some coloring inconsistencies
Re: some coloring inconsistencies
Yes, it's very thin paint and takes multiple coats. I've never thinned it more than 10%.
I applied the 3 coat and it is already better , I hope a 4 coat will cover everything even .
I have one more question about the thinning part, in the tutorial about "Roll and Tip"
there is written that thinning 35% is "dead on" but there is also an example that says 2 ; 1 ;1 ratio .
So you could thin up to 50% ?
I thinned about 20% on the red boat.
It was 100 degrees Fahrenheit in the shop when I painted it.
50% is too much thinner in my opinion.
Richard
viewtopic.php?f=12&t=62146
a spot with two coats (from the same can) will look different thatn a spot with one coat - it has to do with the film thickness. Bright colors take more film thickness to achieve color uniformity. The red stripe on my runabout took 3 pretty heavy coats, the white on the sides took only two thin coats.
DB Michel wrote:I have one more question about the thinning part, in the tutorial about "Roll and Tip"
The way I read it 2:1:1 would mean 50% paint, 25% catalyst, and 25% reducer
50% is too much, there woudl never be a need for that anyway.
that's right..... you can go as high as that 2 part color, 1 part activator, 1 part reducerThe way I read it 2:1:1 would mean 50% paint, 25% catalyst, and 25% reducer
Ok , thanks for the help
Users browsing this forum: Ahrefs [Bot] and 6 guests
