Tips for drawing batten/plywood parts storage??
LloydCt
New Poster
New Poster
Post by LloydCt »
Greetings.
I would like to hear a couple of tips for:#1 a Drawing Batten material
#2 what is best method to store plywood parts/frames etc. after I cut them out.
#1
I have mostly decided in cutting off a 3/4 by 1/4 strip of what the Lumber Box store is calling 'premium' grade pine. Does anyone use mdf etc which wouldnt be affected by grain etc. or does it at all matter? Pine vs. Oak etc re: stiffness? Making small boat so super long battens not needed.
#2
Im not great with time management and it's winter temps here in CT. I am hoping to cut some of my parts ahead of an as yet undetermined time in the future when I can assemble the boat. What is the best way to store them for maybe a month or so? Cut them out and stack them in one flat stack possibly weighted? In the furnace room = good or in the furnace room = worst possible place for warpage etc. or it dosnt matter..?
Any thoughts on either question would def help this neophyte builder.
p.s. Re my D5 build it was suggested I 'just start' which I def appreciated. I have but what Im doing is practicing on full size large cardboard pieces to get the hang of things first.
LLOYD
Re: Tips for drawing batten/plywood parts storage??
Gotta keep them flat. Sticker or lay on flat floor that is for sure dry. If stickering the bottom; use same dimension material space every 6" max apart. Weight should not matter.
OrangeQuest
Post by OrangeQuest »
I stored my cut pieces on half an "A" frame I made for storing plywood. My warehouse is very high humidity and don't have the space to lay plywood flat. I stored it all on the A-frame for a few years. Was still very flat. We are talking 7 or 8 sheets of plywood and only a few were marine grade. The rest were very cheap stuff they use to protect tabletops in transit but they had edges on them to provide a very flat surface and air gaps so no moisture could build up and cause mold. Some of the pieces were cut for my sole and gunnels and things like that.
My A-frame has a lip at the bottom to hold multi sheets without slipping out and to keep everything off the wet floor. It's as wide as a sheet of plywood but has a foot print of 4'X 4', but is 8' tall.
VT_Jeff
Post by VT_Jeff »
I store all my plywood, whole and cut parts, on the floor under my 4x8 workbench between 1" sheets of insulation. Works for me, no warpage since i moved to this method. Maybe not the most convenient.
VT_Jeff
Post by VT_Jeff »
I used something similar to your plan for a batten. I cut a few different widths and played around with them to see which i liked. I may have used a pvc pipe for the long curve of my bow.
Chenier
Post by Chenier »
I'm not sure how small your "small boat" is. Mine was 14.5'. For a batten I used a 16' length of 7/16 x 1-5/8 clear pine from the box store. I might have found it in the mouldings section. Worked like a champ and I still have it.
Jaysen
Post by Jaysen »
Not sure when/where/who… someone once suggested 1/2” pvc. Use couplers for longer lengths.
TomW1
Post by TomW1 »
Do not lay your plywood directly on the floor or even on plastic. Lay it on 2x4's spaced every 18" to allow air flow under the plywood, it will keep that way for years. As someone suggested above 1/2" PVC pipe works best as it is cheap, flexible and can be adjusted in length. you can even use 3/8 or 1/4" to reduce the cost.
Post by Dougster »
Maybe just me, but I didn't like using PVC for battens. Like Chenier, I used moulding from Home Depot.
