Project TW28
Re: Project TW28
Putting in the roof insulation
Re: Project TW28
Refurbished the hatches and replaced the acrylic with 8mm toughened glass the only problem now is internal condensation so will fit plastic inside as secondary glazing.
Re: Project TW28
Some work done over winter seems to take forever. Head lining fitted makes it look so much better. Have got to take a break now had a melanoma removed from my back and Doc said no work for a month suspect I will be starting back before that
Re: Project TW28
I hope the melanoma removal goes well!
Your latest images are not showing for me, but I'm sure your work is as good as everything else you've done.
