Fellow boatbuilders,
I am building the "corsair 11", I just started to draw the plans on plywood of this nice little boat. I like the "open stern" version.
I'm not in a hurry as I don't have much freetime and also is my first boatbuilding experience so don't expect spectacular progresses. My first milestone is to complete the hull.
Regards,
Jordi.
Corsair 11
A bit of my"building report":
All 9mm plywood pieces are cut: frames, transom, daggerboard and its case, skeg and rudder.
In the last two days I drew and cut the hull bottom and sides (in 5 mm plywood as I couldn’t find 6 mm) I’ll cut the deck at the end of the building process.
The next step is to assemble bottom and sides with a butt block and “stitch & glue” everything. This will be done at the end of august, I’ll be away a couple of weeks sailing in the Mediterranean Sea . I'll post pictures when I'm back.
BTW, I have a question: should I post this in the "Builder's sailing boat" or in the "Builder's small boat" forum?
Regards,
Regards,
- Jordi -
I think that qualifies as a small boat.esparver wrote:A bit of my"building report":
Regards,
Well, this is done you can see the side and bottom panels glued, as well as the skeg, centreboard, rudder and its box (not shaped yet) in my buiding gallery.esparver wrote:The next step is to assemble bottom and sides with a butt block and “stitch & glue” everything. This will be done at the end of august
I'm about to stitch all the hull together and post pictures of the process very soon.
Best regards,
PD: ChrisObee yes of course, but for me it's a BIG boat!
- Jordi -
Olá Jonnas,
Yes you're right. I eddited my previous post.
Thanks!
BTW: my thumbnails photo album is here:
http://gallery.bateau2.com/thumbnails.php?album=169
Thanks!
- Jordi -
More to update!
I've just stitched all the hull!! there's a couple of pictures, the rest is in my builing gallery.
Next step is to measure diagonals and begin with the fillets: I will glue the hull with a bit of epoxi+filler and then remove the plastic ties, put tape outside and be ready for some serious filleting (first milestone will be acomplished then)
Hope you like the pics!
- Jordi -
Hull is turned, diagonals measured and ready for filleting.
Right now I'm doing epoxy tabs to remove plastic ties and begin filleting. A couple of pictures:
More to come...
Cheers!
More to come...
Cheers!
- Jordi -
