It actually looks pretty good. Doing all the laminations in one day saved you a lot of grinding work and makes for a better laminate.
The extra layer of tape around the transom is going to make the fairing more difficult. To get an idea of how much you need to fair. take a long straight edge (a 4' level works well) rest it on the keel with one end on the transom. You can now see that there is a hook that needs to be faired. the last 4 feet ors o of that boat need to be a straight run (or close to straight as reasonably possible)
Same thing applies for the overlaps of Biax cloth around the bow – there is a lot of build up there.
You can beef up laminations on the inside without making for a bigger fairing project. Build ups of glass on the inside are easy to deal with. If the build up of the overlaps is in a hidden area like the inside of the transom then there is no real added faring work
Those small air pockets are no problem sand/grind then out and fill then with thickened epoxy
I recommend making/buying a long faring board.
FS14 build saga continues......
Joel,
Thanks for the reply.
The spot on the side that is not laminated I was going to grind off and cover the whole edge of the overlap with a strip of glass but if you think I can just fill it with thickend epoxy that will be what I will do.
I already purchased the fairing board and 60 grit sandpaper from you all.
Do you think that the laying of the glass on different sides will effect anything? I can feel the longitudinal threads more on one side of the hull.
Can I lightly sand the bottom prior to fairing to get off the rough edges without hurting the glass?
Derrick
Derrick
I think that looks like pretty nice work to me. When you say delamination, are you sure you're talking about delamination or just a cloudy finish? Is the fiberglass actually lifting away from the plywood or previous layers of glass? Or are you just talking about the way it gets sort of milky looking? In my experience, that's something that happens from overworking the glass and resin sometimes, but it doesn't mean it will delaminate.
I think it looks pretty darn good.
Thanks for the comments. I have one spot that is delaminated on the right side. It is about 3 inches in diameter. It is near the rub rail edge and I must have missed it when working in the resin. You can see it in the pictures as a small circle. I may grind it down and patch or just fill it with resin. I have not decided which would be the best way to deal with it.I think that looks like pretty nice work to me. When you say delamination, are you sure you're talking about delamination or just a cloudy finish? Is the fiberglass actually lifting away from the plywood or previous layers of glass? Or are you just talking about the way it gets sort of milky looking? In my experience, that's something that happens from overworking the glass and resin sometimes, but it doesn't mean it will delaminate.
Joel,
Thanks for your input. I can use either the orbital or the fairing board but am a little scared of the orbital as I can get carried away with that thing and do real deep damage.....
Derrick
I did some work on the boat. I was able to add two layers of rub rail to one side. I could have done more but had to wait overnight for the expoxy to dry before adding the second one. I need to remove the clamps tonight. I may have time to add the third layer tonight and be done with one side.
I will put some pics up soon of all the clamps used to just put on one rub rail layer.... Home Depot loves me!!!
Derrick
Derrick
Thanks for the suggestion. I have about 60+ of the less then 1 dollar clamps and unless I build a much bigger boat will not be needing more for the time being.....Daddy wrote:Derrick, in case you need some more you can make lots of "clamps" for little or nothing by using split rings of pvc pipe. There are pictures somewhere in the gallery of glueing on rubrails using these clamps.
Daddy
I do have the plans for the PH18 but decided to build this one for now. I'm enjoying watching your build. I am going to be fairing soon and you make it look way to simple.
Derrick
Users browsing this forum: Google [Bot] and 7 guests
