I would just like to say thanks for all the help I have gotten here. I wouldnt have been do this without it.
Here is a drive by:
http://youtu.be/QgnWQZF33bc
At least, and it would keep it under the redline, AND should provide better economy.Auger01 wrote:With the 16 pitch prop it tops out right at 40. Lighly loaded it WILL slighty go over the redline of 6000. I am thinking that with a 18 to 19 pitch prop might do 45mph.
With four adults, a kid and an ice chest, at WOT I got 5800 RPM, which is just about right. Since I will be pulling kids around on skis and tubes, I think having it propped a bit low is probably a good thing. I may get another higher pitch prop to put on when it is just me and the Mrs. crusisng around.AMC wrote:At least, and it would keep it under the redline, AND should provide better economy.Auger01 wrote:With the 16 pitch prop it tops out right at 40. Lighly loaded it WILL slighty go over the redline of 6000. I am thinking that with a 18 to 19 pitch prop might do 45mph.
Thanks. I really wanted to use an orange carpet, but it just isnt made anymore so we had to go with something different. The navy blue turned out well I think.AMC wrote:The boat itself looks good, but that interior is at a different level. All the seats look fantastic. You kept a interesting combination of the original look with some modern takes. I would never have thought to use that blue carpet with the red seats, but I think it really pops. Very creative choices. And the access panel in the back, in place of the old curtain cleaned up the look a great deal.
Spoil the classic lines of a 70's trihull with a trolling motor?!? Surely you jest.AMC wrote:All you need now is a bow mounted trolling motor on the front, and a pedestal seat and you will ready!
I think I did two or three coats of epoxy and three coats of varnish. I used the system three clear coating epoxy. I did not thin it. It was made for this application. I used Pettit Flagship and also thier Captain varnish. I only sanded if I let the epoxy fully cure before the next coat and to correct any imperfections. I sanded the epoxy with 120 grit to prep it for the varnish. To sand between the varnish coats I used 220 or 320 grit paper. I would thin the varnish with exactly 1/2 oz of thinner per 3 oz of varnish.tcason wrote:Auger01 wrote:Can you provide how you did the epoxy on bare wood with varnish over?
such as
Number of costs of epoxy
Did you thin epoxy
sand grit between coats
any lessons learned?
