I have the hydrotech, plans and kit...........now if i can find the skills.
I already have an 18 horse 'rude to push it.
Locally I have found 25/32 Honduras mahogany; will this work on the transom or is it too thin?
Is there a preferred wood for the splash rails?
How much Quick fair will I need to do all the fairing?
I'm getting rather stoked.
sin city D15
Re: sin city D15
I do not know anything about building that boat but I can tell you not to worry about the skills part. If you want to build it and stick with it then you will build it. I am pretty sure my woodworking skills are at the bottom of the list but this method is forgiving enough it did not matter.
Re: sin city D15
I can't answer about the plywood, I must look at the plans. What do the plans say?
Watch out for the weight of the engine, that puts stress on a transom while on the trailer.
Re: sin city D15
"Outboard clamp: hard wood (mahogany) 10" x 1", one 5' piece.
Locally I have found 25/32 Honduras mahogany; will this work or is it too thin?
Thank you
Thank you
Re: sin city D15
'll look at the plans tomorrow.
When I designed that boat, mahogany was reasonable priced. Not anymore. You can use plywood but thicker.
Tomorrow
Tomorrow
Re: sin city D15
If my outboard is shorter than the 20" as in 15", should I lower the clamping board, or leave it flush with the sheer and cut it down?
Re: sin city D15
Please read this:
http://www.bateau2.com/howto/shaftlength.php
That is how an outboard should be installed.
Almost all engines are either 15 or 20" but some are in between and you have to adjust the transom height.
Re: sin city D15
thank you for putting me right!!
i measure 18"shaft length on my motor.
time for more measuring and cutting.
Re: sin city D15
frames are together need to get pictures....
Re: sin city D15
Ok, it is flipped and I'm almost ready to glass the bottom..... anyone have any advice on a trailer?
Users browsing this forum: Yandex [Bot] and 16 guests
