Hi John, hope all is well with the boat now that you have had some time to use it. How are the windows working out ?
Still on my build and need input. Your motor controller seat - what thickness have you built it to ? I will be using the OEM Mercury control which is still quite large for my 9.9 HP (12" long x 7" high plus the "T" handle sticking up from that). I did not buy it yet but am building the seat at this time. Because the cabin sides angle inboard, I suspect the T handle will rub on the cabin internal side if it's not thick enough. Right now, the seat thickness is 3/4" ply to be glued to the 3/4" coaming much like what you did on yours.
p.s. You have used Monstaliner; does 5200 bond to it no problem ? What about silicone ? Kiwi Grip sticks, I recall that one...
Marc
Topwaters NV23
- topwater
Re: Topwaters NV23
Blueflood the boat is going great and the windshield works excellent. The vinyl roll up side curtains i take off
and leave at my dock because its hotter than hell here in the summer. I wish i had them a few times when i
got caught in thunder storms .. As far as stuff sticking to Monstaliner you will have to test. I know
Kiwi Gripe will not stick to it as for 5200 i dont know because i didnt use it on any deck fittings .Silicone
i dont use on my boat. What i did use is Boat Life Life Seal which is a hybrid caulking compound , i like
this stuff alot . What i did is trace with a pencil the out line of what ever i was bedding down on to the
Monsataliner and rough it up with some sand paper , wipe it down then bed it . worked well for me.
The only stuff i have found so far that will stick to it with out prep is Weld Mount 4020 Acrylic adhesive.
This stuff is crazy strong I used this and weld Mount zip tie bases for all my wiring , steering hoses,
wire harness any thing i wanted to stick to the hull . It saved a ton of time , no drilling and filling , no waiting
dry time. Half strength in 10 min which i think is 100 LB . Check it out its not cheap but i use it for every thing.
John
John
Novi 23 finally launched !
Re: Topwaters NV23
Hi John,
Thanks for this...one thing you skipped over...the outboard controller
Marc
Marc
- topwater
Re: Topwaters NV23
Blueflood my mercury controller came with a 1/4" or a 1/2" spacer for the back of the controller.
I ended up not using it and built my own spacer from a piece of 1/2" white starboard. You kind of
have to look at at it when you get it to see what angle and spacing you will need . If you end up with
the same controller that i have i will give you the factory spacer that came with it and you could do
something with that. Let me know i'll mail it up to you.
John
John
- glossieblack
Re: Topwaters NV23
Topwater, Great to see that you have been recognised as a 'Bateau Builder - Expert'. You've built a beautiful Novi 23 and you give great advice. Thanks.
- topwater
Re: Topwaters NV23
Thanks for the vote of confidence Glossieblack . Us cloofs have to stick together
Re: Topwaters NV23
Hi John,
hey cool ! Promoted
Marc
hey cool ! Promoted
Marc
Re: Topwaters NV23
What a beautiful boat. Great job.
Re: Topwaters NV23
Hey topwater couple of quick questions:
1) how is your transducer working out are you happy with it? Did that location work ? I’m at the point where it would be time to pick an area and glass it. Yours was the first I’ve seen and it’s looks like a great idea.
2) I also have some purpleheart I was thinking of for a keel was there a particular reason that you changed your mind ?
Thanks Tom
Thanks Tom
- topwater
Re: Topwaters NV23
Tom the transducer location works perfectly no problems and no spray . The purple heat skeg ended up with a warp in
it , i don't know why and it was easier to build a new one out of some scrap 1/2" marine ply i had laying around.
When i put it on the hull i glassed it with 12 OZ glass. Tom where do you live in Mass I lived there for 48 years.
