This is more of a historical post than a build log, the boat was finished and launched a few days ago. Mainly I wanted to pass on the differences and atrocities that were committed during construction. First off, I figured out after making the V12, that once I have a completed boat in my garage, I don't have the room to make the rudder and daggerboard. So, I started with that first this time. Also, since the guy I sold the V12 to, found out that the daggerboard was not impervious to rocks at full sail, I made him a new one as well. Along with what turned out to be a great improvement.
First, both daggerboards, made to plan, clear epoxy, and a layer of 4oz. glass. The glass helps with abrasion resistance and adds a bit of weight, which is needed because they both still float. I later added some 17oz. glass to the upper body of the V12 daggerboard just to weigh it down some.
![Image](http://i.imgur.com/Gla3xsG.jpg)
Next step was hacking off the leading edge at the tips of both boards and making a flexible mold out of the hacked off bits.
![Image](http://i.imgur.com/wgSTSRy.jpg)
The mold was sprayed with pam, then filled with epoxy/graphite. Using a drill, small holes were peppered through both the resulting pieces and the daggerboards, giving a strong physical bond.
![Image](http://i.imgur.com/y2Txl3Z.jpg)
A bit of sanding/shaving and then a few coats of spar varnish later and we end up with this:
![Image](http://i.imgur.com/0eFU57B.jpg)
The smaller V12 board has had a lot more 'testing' than the CR13 board. However, we can say for certain that it will hold up to serious rock abrasion and impacts. At around 4 knots the V12 was brought to a complete stop by an immovable rock. The resulting scratch in the graphite epoxy is hard to find if someone doesn't point it out. So the extra work of molding and replacing the tips of the boards does seem to be worth the effort.
Next up, building a boat!
