There isn't glass on the underside of the gunwales, the inside of the sides, or the outside of the console. Larry coated everything with epoxy, but didn't use glass in a lot of the places the plans did not call for. All the seams and connection points are taped, but the surface was epoxy, primer, and paint. All the wood looks solid, including the stained area on the inside of the port transom that comes up above the baitwell. That's why his Dory came in hundreds of pounds lighter than mine!!
After sanding, everything that asks for it will be getting multiple coats of new epoxy before any new glass, primer, or paint is applied. Found an area on the back of the T-top that they missed with the pressure washer, but I've told them the next step is to remove all the hardware from the gunwales and start sanding. I'm trying to wrap my head around a way to sand and repaint the console without removing tha gauges, switch panel, etc. I have a small corner sander and the new multi tool has a sanding attachment. I'm less interested in them getting everything faired and shiny as I am making sure the wood is totally protected. The interior may very well end up being "work boat" finished...
Found a piece of hose that will extend the fuel line out over the back of the transom so will start siphoning the fuel out this weekend.
No Excuse
Re: No Excuse
Re: No Excuse
Craig if you want to just fix that scratch on the port side, I recall that Larry used System 3 Vachon Gray for his exterior paint. You are making good progress on her. A couple of other things that you have probably found that I did not get to explain, on the red buoy with the keys is both the trailer lock and the starter key for the boat.
Re: No Excuse
Craig, what weight of cloth do you estimate that Cracker used on the gunwales?
Tom, the exterior paint on No Excuse is white Sterling.
Richard
viewtopic.php?f=12&t=62146
Re: No Excuse
Given how meticulous we all know Cracker Larry was in the construction, I, for one, would appreciate a separate thread about what held up best and weathered well since(and maybe what didn’t). I’m thinking, if his work with “x” didn’t hold up as well, there’s no chance mine will.
For instance, this comment caught my eye: “ Good news is he used Sterling on the outside and that all looks great except for a big scratch on the port side above the style line”. Maybe that suggests Sterling is the way to go. (?)
Jbo
Jbo
Re: No Excuse
Richard
Re: No Excuse
Nope it is to gray to be white Sterling that is what he used on the interior as Sterling was cheaper at the time and is no longer sold in the store. It caused him nothing but problems as can be seen on how it is coming up for Craig. TomAripeka Angler wrote: ↑Thu Oct 13, 2022 7:17 pm Craig, what weight of cloth do you estimate that Cracker used on the gunwales?
Re: No Excuse
TomW1 wrote: ↑Thu Oct 13, 2022 8:06 pmNope it is to gray to be white Sterling that is what he used on the interior as Sterling was cheaper at the time and is no longer sold in the store. It caused him nothing but problems as can be seen on how it is coming up for Craig. TomAripeka Angler wrote: ↑Thu Oct 13, 2022 7:17 pm Craig, what weight of cloth do you estimate that Cracker used on the gunwales?
Tom, the interior of No Excuse is S3. The hull exterior is Sterling.
Richard
Re: No Excuse
That is counter to what Larry told me if I am remembering correctly, maybe you could show me something that proves that. Also, the interior was light gray,the Kiwi Grip was gray also, Larry hated a white interior. TomAripeka Angler wrote: ↑Thu Oct 13, 2022 8:37 pmTomW1 wrote: ↑Thu Oct 13, 2022 8:06 pmNope it is to gray to be white Sterling that is what he used on the interior as Sterling was cheaper at the time and is no longer sold in the store. It caused him nothing but problems as can be seen on how it is coming up for Craig. TomAripeka Angler wrote: ↑Thu Oct 13, 2022 7:17 pm Craig, what weight of cloth do you estimate that Cracker used on the gunwales?
Re: No Excuse
Richard is right. Grey S3 interior and white Sterling exterior. Can't prove it in writing as Larry's gone and he deleted the original build thread after having an argument here.
Re: No Excuse
The cloth looks like 6 ounce.
