OD18 Gunnels
cottontop
OD18 Gunnels
Post by cottontop »
Cracker Larry and others having gunnels on their OD's, I'm doing some work on my OD 18 and have decided I would like to add gunnels to mine. Need some suggestions. How wide, supports, adding rod holders in these,what thickness plywood, etc. I built inwales on mine but have decided i would like the gunnels. Also thinking about adding a jack plate. Any good reasons for doing so? What size/hydraulic-manual? And finally, thinking of changing from from mechanical steering to hydraulic(pros/cons). Thanks, John :doh:
Larry B
Re: OD18 Gunnels
Post by Larry B »
John, I used 3/8" ply for my gunnels, here are some pictures:
Here's the brace's I used:
and another shot:
You can't see the jack plate too good here, but it's the one Shine sells here on the site. I love it because I could get my motor height perfect. Craig, has the hydraulic jack plate and can raise and lower it while under power, I couldn't afford that one :wink:
As far as mechanical vs hydraulic steering, I have hydraulic and love it, and it's really not much more than mech. I can get you pictures if you want??
Larry
Completed: FL14, OD18
cottontop
Re: OD18 Gunnels
Post by cottontop »
Thank you Larry. I really appreciate the response. I just finished reading your build thread last night just before I wrote this. I love your boat. It is a real beauty. How wide were you gunnels? Don't remember reading about their width. These OD's are some really fine boats. Very versatile. There weren't many being built when I built mine. I have learned so much more from you, Cracker, Craig, Steven, and so many others. Wish I would have had the knowledge I have now from all of your builds when I built mine. That's what makes this site so great. John
ddbiiz
Re: OD18 Gunnels
Post by ddbiiz »
John,
I made mine about 8" then 3/4" inside trim, the supports were every 4', and I used 3/8" ply. Had 4 rod holders, cleats, and rod storage on supports never had any problems. The only thing was boat got skinny at console because I made the console to wide, it was my first boat live and learn. 8) Good Luck
Don
Cracker Larry
Re: OD18 Gunnels
Post by Cracker Larry »
John, I made mine 6" wide and they were almost too narrow for fitting the rod holders. Because of the hull flare the bottom of the holders are fairly tight to the hull sides. I would make them 7 or 8" if I were doing it again.
I also used 3/8 ply for the decks and 1/2 for the frames. Frame spacing is 36". The inside edge is 3" high. It's rock solid. I'll dig up some pictures of the framing.
I added a mechanical jackplate (Bob's) with a 5" setback. It added a couple mph and allowed the engine to be raised higher, which makes it more efficient and reduces draft.
Hydraulic steering is certainly nice, but with these low HP engines, not really necessary. My NFB cable system works like a champ and no torque is transferred to the wheel.
Larry B
Re: OD18 Gunnels
Post by Larry B »
cottontop wrote:Thank you Larry. I really appreciate the response. I just finished reading your build thread last night just before I wrote this. I love your boat. It is a real beauty. How wide were you gunnels? Don't remember reading about their width. These OD's are some really fine boats. Very versatile. There weren't many being built when I built mine. I have learned so much more from you, Cracker, Craig, Steven, and so many others. Wish I would have had the knowledge I have now from all of your builds when I built mine. That's what makes this site so great. John
John, Mine start at 6 1/2" to 8 1/2" at middle of console and ends at 11", only reason my boat turned out so well is because of all the builders before me, including you John :D
jacquesmm
Re: OD18 Gunnels
Post by jacquesmm »
Off topic but I love the paint job on that yellow boat. :D :D
Cracker Larry
Re: OD18 Gunnels
Here ya go John, gunwales in 12 easy steps. I wouldn't do this for just anybody :D
Cut and glue the frames, I wanted mine above the sole so I wouldn't stump my bare toes and it makes the boat much easier to clean. Then glass them in and add support cleats. This is the best way I can figure to get the frames square.
I try to move along wet on wet, so everything is at a different stage of completion at the same time
Notch the frames for the support cleats.
Fit and glue support cleats.I used 1X1 for these cleats.
At the transom I had to make the deck narrower so I could open the hatches. LarryB did about the same thing. This is the transition joint.
Bow view of cleats
Use heavy paper to make a pattern
Pattern cut to fit
Transfer pattern for best nesting
Cut and fit decks
Glue inwales. I ripped 3" strips of 3/8 ply for mine
Clean it all up
EDIT: I used a router for that, first with a flush cutting bit, then with a 3/8 round over bit. Then glassed over the whole thing.
Done :D
Last edited by Cracker Larry on Wed Dec 12, 2012 9:03 pm, edited 2 times in total.
Larry B
Re: OD18 Gunnels
Post by Larry B »
jacquesmm wrote:Off topic but I love the paint job on that yellow boat. :D :D
Thanks Jacques, She is definatly Yellow :D
cottontop
Re: OD18 Gunnels
Post by cottontop »
dd, cracker, and larry thank you all for your quick replies. Cracker, I don't know of anyone who is more helpful on this site or generous with the sharing of their knowledge. 8 inch gunnels it will be. Cracker and Larry does the jackplate holes automatically line up with the motor holes I already have drilled in my transom? I currently have my Mercury mounted to the transom. Cracker did you order the mechanical plate from Shine? I will wait till the new year to order plywood from Jacques and Shine. We are leaving early next week to head up to the mountains for Christmas. Daughter and son-in-law wanted us to do Christmas in Tennessee this year. 1st time ever doing Christmas away from our home in Florida. I wish all of you a Very Merry Christmas and A Happy, Healthy, and Prosperous New Years". John :)
