BarraMan's Mangusta 21 barraboat in Townsville, AUS
Re: BarraMan's Mangusta 21 barraboat in Townsville, AUS
Post by Fuzz »
I just learned the sound of glass meeting rock at 30. In case you are wondering it aint pretty. :help:
BarraMan
Post by BarraMan »
Fuzz wrote: Sun Aug 20, 2023 1:19 pm I just learned the sound of glass meeting rock at 30. In case you are wondering it aint pretty. :help:
The sound of skeg on rock is not pretty either! 8O :help:
Post by Fuzz »
In my case I am sure the skeg made noise as it departed but the sound of ripping and tearing glass drowned it out. :oops:
BarraMan
Post by BarraMan »
Fuzz wrote: Sun Aug 20, 2023 9:08 pm In my case I am sure the skeg made noise as it departed but the sound of ripping and tearing glass drowned it out. :oops:
Ouch ! :help:
BarraMan
Post by BarraMan »
I've finished the repair to the keel rub. :D Will see how the Keel Guard fairs on my roller trailer! :doh: It is straight although it doesn't appear to be in the pic - just the angle!
Seven years of accumulated Northern Territory red dirt on the trailer is pretty obvious. Maybe I'll get under there with the pressure washer. A job for winter 2024 - put the boat on hard stand and dress the bottom!
Next job for now - lift the motor off, install new house batteries and service a couple of pumps!
Post by Fuzz »
Why are you needing to pick the motor off?
BarraMan
Post by BarraMan »
Fuzz wrote: Tue Sep 19, 2023 2:53 pm Why are you needing to pick the motor off?
Good question! :D
Under the rear casting deck I have:
Three batteries (Start and 2 x house)
Three pumps (for the 2 livewells plus 1x aerator
Three chargers (AC mains to 12v DC, 12v DC to 12v DC, 12v DC to 32v DC)
Four master switched
Two sea cocks
Its a bit crowded in there!
I can get at most of it from the front but its a bit of a hassle. I can't get at the two livewell pumps from there.
Fortunately I have a panel at the rear that I can access from the motor-well and remove.
I have an engine crane and a motor lift ring, so remove 4 x bolts and pull the motor out of the way without disconnecting anything is the easiest way to go. :D
I'll take some pics!
cape man
Post by cape man »
That's what I was assuming as well...
BarraMan
Post by BarraMan »
OneWayTraffic wrote: Sat Aug 19, 2023 6:53 am I'd rethink that keel guard idea.
OK - so you were right! Keelguard needs to come off! :D
Post by OlivierP »
Just wondering, could you just use a shorter keelguard to protect the bow in front of the roller ?
Building C17: app.php/gallery/album/262
Built canoe, GF14, Devlin Bella 16.
Sails a 30ft Wrighton Biloup sailboat.
Users browsing this forum: Bing [Bot] and 1 guest
