I am nearing completion of a Quattro 16 beach cat by Woods design; which I didn’t post.
Waiting for logistics to deliver materials to continue. I decided to start to build a Zest 14’ dinghy,
also by Woods Design. (Oops that’s two).
A few days ago I cut out patterns from mdf and coated them with polyurethane.
I cut these with my finishing router.
Today the Baltic birch marine plywood arrived and I cut the sides and keel panels.
I’m building this dinghy for the grandson of a friend who donated the shop space
I’ve been using.
Zest 14’
Re: Zest 14’
Pictures are not showing up for me
Re: Zest 14’
Hi. Sorry that was weird how the pics disappeared. Fixed.
Everyone seems to be waiting for some deep thought or emotion
Someone to get the devotion of what they do
Re: Zest 14’
Much better. That is a nice thing you are doing for your friend and his grandson.
Re: Zest 14’
I went out to my workshop today. Painted the first coat of polyurethane on the Quattro 16,
and made some progress on the Zest.
It’s starting to take shape. This is a dry fit, I think the shop is too small to build it inside of.
I’ll move it to another section of the workshop with a bigger doorway.
Re: Zest 14’
Interesting how winter passes, bringing ideas of how to improve projects, at a time when you can do little.
I was working on an idea for the mast.
The Dinghy mast sitting on the catamaran.
I haven’t seen this being done. My tubing has a max length of 2.5 meters (8 feet). The mast for this dinghy needs to be 6 meters. I found some aluminum pieces that will sleeve together. The larger piece is 65 mm outside diameter and 59 mm inside; 2 meters long. The smaller piece, (insert) is 58 mm outside diameter; 60 cm long. The two pieces sleeve together but still quite loose, will wobble and vibrate. I tried some coats of water based polyurethane to fill the gap. I fitted 2 2 meter lengths together. I thought they would slide apart later. The plan worked better than expected. The 4 meter length seems to be inseparable. I was just barely able to squeeze the 4 meter length out of the basement. This was last winter. Using PVC tube for sailways, I’m using epoxy mixed with wood flour to stick the PVC and aluminum together.
I read that PVC and aluminum don’t stick together well. This is correct. After testing I find that epoxy mixed with wood flour, I also used silica sand; work very well.
Aside from this I am almost finished the Zest hull. Still need to paint this back part, and paint the wings that fit on the sides.
Re: Zest 14’
Nice improvisation for the mast! Looking forward to seeing the build progress - I'll be following along.
Good luck,
Mick
Good luck,
Mick
Re: Zest 14’
Inkeeping with the concept of the 50 foot boat. It looks not bad from 50 feet.
I still need to do some work on the mast. Rudder has been made and needs the rudder stock and tiller,
Wings need to be painted. Some touchups on the paint job. Rigging. Sail is ready to go.
Re: Zest 14’
The PVC tube as form for the sailways seems like a big fail. The PVC by itself of course is not strong enough.
I failed at wrapping FRP around the aluminum tube. I cut small 25mm diameter aluminum tube, using an angle grinder.
I have a slot from end to end, widened to 4mm and ground and filed smooth. The inner diameter is 17mm and the sail slides smoothly from end to end.
Re: Zest 14’
Users browsing this forum: Ahrefs [Bot] and 0 guests
