What HP did you go with?
Looks great.
LM 18 SSI GA
Re: LM 18 SSI GA
See my LM 18 build here.
viewtopic.php?t=64254
See my LM 18 Questions here.
Finished Boat Here
viewtopic.php?f=25&t=65173
Finished Boat Here
Re: LM 18 SSI GA
Is that a 4 blade prop? I tried several props and because the boat is so light I found that a 3 blade is much faster and the boat doesn't require the lift of the 4 blade. Just food for thought. I would think you should be able to hit 30 mph especially because you built light.
great job.
great job.
Finished Boat Here
Finished Boat Here
Re: LM 18 SSI GA
It’s just the stock aluminum prop. I’d like to try another one. I messed up when I mounted the Jack plate and the engine sits too low. The cavitation plate is about 2” below the hull with it jacked all the way up. It should help when I get that straightened out.Cbuf wrote: ↑Tue Nov 29, 2022 10:23 am Is that a 4 blade prop? I tried several props and because the boat is so light I found that a 3 blade is much faster and the boat doesn't require the lift of the 4 blade. Just food for thought. I would think you should be able to hit 30 mph especially because you built light.
great job.
Re: LM 18 SSI GA
If it helps I built mine heavy, ( Livewell, trolling motor, poling platfoam, with a 50 hp). My cavitation plate is about 1.5 inch above the bottom and I'm thinking of going one more hole up. Also, the transom as designed (or at least how I built it) was too steep. I had to install motor shims to get more negative trim.
Finished Boat Here
Finished Boat Here
Re: LM 18 SSI GA
The negative trim is good. I definitely need to get it lifted though.
Re: LM 18 SSI GA
Chuf, when you tried your 4 blade props were there pitch size at least 2" smaller than your 3-blade pitch. The most in speed you should lose is 2-3 mph. Edd if you would like I would be glad to work up a new prop size for you if you would like. Tom
Re: LM 18 SSI GA
Edd,
Really nice job on the LM!!!! Always nice to see some fish in the cooler!
-Reid
-Reid
- Steven Wright
- Steven Wright
Re: LM 18 SSI GA
Yeah I’m open to suggestions, thanks
Users browsing this forum: dennisb, Google [Bot], Google Feedfetcher and 8 guests
