I like the "problem" side of the projects. "How do I cook my fish when I don't have any land and I'm on a 12' dinghy and my fuel is the dry sticks I brought with me?" "How do I sleep with adequate ventilation, bug protection, and stability while maintaining loft that will prevent need for mattress material?" "Who in their right mind builds a boat of ANY kind without a way to get it to the water?" I've added a requirement for long term sustainability to all my solutions as well. No specialized products that lock me into vendor relationships, nothing I can't build or replace with off the shelf stuff, nothing that requires specific materials. More than once I've found myself sitting with the sander on (luckily not on the hull) staring at a space and trying to imagine how I would fit a bait well or cooler in it.
And before anyone worries about weight... By the time the big trips start, I will have LOST as much weight as I'm adding in "stuff". Full load out should be well under 225. Loosing 60lbs leaves room for LOTS of gear.
I need to take my own advice. I think I said it to Karl: "if no one can see it, why are you worried about it?"
I just spent about 2hr swearing at a buck of stuff only to realize that NONE of it will be visible once the mid seat is on. I'm not Tony...
More compound will be applied tomorrow.
Good stuff Jaysen!!! Jeff
I stand falsely accused!!
I didn't finish the insides of the lockers more than to make sure there were no sharp pieces of glass that could cut you. And I didn't fair the underside of the middle seat. I may be nuts but I'm not crazy.
Tony
In my case it's the forward side of the frame. Remember that I've got the dagger trunk which necessitates the long nosed middle seat. Not a snowballs chance in hell anyone will see the bottom of that frame. Especially considering that no one will be forward of the frame unless they are launching the boat.
I actually need to deal with the bow all the way from beasthook to mast step. Not looking forward to that.
- glossieblack
Your on the right track Jaysen. Seeking perfection is the enemy of the good.
No pictures but bottom of inside is "done enough". Have sides and frames to smooth.
That said I have a bit of finish sanding in the corners and from mast step forward. Should go "quick" (does it ever go quick?)
Pictures soonish but not today.
Holding out on us.................ok, I see the way it is going to be
Just like you and fishing. 9' seas should be nothing for you.
Users browsing this forum: Ahrefs [Bot] and 10 guests
