The forum upgrade is complete. It was very uneventful. Please post issues in this thread.
Due to a high level of "bad actor" traffic on the community site Jaysen is implementing a forced verification to confirm that you are a human. This is a PITA and he hates it too. The 3.2 seconds it takes for the one time you have to do it every couple hours is much preferable to the hours we are losing to morons clogging the CPU on the servers. Jaysen is still looking to solve this a bit less intrusively and without cost to BBC. Hopefully the magic solution will appear out of thin air soon. Jaysen is already annoyed.
TW28 for Adriatic Sea
TheBroomside
Re: TW28 for Adriatic Sea
Post by TheBroomside »
Looks good. Nice work!
Peter
LUS
Corto Maltese
Post by Corto Maltese »
I'm posting the question also here:
Finally, I'm going to buy a propeller now for the TW28. But... there's no exact answer and I'm a little bit confused.
I have a Beta Marine 43hp (Kubota) 2800rpm engine with TMC60 (2.54) and a Python Drive in front of the 35mm axle. Now, Jacques proposed a long time ago a 17"x13" propeller for a similar engine and transmission, but the dealer suggests to me 19"x17". I wanted a 19" 3-blade propeller as there's enough room.
I checked different online pitch calculators and I'm even more puzzled. The data ranged from 19"x11" to 19"x14" and one calculated the same 19"x17" dimensions as the dealer offered. So, maybe this last dimension could work.
But I would like also to ask for real experiences from builders and practical people as obviously there's no hard science working here. Especially because the hull of TW28 with box keel is not common.
Wish you nice summer on your boats or successful boat building.
Dario
glossieblack
Post by glossieblack »
Does the prop supplier offer a re-pitching service for a fee? If so, suggest you go with the largest practical diameter, and a somewhat conservative pitch. Use it for a season, gather data, and then re-pitch if required.
Corto Maltese
glossieblack wrote: Thu Jun 23, 2022 6:48 am go with the largest practical diameter, and a somewhat conservative pitch. Use it for a season, gather data, and then re-pitch if required.
That sounds clever, thnx
glossieblack wrote: Thu Jun 23, 2022 6:48 am Does the prop supplier offer a re-pitching service for a fee? If so, suggest you go with the largest practical diameter, and a somewhat conservative pitch. Use it for a season, gather data, and then re-pitch if required.
Glossie is spot on. You do not want to over prop the engine as that is a good way to kill it. Fully loaded boat with all the weight it will ever carry and the engine should still reach full rated RPM. You do need to be a little close on the prop as there is a limit to how far a prop can be re-pitched. For a 19-20 inch prop you need about 3 inch clearance. I would go with the biggest dia prop I could swing.
TheBroomside
Dario,
I have a very similar setup: 42 HP Mitsubishi, TMC60 with 1:2.5 reduction, Python drive and 35 mm axle.
The propeller is 19x13. Cruising speed is app 10 km/h at 1700 rpm. At 800-900 rpm speed is 6 km/h. For manoeuvring a lower speed would be easier, so perhaps the pitch is a little high. On the other hand the 1700 rpm is a good compromise with regard to noise, so I am not really considering changing anything. With this setup the Luka needs a little less than 1,5l/h which is quite nice considering current diesel prices.
I do not think the setup can handle a 19x17 prop, to me me the pitch is way too high.
Good luck, looking forward to a splash.
Regards,
Peter
Lus
TomW1
Post by TomW1 »
Dario totally agree with Luka you do not want to over pitch this your motor.
Corto Maltese
Thanks for the excellent advice,
yes, I've also doubted the suggested pitch. I'm expecting cruising speed around 5kn and enough thrust for sudden gusts of bora, the strong wind falling from mountains toward the Adriatic sea.
Peter, I have just one question more... do you reach max rpm? (in my case 2800)
I wish I could drink a beer with you :)
vla
Post by vla »
TheBroomside wrote: Thu Jun 23, 2022 3:00 pm Dario,
Regards,
Peter
Lus
Dario,
I have the same engine as Peter, only mine have a 30mm axle. My prop is 16x14 . The cuisine speed is 10 km/h at 1600 rpm and uses 1.6l/h. So my conclusion is: no difference. But my feeding says that a 19 inch prop can transfer the power beter in the water. Max rpm +/- 2500 2600 with a lot of norse and a speed of +/- 14km/h.
Allard.
TW28 Stoere meid, the best boat for long trips
Corto Maltese
Thank you, Allard!
I needed your advice. Now I'm more confident.
I hope I'll get a good price, some producers want from me over 1000eur...
regards
Dario
