Various nice Jaap, job well done. On to the next step!
FL26 build in Friesland
- AD16 The Opportunist
- chicagoross
After the flipping it was time to cleanup the shop a bit and we went for holiday with our launch and a tent. Very good time with the family.
But now back to work and boatbuilding. I removed all the molds and cleaned up here and there, but to my surprise the bottom is by far not flat.
I think, that the jig is too small and too much weight is on the outside, which causes the middle raising at least an inch. The bottom is off course not a composite yet and after some discussions with friends we think that the solution in picture 2 will do. I was glad to discover this before glassing the inside. I did not want to build the first fl26 with a small tunnel hull
Most of the designs here have more or less a V-bottum, but nevertheless, keep on measuring and checking.
jaap
jaap
After carefully set the bottem panels flat, I started glassing the inside. Outside was easier then inside, which I didn't expect. The bottem panels are difficult to reach; they need 2 layers biax and working wet in wet is not possible for me. Even doing it in smaller part, I crawled around in wet fabric now and then; keep in mind that I do everything on my own with only 2 hands. There was just enough wide fabric and I had to use almost all the left overs, which gives it some kind of mosaic look. Not my favorite but it is more then strong enough due to the wide overlaps. Maybe spended a little to much on the skeg.
After a touch up with the sander I put the stringers and bulkheads in the hull. A great moment for me after the fight with fabric, resin and the clock.
A few small corrections were needed with the jigsaw but it all fits quite well and looks fantastic (to me!). Standing in the boat and having a good impression of dimensions, took my fantasy on a walk. We were already sailing. Back to reality, everything is spot glued and it is time to clean up the shop a little.
jaap
jaap
- peter-curacao
Jaap,Jaap wrote:After carefully set the bottem panels flat, I started glassing the inside. Outside was easier then inside, which I didn't expect. The bottem panels are difficult to reach; they need 2 layers biax and working wet in wet is not possible for me. Even doing it in smaller part, I crawled around in wet fabric now and then]
Just an idea
Although I'm not at that stage I've been thinking about that, and I was thinking of wearing these things
I think the little holes those things make will fill up again, just like the concrete floors, were those "shoes" are intentionally made for.
Btw I think your work is looking good
Peter
The inside lamination of large hulls is done either with a hanging scaffolding or one side at a time.
For an amateur, it will be one side or one length at a time.
@peter-curacao, kinky shoes!! Would you use them on a teak-deck as well? Just read on the internet newspaper about small tornado's in Curacao. Is there any damage in your neighbourhood??
@Jacques; I did the sides in 2 pieces, but that is just one layer. To use as less resin possible, the bottem panels were a little more difficult.
When you cut a large piece of biax fabric, say 3 by 12 ft, it gets very easy very out of shape, due to weigth and were you hold it.
Do you still have plans to visit the Hiswa??
jaap
jaap
- peter-curacao
No jaap I won't recommend them on a teak deckJaap wrote:@peter-curacao, kinky shoes!! Would you use them on a teak-deck as well? Just read on the internet newspaper about small tornado's in Curacao. Is there any damage in your neighbourhood??
jaap
No damage here but in the neighborhood they were it's a ravage. cars and roofs were blown away Thank's for asking
Peter
