASILY REMOVE IT. THIS SURE SHOWED ME HOW POORLY ANY POLYESTER/POLYESTER REPAIR WOULD COME OUT.
NOW ABOUT READY TO INSTALL THE FRONT HALF OF THE SOLE. I LEFT ABOUT A 2 INCH LIP AROUND THE PERIPHERY OF THE BOAT TO ACT AS A GLUE FLANGE AND HELP STIFFEN THE COMPLETED BOTTOM. CHAMFERED THE SOLE EDGES SO AS TO MAKE A SMOOTH TRANSITION FOR THE TABBING.
AS THE HULL SHAPE WAS DISTORTED BY THE REMOVAL OF THE AFT DECK I REINSTALLED IT. BOY THAT SURE HELPED SQUARE THINGS AWAY. I AM REMOVING THE POP RIVETED FLANGE WHERE THE DECK AND HULL MEET AND FAIRING THE 2 INTO ONE SMOOTH TRANSITION. THE INSIDE IS TABBED TOGETHER, I WILL ALSO RUN A SMALL STRIP DOWN THE EXTERIOR TO BE SURE IT WILL NOT SEPERATE. I PUT AN 18" BLOCK AT THE JOINT WHERE THE REAR DECK CAME OFF AND TABBED THE HECK OUT OF IT AS WELL. GENEROUS AMOUNTS OF THICKENED RESIN BEDDED IT ON TO THE TRANSOM AT THE TOP.
GOT THE SOLE IN. THE EDGES WERE A BIT OFF RELATIVE TO THE REMAINING FLANGE BUT MY ELECTRIC PLANE AND DISC GRINDER SOON SMOOTHED THE TRANSITION. A BIT OF FAIRING WITH THICKENED EPOXY AND THE TABBING WENT EXCEPTIONALLY WELL.
JUST PUT BUTT BLOCKS EXTENDING 2 INCHES AT THE JOINT, TIGHTENED THEM UP WITH TEMPORARY SCREWS. HAD TO SCREW A COUPLE SPOTS ON THE SOLE AS WELL TO ENSURE COMPLETE CONTACT. ALL SCREWS WERE REMOVED AFTER RESIN SET.
THE PORT SIDE CENTERDECK AREA OF THIS OLD GIRL EVIDENTLY HAD AN ARGUMENT WITH THE DOCK AT SOMETIME PAST, OR PERHAPS WAS WHACKED BY SOMETHING IN THE HURRICANE. IN ANY CASE THE TAB ALONG THE GUNWALE WAS LOOSE AND THE DECK ITSELF WAS CRACKED SO I GROUND IT CLEAN, RETABBED AND ADDED A LAYER BENEATH THE CRACK IN THE DECK. THEN FIGURED THE INNER CENTER DECK AND SEAT SUPPORTS.
FITTING THE BULKHEADS. ALL THIS AREA AND THE SOLE DONE WITH 9MM MERANTI.
MORE TABBING - -
SAW WHERE ANOTHER BUILDER DID A NEAT TRANSOM DRAIN BY CUTTING A LARGER HOLE, PLUGGING IT WITH EPOXY AND DRILLING THE SMALLER HOLE IN THE CENTER SO AS TO ELIMINATE ANY CHANCE OF WATER PENETRATION. GREAT IDEA, HERE'S HOW MINE CAME OUT. I PUT A LITTLE CHOPPED GLASS IN THE MIX FOR EXTRA STRENGTH.
WITH RAIN IN THE FORECAST WE GOT THE SOLE SEALED UP, GOOD THING AS THE RAINS CAME TODAY THE 7TH.
NOW IT'S NOVEMBER 8TH, WE HAVE MADE SOME PROGRESS ON THE BOAT, WEATHER IS REALLY NICE NOW ALTHOUGH GETTING CHILLIER AT NIGHT. HAD TO MAKE A 3000 MILE TRIP TO WASHINGTON STATE TO PICK UP MY OUTBOARD COLLECTION FROM STORAGE.
I HAVE DILIGENTLY LOOKED AROUND ON THE BBS AND CAN'T FIND ANY SIMPLE "POST" ICON SO I KEEP ADDING TO THE SAME PAGE - ANYONE CARE TO COMMENT? IT MUST BE SO OBVIOUS BUT BEATS ME!
