1986 19' Atlantic rebuild
goingbogueoutdoors
Re: 1986 19' Atlantic rebuild
Post by goingbogueoutdoors »
Dry fitted my other 1708 layers along the sides of the well today
goingbogueoutdoors
New tabbing and wetted out my 2 layers of 1708 on the transom as well as both pieces either side of the well.
on
cape man
Post by cape man »
Looks solid!
boguesounder
Post by boguesounder »
Looks great. Like the hull color also.
fallguy1000
Post by fallguy1000 »
Looks good. I assumed you intend to tab here?
It would be good to run that tabbing onto the new glass. All that force gets applied on gradients that way.
Easy to do, just dart the glass on the vertical and lay it down.
viewtopic.php?f=12&t=62495
fallguy1000
fallguy1000
Also, it is good to overwrap the top of the transom; same story; force gradients. I seem to recall you were or did, but lotsa strength on one side and little on the other is not best because you can get stress risers in the corners then.
If you have any doubts; after it cures for a week; just push against it with your legs and see if it gives in the middle. Looks strong to me.
goingbogueoutdoors
fallguy1000 wrote: Tue Nov 29, 2022 11:44 am Also, it is good to overwrap the top of the transom; same story; force gradients. I seem to recall you were or did, but lotsa strength on one side and little on the other is not best because you can get stress risers in the corners then.
Thanks! Yes did 3 layers of 12oz biax overtop transom as well as the two layers of 1708. Will heed advice and tab along well sides into the bilge forward of well. I have plenty of. 12oz. biax
goingbogueoutdoors
Pic of back of transom. Also where i plan to tab tomorrow on the well to the stern of the boat. Thinking one layer of 12oz. biax should suffice. Also taking care of that one dried out corner on the back of the longer layer as well.
goingbogueoutdoors
