Or sweet talking a spot on a kayak lift. I don’t want junk on the transom when I’m out in the bigger water.OneWayTraffic wrote: ↑Thu Nov 03, 2022 1:54 pmI’d be investing in a pair of dinghy wheels on swing down brackets.Jaysen wrote: ↑Thu Nov 03, 2022 10:41 am I’m “hard” on the boat bottom as I have to launch/retrieve by dragging it up a concrete ramp. No matter which method I use it isn’t lasting more than two trips. Graphite is an easy touch up compared to paint.
Disclaimer: displacement hull doesn’t care it the touch up is perfect. Planing hull cares a lot more about the touch up smoothness.
How’s your graphite bottom?
Re: How’s your graphite bottom?
It works pretty good and seems to last for me. But it does not make the bottom bullet proof. It is just epoxy with a little stuff mixed in with it.
mine is fine with sand, smooth rocks, grass, crab traps, old dock posts, and things like that but don't expect it to be fine hitting a good oyster bar. i've pulled up on some and just slowly coming onto the oyster bar puts some scratches/small gouges in it. The good thing is it's super easy to touch up if you need or want to. I put on 4 coats on my boat after I faired the bottom and have no complaints and it looks better than work boat finish IMO.
Boats restored: 1973 Glastron CV16, 1990 Proline 17 CC, 1993 Bass Boat
Boats built: custom 15ft flat bottom skiff, Soon-to-be-built TX18 (originally dborecky's build)
