Can you explain how the scupper is going to function?
I'm also wondering about the depthsounder. What is the reason for that on a kayak?
You are a careful worker and I've no doubt you've thought this through, so I'm just curious.
PY12 - Plyak build
Re: PY12 - Plyak build
The Kayak will be a fishing kayak. The areas I will be fishing don't have a lot of cover so knowing areas where the depth changes is important in locating fish. It's pretty common to install fish finders on fishing Kayaks these days. Most of the time this involves a mount that hangs the transducer over the side, or it gets mounted in a box glued to the hull. I'm trying to design a more elegant solution that places the transducer below the water line. The cable will enter through a cable gland in the enclosure I designed.
As for the scuppers I will be mounting two drain fittings in the sole. Those fittings will get connected to hoses that run into a fitting mounted in the enclosure. I will show pictures of this as I get to it.
Cool. We see a lot of people fishing from kayaks in Tomales Bay and I've been noticing ever-increasing high-tech gear. I'll have to check out what they're doing for depth.
Tony
Anyone know how much foam is needed under the sole? I don't see this listed anywhere in the plans.
It's up to you.
You don't have to add foam, the hull material floats but it is a good idea to add some foam to provide extra buoyancy.
In that boat, I would put some foam in the ends.
A 2 gallon kit expands to provides 480 lbs of buoyancy but it is difficult to pour that much foam in the small Plyak.
I would buy one or two quarts kits, each will give you 120 lbs flotation.
Does this mean that point 11 on page 4 is not true? It states: 11. Buoyancy foam under sole, required.jacquesmm wrote: ↑Tue Oct 17, 2017 1:31 pm It's up to you.
Snail, this is in the study plans for the PY12 and may also be in your plans: "The cockpit sole and the foam under the cockpit are part of the structure."
It is required.
I reply from memory. In most of my designs, foam is optional but in some cases I use the foam as part of the structure.
If the plans say to use it, use it.
I don't know, I may have calculated it but I am not in the office right now.
It will be at least 2 x 2 quarts kits and a two gallon kit is a better deal than 3 qts. I would buy a 2 gallon kit.
