Today's vLog goes live on YT at 11:00 EST. You can see it here early. https://youtu.be/mn6XbuMWZHM
We had some good weather followed by a flash freeze! As some of you South of the Border (Can/US) in the NE States go hammered too. Temps are looking better in the weeks to come, maybe we've turned the corner if Mother Nature can get her sh*t figured out.
Standby....
knottyBuoyz III The TW28 Project
- Knottybuoyz
Re: knottyBuoyz III The TW28 Project
Yours Aye! Rick
- Knottybuoyz
Today in the boat shed. Still cold and damp. Did a lil' wood butchering on the carcass for our storage space.
Levelled up.
Cleats going in. Just dryfit for now. Sort of a proof of concept thing I guess. Got no experience building stuff like this. Didn't want to do drawers. We'll use plastic totes.
That's it for today. Cheers!
Levelled up.
Yours Aye! Rick
- Knottybuoyz
Yours Aye! Rick
Nice work Rick!! Jeff
Mass of wires comming to this location.
- Knottybuoyz
Probably more like a "Mess of wires" narfi
Yours Aye! Rick
- Knottybuoyz
Latest vLog update is live on YouTube now.
[youtube]https://youtu.be/4xR9_BUsEWY?si=h6fmyOsWqSu4SV2F[/youtube]
Yours Aye! Rick
Have you made decisions on electronics and electrical systems? I've been doing some retrofit with lithium and solar on my catamaran and the more I read and learn and do, the more I'm convinced if I was starting from scratch I would go with 48v. Smaller and cheaper electronics and much smaller wiring which is not just lighter, it's much easier to fit, route and work with. (I've got a couple of pretty good runs of 4/0 cable because I'm working with 12v.
- Knottybuoyz
I designed a full elec system when I was working with some Elec Engineers at Coast Guard. That was a long time ago and obviously what was done is out of date. i have some experience with LifeP0 and solar etc. rewiring our RV. I'm invested heavily in 12 volt equipment, Renogy, and will have to follow through with that. The boat will actually have two separate elec 12 volt systems. One for house loads and one separate for the windlass and bow thruster. The house batts are 2x 200 AH Renogy LifePo4's and the Windlass/Bow Thruster will run off of a single 200 AH AGM because of the higher demands. Wire runs will be short. The batts will be located very close to the loads such as the Inverter/MPPT controllers, DC/DC charger & auto transfer switch etc. I should be somewhere near installing those systems this fall. *Fingers Crossed* Solar so far is 2x 135 watt mono crystal panels and 1x 100 watt flexible for the AGM.narfi wrote: ↑Fri Mar 08, 2024 12:06 pmHave you made decisions on electronics and electrical systems? I've been doing some retrofit with lithium and solar on my catamaran and the more I read and learn and do, the more I'm convinced if I was starting from scratch I would go with 48v. Smaller and cheaper electronics and much smaller wiring which is not just lighter, it's much easier to fit, route and work with. (I've got a couple of pretty good runs of 4/0 cable because I'm working with 12v.
Still an unimaginable amount of work to do.
Cheers!
Yours Aye! Rick
Sounds like a well thought out system! Will you have a start battery as well or will the wireless battery also be here for the engine?
I think I remember you were going to use a small gas generator. Are you planning on utilizing an oversized alternator for the house bank as well?
Users browsing this forum: Yandex [Bot] and 0 guests