INSTALLED A REAR SEAT BACK, THIS WILL ALSO ACT AS THE FORWARD BULKHEAD FOR THE MOTORWELL
FRONT SEAT SUPPORT AND SEAT BACKS TAKING SHAPE
MOTORWELL INSTALLED. IN ORDER TO SAVE CUTTING A NEW SHEET OF WOOD I WAS ABLE TO SCARF 2 SCRAPS TO CREATE THE WELL FLOOR.
THE 2 REAR SEAT SUPPORTS ARE CANTED AS THEY ALSO FORM THE SIDES OF THE MOTORWELL. THEY WILL BE CLEATED TO ADD STIFFNESS AND SUPPORT THE CENTER OF THE SEAT. AN OMC "DURA TANK" JUST NEATLY SLIDES INTO THE SPACE ON EACH SIDE OF THESE SUPPORTS.
THIS BOAT HULL AND DECK WAS ORIGINALLY FLANGED AND POP RIVETED TOGETHER. THEN THE INSIDE WAS TABBED. THERE WAS SIGNIFICANT DAMAGE TO THIS FLANGE, FILLED WITH SILICONE, ETC SO I HAVE CUT THE ENTIRE THING OFF AND WILL FAIR AND TAB THE OUTSIDE TOGETHER. THEN 3/4" STAINLESS TRIM. UNFORTUNATELY THERE IS A PRETTY BAD MATCH BETWEEN THE 2 HALVES! SO WE GOOBERED IT UP, WITH THE ADDED TAB MATERIAL IT SHOULD ROUND OUT AND LOOK OK. I DID THIS ON MY 21" MFG AND IT CAME OUT REALLY COOL!
LOOKING DOWN ONE SIDE
TOMORROW NOV 6TH I WILL ADD MATERIAL TO THE PERIPHERY AND GLASS THE MOTORWELL FLOOR AND SIDES WITH 8 OZ CLOTH. THEN WE HAVE TO START THINKING ABOUT THE FINISH.
WILL QUICKFAIR FILL IN THE NASTY GEL COAT SPIDER CRACKS OK? DO I NEED TO PRIME THE GLASS 1ST? I AM IMPRESSED WITH THE SMOOTH FINISHES I SEE USING THE ROLL AND TIP PROCESS. I HAVE ALWAYS SPRAYED, BUT PRESENTLY HAVE NO GUN NOR GOOD SHELTER. HOW LONG DOES IT TAKE THE STERLING PAINT TO TACK OFF?? I MIGHT BE ABLE TO RIG A TEMPORARY SHELTER FOR THIS JOB IF NEED BE.
11-21-2008
I AM ABOUT READY TO ORDER SOME FINISH, I HAVE SOME QUESTIONS REGARDING APPLICATION AND COVERAGE.
IN ADDITION TO THOSE PRIOR Q'S POSED IN THE FORUM -
WHATS THE DEAL WITH THE GRAPHITE BOTTOM PAINT - I CAN'T FIND IT ON THE BBC SITE.
HOW MUCH STERLING PAINT REQUIRED FOR MY:
DECK (ORDER 1 QT?)
BOTTOM (ORDER 1 QT?)
HULL SIDES AND TRANSOM (ORDER 2 QTS?)
OVER TOP OF QUICKFAIR - SHOULD I PUT A COAT OF RESIN AS STATED ON THE CONTAINER OR WILL PRIMER SUFFICE?
PRIMER - BRUSH OR SPRAY?
CAN I JUST PAINT OVER THE EPOXY ON THE INSIDE WITHOUT ANY PREP OTHER THAN SANDING?
CAN YOU RECOMMEND AN EPOXY INTERIOR FINISH SIMILAR TO THE OLD "ZOLOTONE" SPATTER TRUNK OR HULL INTERIOR FINISH THAT WILL LAST FOR A BOAT? I USED GEL COAT IN HAWAII BUT THAT SEEMS OLD SCHOOL.
I HAVE BEEN ADDING TO THIS BBS BUT I CAN'T FIGURE OUT HOW TO ADD A NEW POST! OR A NEW PAGE. ALSO WOULD LIKE TO SET UP A PHOTO GALLERY OF THE PROGRESS ON THIS BOAT, WHERE DO I START?
