Here are some pics.
Hope this worked.
http://gallery.bateau2.com/thumbnails.p ... y&uid=3526
TW28
- Lackofdistinction
From the study plans:jasonmcintosh wrote:I'm still curious about the keel.
How big of a prop goes on it? Isn't the keel's width pretty wide and will interfer with the water flow around the prop?
Jason
"One particularity of this design is the relatively wide box keel somewhat in the style of the Jersey skiffs. W. Atkins was a great believer in that feature and we have used it on long range sailboats between 32 and 65 feet.
That keel is a NACA profile and has very little drag. It is easier to build than a keel with outside ballast and allows us to install the engine very low. This gives a shallow shaft angle which is more efficient and the low engine installation angle gives better lubrication, extends engine life. Plus, it lowers the engine weight and gives easy access to trim ballast.
Access to the shaft coupling and stuffing box is also much easier than on most boats."
JG
Hi Jason,jasonmcintosh wrote:I'm still curious about the keel.
Jason
I brought a Vetus 42hp and requested Vetus to specify prop size and pitch. They came up with a 18" dia prop with a 11
deg pitch. They also suggested that a cruising speed of around 9kn would be achievable based on the hull design. 7kn or 9kn I don't care, I'm not in a hurry.
As for the keel width the boys from Bateau used a NACA profile which is also used to design rudders. After a bit of research I came to the conclusion that it acts a bit like a wing on a plane. Although it doesn't create lift it does create a push effect as water passes over the widest part of the keel resulting in very little drag. As this design (NACA) is not new I feel confident it won't interfere with the flow of water around the prop.
Macca
The profile looks great to me. What I was wondering about is how wide the keel is just infront of the prop. I was thinking that it continued to be wide all the way back and your pictures didn't show it from an angle so I couldn't tell. But the study plans show some framing that has it narrowing again before you get to the prop. I'm not questioning the plans so much as trying to understand the boat.Macca wrote:As for the keel width the boys from Bateau used a NACA profile which is also used to design rudders.
Looks like you're doing a fantastic job. Please keep the pictures coming, I think we all REALLY appreciate them. I'd also love to hear about how you're handling the size issues in building a very big boat. Can't wait to see how you flip it.
Where do you plan on using it? Any lengthy voyages planned?
Jason
Hopefully fishing from my GF18
Users browsing this forum: Amazon [Bot] and 8 guests
