HB20 Build - Upstate NY
Re: MT24 Build - Upstate NY
Jonathan
Jonathan
Kids and I did some color idea mockup. I guess we're excited. Although I also love the red and green, I'm going with the navy topside/red bottom (as rendered in the MT24 study plans).
I'll be building the boat in what was going to be my new 24x24 woodworking shop. It will now primarily be the boat shed. Although something will have to be done about the 7' doorways for a 9' tall boat. Maybe install the superstructure outdoors.
The town is aware that I'm building a carport. Once the siding is on and it's inspected, time for insulation and electrical. Nothing too fancy... just 4-season functional.
I also set up a page documenting the project, and the impetus for it happening.
https://jonlitts.wixsite.com/therapeutic-vessel
Jonathan
Jonathan
Nice looking workshop! Hope the kids are enjoying the process so far.
- Evan_Gatehouse
For god's sake built the front face so you can partly disassemble the section above the doors and built it all inside.
SK17,MM21/MT24
SK17,MM21/MT24
Evan has a great plan. If you don’t, you’ll always wish you had. I wish I wasn’t a slave to the weather.
Jbo
Jbo
Yes, I did weigh this option as well and have figured out a way. Definitely worth the extra effort.Evan_Gatehouse wrote: ↑Mon Nov 28, 2022 10:28 pm For god's sake built the front face so you can partly disassemble the section above the doors and built it all inside.
Jonathan
Jonathan
I'll be following along with your build. It's going to be a lot of work, and (hopefully) a lot of fun.
Good luck,
Mick
Good luck,
Mick
Happy New Year, builders!
Zero boat progress made... but definite workshop progress. I was able to squeeze 110" of height out of the door, constrained by the width needed between the center post of the building and the angle of the rafter. This should... I believe ... baaaaaaaaarely be enough to get the boat in and out of the shop on it's cradle. R38 and R19 throughout, power run, fairly well lit, and got the big sliding door hung yesterday. The door will get 2" foam board. Just need to seal up the door gaps before I can get some heat in there. OSB walls will suit me just fine.
I built this over a concrete pad that already existed on the property, giving me interior dimensions of about 23' x 23'. How frustrating for a 24' boat build . But diagonally will work fine.
Slow n' steady!
https://youtu.be/uHypQG-gQKw
Slow n' steady!
Jonathan
Jonathan
Really nice looking shop, it will make the build a joy! I would call that progress for sure.
