kiwi wrote:OK! We need some input from Toni_V on the FL26 layout now - maybe we can get a sauna in there? So then the showers outside would be at just the right temperature!
Tony
Heh, I don't think there's enough height
. A sauna would be must have on a boat like that - I don't like swimming in cold water.
However It's pretty freshing to dip to ice hole in winter. Nice feeling of warmth when you came back up
And thank's for the kind words earlier, I like to fiddle with designs but I'm not really a designer.
About the hull speed issue - it's not really an issue in here. The traditional two pointer boat is called "fiskari" and they can go nive speeds with little effort.
Usual measures are:
-Lenght 26-33 ft
-Width 6.5-11 ft
And they'll be powered by 20-100 hp engine which will give 10-18 knots of speed. At 60 years ago the same models were powered by 1-2 hp engines to go at hull speed.
There's no magic, hull is rockerless, narrow at waterline while wide an top. It's going nicely as long it's kept light and without heavy top structures. Nowadays the same boats are mostly heavier with cabins and wider to give more stability. So slower.
If Froude would have measured these boats too, I think there wouldn't be hull speed concept like we know these days...
