After 2 1/2 years my xf is ready for the water. I posted a few pics of her on the trailer. Hopefully I will get some decent shots of her on the water.
Everyone who has seen this boat is awestruck on the design. She looks like she will float on air.
News at 11
Hunch's XF20 Launched
HUTCH,
Man really sweet looking boat. That topcoat should be very easy on your eyes, mine was just about the same color and stayed cool to the touch on the hottest of days.
On a sep note, would you have a picture of your braces under the gunwhales or a discription. Mine are going to be 10" or so and I have yet to figure out that part. Thanks for any help.
CONGRATS AGAIN!
CONGRATS AGAIN!
Launched the old xf and christened her "Runamuck"
That 110 Jonnyrude is more than enuf power but between the 300 pound motor and the 65 pound Detwiller she still floats in 3" of water but without my fat ass in it and with the 35 live well empty.
She handles more like an air boat even with the keelson and 4 full length runners bolted to the bottom. Slippery as hell and windage at slow speeds coming to the docks is tricky.
The tunnel is raising a good size hump and is working fine.
I would say it is properly designed and proportioned right.
The Detwiller jack plate is an absolute failure. The lower cross bar catches the hump of water coming out of the tunnel when lowered all the way down. This cross bar at the lowest point rides about a inch or so above the tunnel. Forget about a good hole shot.
With the plate raised about 2" there seems to be clean water under the plate but it will cavitate badly above 4800 rpm. At 4800 my best guess at speed is 25+ A larger, deeper and cupped prop is in order. She should top out at 35+
She also cavitates in a turn at speed.
The water pressure is fine with the plate raised the full 6"
So I need to re-think this jack plate. I may attach a baffle that extends from under the plates bottom cross bar to the transom. This may prevent the leading edge from diggin into the hump.
The bar is the silver plate to the lower right of image.
If jury rigging the plate don't work its back to the drawing board. Perhaps a Bob's jack plate is in my future. The Detwiller is built like a tank and rated to 300 hp but it's not meant for tunnel boats.
The hull is a absolute dream to fish. Stable as rock. A very very dry ride. A little hull slap but not too bad. Jumped a few power boat wakes and she handled them well. I'm anxious to see how she will handle a steep chop in the bay when it kicks up. Should be a fine boat for Florida Bay once I iron out the prop and cavitation problems.
Posted a cpl more pics on the gallery
All in all it was a good sea trial and a good day
Tight lines.
Hunch
Tight lines.
Hunch
The side gunwales braces are made up from 3/4" 1 1/4" mahogany on 12" centers. butt jointed, screwed and epoxied to a 3/8" x 1 1/2" white oak sheer clamp and 3/4" x 4" mahogany rail. Covered with 3/8" AC plywood and 8 OZ cloth as are all the decks. Epoxy coats all the plywood inside and out.FLYonWALL9 wrote: On a sep note, would you have a picture of your braces under the gunwhales or a discription. Mine are going to be 10" or so and I have yet to figure out that part. Thanks for any help.
CONGRATS AGAIN!
That top coat is Benjamin Moore Iron Clad. Oil base satin exterior enamel.
Good old metal paint has worked for me on all my fishun' scows.
congrats on the boat man! she is a beauty!
by the way isn't that shot next to the dock in your gallery taken at gilberts in jewfish creek? i fish that area very often especially at night for snook!
poor fishies you are gonna be terrorizing them florida bay reds!Should be a fine boat for Florida Bay
roob76 wrote:congrats on the boat man! she is a beauty!
YUp that's Gilbert's nasty ass ramp and dock. I used it to get to Lake Surprise to wring out the boat in calm waters.
You got a good eye.
Headin to Flamingo and Whitewater Bay tomorrow for some snook and trout. Hope I don't run outa gas. This thing is a pig.
News at eleven.
Users browsing this forum: Bing [Bot] and 12 guests
