- Knottybuoyz
Re: knottyBuoyz III The TW28 Project
https://youtu.be/4jEsgsDT9wc
Yours Aye! Rick
Oh, I am sure it works. I did a bad schematic in my pea brain the first time. First in series, then a shorted parallel.
And now I understand the 3 way connections are for each circuit's parallel node, not to add all the grounds.
Do you know if the circuit which will vary in current affects the led? I have forgotten Gaussian method (thank God, it was a nightmare). I think it does not now and the green mimics are okay.
If you have the running load mimics in series; those will vary for sure; maybe even fry if the current exceeds rated. At first, I thought everything was that way is all.
Very cool Rick. I am a little jealous. Mine is quite nice, but deciphering what is on and not is not so nifty. For me, I have to know the way each indicator stays home a:o their lighting status. Very cryptic.
I still am in a quagmire on my refrigerator. I want to leave it on at the marina, but not all my helm station controls. I turn on dc distribution and it is all on or all off. And if all on, all my led helm console lights are on. So annoying!
I guess I need to run the refer on 24/7 circuits and add a lighted switch in the kitchen.
Looks really sweet.
Question: Where did you get your volt-meter and ammeter? Which manufacturer?
Mick
Mick
- Knottybuoyz
Yours Aye! Rick
[/quote]
https://www.bluesea.com/products/catego ... log_Meters
[/quote]
Thanks...Good luck with your build!
Mick
[/quote]
Mick
- Knottybuoyz
Still tinkering with ideas for the Mimic Panel wiring etc. Learning a bit about all these tiny gadgets that rule our lives. It's mind boggling but I'm still keeping my head above water. It's hard to show restraint when presented with all the possibilities of what this technology can do. I'm simply using some of these common parts in an analog fashion to light up the pretty little LED's on the mimic panel. Most can be triggered and lit directly from the 12 volt source at the switch. Others require a relay to trigger the LED's. Some will need to sense AC current flowing into/out of the piece of equipment. Also had to purchase some tools etc. to make it a bit easier. My soldering experience is limited to copper water pipe and some speak wire.
My God these parts are tiny. The wires are 24 AWG IIRC. For someone with monkey mitts like me it's a challenge to be sure.
Waiting on a couple more parts then we'll string it all together and see if it lights up!
Standby....
Standby....
Yours Aye! Rick
I'm surprised you can't buy something, but I never tried.
- OrangeQuest
The AC voltage LEDS could be lit with just a bridge rectifier that converts the AC voltage to DC and drops the voltage at the same time.
- Knottybuoyz
I don't know. I'm still working on a solution to that. Pretty steep learning curve and AC electricity and I have a love/hate relationship.OrangeQuest wrote: ↑Sun Dec 18, 2022 7:56 pm The AC voltage LEDS could be lit with just a bridge rectifier that converts the AC voltage to DC and drops the voltage at the same time.
Yours Aye! Rick
- Knottybuoyz
Oh ya probably can but where's the fun in that? Seriously this is interesting stuff.fallguy1000 wrote: ↑Sun Dec 18, 2022 5:40 pm I'm surprised you can't buy something, but I never tried.
Yours Aye! Rick
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 20 guests
