re-finishing meranti table with EMC clear coat
technical support and information on EMC topcoats and coatings
tech_support
Post by tech_support »
decided to refinish my outdoor table using the EMC clear. Table is made from reclaimed meranti from old pallets, I made it a few years ago and its been used outside since then. There are a few coats of epoxy over the wood, then I used S3 clear LPU over that. Table gets abuse (plays the roll of craft table for children) so I fist sanded scratches out with 180, then went back over it with 320. Then I simply rolled about 2 ounces of the EMC topcoat over top and.... 8O 8)
jorgepease
Re: re-finishing meranti table with EMC clear coat
Post by jorgepease »
Wow, that came out like new! Nice
wegcagle
Post by wegcagle »
Joel,
Do I need to buy an activator for the clear coat or is it just 1 part? Now that my boat's primed I figure I better add my wood accent pieces now before topcoating everything.
Thanks,
Will
tech_support
yes, you need the two parts, plus some reducer.....
Cracker Larry
Post by Cracker Larry »
Wow, that's nice :!: 8)
wegcagle
Post by wegcagle »
Thanks Joel. Love the table by the way. That's one heckuva crafts table 8)
Will
tech_support
After some of the other projects around here are wrapped up, I have a bigger/longer table in mind. I have a ton of solid meranti pallet wood saved up 8)
ks8
Post by ks8 »
Very nice pallets 8)
So there was still plenty S3 LPU left on there when you rolled and tipped the EMC over it?
tech_support
Yes, Im sure there was, I just sanded the surface with 320. It probably took most of the S3 off
tech_support
Our new house did not have a good place to put the table, so I turned it into a new front door :)
