I've gotta tell ya -- I LOVE THIS BOAT! The more I use this thing, the more I enjoy it, but I have one issue -- THAT DANGED TILLER EXTENSION ISSUE It clearly performs best with me in the middle seat. Steering is ok, but from a safety standpoint, I have to waddle back to the engine to put it in and out of gear. Quite an inconvenience, and it makes docking very difficult -- no way to "brake" without the reverse!
The Automatic trim tabs by Nauticus look very interesting, and I can get a set for around $100. Do you think this might help overall performance and the squatting when I'm in the stern (boy, that sounds funny)?
If any of you GF16 builders have the same issues, I guess I can be the sacrificial lamb and give it a shot
GF16 -- Smart Tabs???
- smilinmatt
Smart Tabs
I built my own non-adjustable trim tabs out of 1/4" ply and they worked fine on a similar boat . Tabs don't ride down so far that they inhibit poling, but they do make backing up or poling backwards a little squirrely.
They completely solved the weight distribution problem, though.
$100 sounds like a bargain. Mine cost almost nothing though and took about 20 minutes to build.
Another solution is to put a Dolfin or other hydro-plane type thingie on your cavitation plate. That might work better for poling since you can haul the motor up.
Just my 2 cents.
Just my 2 cents.
Beigebond,
Can you e-mail some pictures to me? I was thinking of doing the same thing, but I'm not really sure how to proceed. E-mail is redfishla@hotmail.com
Thanks!!
Thanks!!
Trim tabs
There was a question how to do this -- I didn't keep pics, but it's simple. For two tabs:
Cut 5 8x8 inch squares of ¼ inch ply.
Cut 1 of those 8x8 pieces diagonally to make two triangles, I cut a 2 inch circle in the middle of the triangle for looks.
Put the triangles in the middle of the squares to make two simple 90 degree brackets. The circle cutouts helps with clamping.
Use fiberglass tape and epoxy to assemble the pieces. Use tape on the inside and outside of where the two squares meet.
Coat the whole thing in epoxy and paint as you like.
Use two #10 stainless screws with washers on each side of the triangle to mount each tab to your transom (8 screws/washers total). The edge of tab should be flush with the bottom of your boat – if you cut slots rather than drill holes in the tab, you can shift the tab up or down as an adjustment.
Each tab will sit flush against the transom of the boat on either side of the motor. The angle of the transom should give enough downward angle to the tab (it only takes a few degrees). If you don’t think it’s enough, you can add shims between the transom and tab at the top screw points to increase the angle.
You can make these bigger or smaller and improvise the shape if you like – I did mine as a prototype thinking they’d break off after hard use but they never did.
Those tabs are a good idea but are we not on the wrong track here?
The tabs are suggested to avoid the tiller extension but why not solve the tiller extension problem instead?
First, with a crew, there is no need for a tiller extension.
It's only when you are alone in the boat that you need one.
Docking is not done at planing speed. I used tiller extensions a lot but when I get close to the dock, I move back and that's all.
Note that there are tiller extensions with a connector to switch in fwd and reverse. They cost $ 60.00. There was one at our last meeting in Jacksonville, on the XF20.
I don't know the make or where to find it but somebody else may know.
Smart Tabs
Tiller extensions work. But there are a couple advantages to tabs:
I got a little better speed with tabs than with putting my weight forward (not sure why, I just did).
The ride is a little better further back.
I had more confidence in turns seated at the rear than in the middle.
Also, I didn't put a middle seat in my boat -- I cut U frames and put a cooler between them. Even strapped down, it wobbled a bit.
The tiller extension gets in the way sometimes.
It's nice to just pull start and go without having to move forward.
You can't make really sharp turns with an extension (well, not intentionally anyway).
Of course you can take the extension off easily, which makes it a lot more flexible than tabs.
Yes, the ride will be more comfortable in the back, that is a good point.
Users browsing this forum: Ahrefs [Bot], Yandex [Bot] and 20 guests
