NV23 Build
NV23 Build
Does anyone know the position of the stringers on the molds of the Novi 23. Or, where to cut the notches on the molds. I can't seem to find it on the plans.
Re: NV23 Build
It's on the plans.
See drawing E239/5.
It shows the spacing of the stringers on frame B.
It is the same for all frames.
See drawing E239/5.
- Hope2float
Re: NV23 Build
Welcome Od
Topwater is building a NV23 he can probably help with some questions on that build. Good luck and enjoy the sanding
Dave
Dave
Re: NV23 Build
Thanks very much. I found the numbers for frame B. This is a great forum!
- topwater
Re: NV23 Build
Dont forget to post pic's, at the rate i am moving at you will catch and pass me
Novi 23 finally launched !
Re: NV23 Build
Ok folks,
I am building and ready to share some pictures.
I understand I need to first put them in or on the gallery. but don't know how.
- Mad Dog
Re: NV23 Build
odwyerjb wrote:Ok folks,
You can also use a host like Photobucket to link in the pics. That was easier for me and allowed me to share images on other forums and such.
MD
Ergo piscor, ergo sum
Re: NV23 Build
Thanks Mad Dog. Lets see if I can get this thread going and do something useful.
First picture:
This is how It started on April 2nd 2012. I needed a place to build and didn't have a shop big enough. So I have to build outdoors. This is my back yard with my shed to the right. The trees to the left are just about 16 feet from the shed so there should be just enough room for the flip. You can see the sprinkler head whidh I moved so it wouldn't spray the boat each day.
This is the strongback made from 2 x 10's and on 4 inch posts.
The yard has a bit of a grade, which you can see here in this picture.
The strongback is 3 ft wide. I have seen this question asked in some other threads.
I have more pics posted on an album., but it is time to work on the boat!
First picture:
Re: NV23 Build
Still having trouble posting some pictures from the gallery, so this is a test.
First station installed on the strongback
Re: NV23 Build
Ok, but the picture is small. Secondtest
Users browsing this forum: Yandex [Bot] and 13 guests
