Roland, I have the "long shaft" Honda 90, which I assume is 25". I wouldn't stress over 1/2", you will be able to adjust when mounting your motor. Good Luck, Ronnightcrawler wrote: ↑Sat Sep 04, 2021 9:02 am Good morning Ron
Quick ? for you. Is your motor a 20 " shaft or 25". I am getting conflicting info. JM said in one post that the 19.5 inch to the dwl is good for a 20" shaft. that measurement gets you 25.5" to the bottom of the hull. In my limited experience that was the measurement used to gage shaft length. i am confused.
Roland
PG 25, July 2017, PangaRon
Re: PG 25, July 2017, PangaRon
The Duckbill Drains worked! Thanks for the suggestions! The boat took on minimal water during launching and stayed almost dry the whole day. Just a slow troll and the water drained. I just needed a little slope at the the ramp to get the boat clean. It was the first time I wasn't standing in water all day! This forum is the best!
Good news! Glad they seem to be working for you.
That is awesome! I'm glad you were able to find and good cheap solution!
Great news!!! Jeff
Am glad you found a fix. Good luck fishing Ron. Sorrry if I was a pain.
Super, Ron. Great fishing from here on out, keep us informed.
Keep them clean and supple. UV will perish then in the end, though there's spray protectants that work against that.
Good recommendation, thanks!OneWayTraffic wrote: ↑Tue Nov 09, 2021 1:15 pm Keep them clean and supple. UV will perish then in the end, though there's spray protectants that work against that.
303 is what we've used for years on our drysuit gaskets.PangaRon wrote: ↑Tue Nov 09, 2021 4:58 pmGood recommendation, thanks!OneWayTraffic wrote: ↑Tue Nov 09, 2021 1:15 pm Keep them clean and supple. UV will perish then in the end, though there's spray protectants that work against that.
https://www.amazon.com/303-Protectant-P ... 56891&th=1
