Thanks Dave, I hope to get the stringers finished this weekend and move on to cutting out some more frames.
regards Steve.
OB17 Underway downunder.
Big day of building today, marking out stations /frames, have got them all done. Just got to cut them out.
Made a few small changes to the design just for personal preference. The side of the boat will be a bit taller...about 30mm. The Gunwales will be wider and flat/horizontal to the sole, casting deck higher and all the way to the bow. Have marked all the frames to suit.
I will post photos soon that explain. My old boat I made this way and it works well. Except it is made from aluminium (rubbish) and it is small. The OB17 is lots bigger and made from the good stuff.
Had to add some wood to allow for the alteration from the plan. Horizontal gunwales and higher sheerline.
Photo of my old boat showing flat gunwales and large high cast deck. the changes I am making to the OB17 design are similar to this. The cast deck will be 390mm from the sole.
This picture shows the modification and the raised casting deck height. Station "B"
Better laminate the transom before I cut out the hull panels.
I like to see a nice bead of resin squeeze out. I am useing a heap of screws to press the clamping board to the transom. I will remove them and repeat the process with the next clamping board.
I have checked the lay-up with a straight edge and it is dead flat.
After the transom is laminated is it best to drill out the screw holes and fill them or is it OK to just fill them as they are
Is that enough screws ?
- Lucky_Louis
Looks like you could use a few more screws..... I think I used 4 in total and a couple of 5 gallon pails...
You don't want too much pressure when glueing with epoxy, just enough to expel air. The ooze looks good.
Just fill the holes, no drilling rqd. What are you using for filler in your glue? It should be wood flour and that doesn't look like wood flour. Microballoons are too weak for glueing and Cabosil is too brittle.
OB17 Splashed June 2007
Hi there Lucky_Louis. The filler I am useing is West systems 403. It is a mixture of cotton microfibre (cotton flock) and cabosil. Woodflour is not available here. I asked the people at ATL composites (a big boat building and composite company here) what to use and they told me to use the 403. I hope that it is OK. Most of my experience with building is with composite airplanes, we call them aeroplanes in Australia. (Jabiru aircraft), they use that product as well. they also use just the pure cotton microfibre especially on the fillets. I was thinking it may be better to use that when it comes time to make my fillets. I have not used any Q-cell or microballons for glueing I know it is weak.What are you using for filler in your glue? It should be wood flour and that doesn't look like wood flour. Microballoons are too weak for glueing and Cabosil is too brittle.
Are there any other alternatives you are aware of
I think I might get some microfibre flock from the aeroplane people just in case.
- peter-curacao
Aren’t there any carpenter factories in your neighborhood to get the wood flour? I always get it there and best of it it’s for freesideslippa wrote:The filler I am useing is West systems 403.
403 is good for laminating, for your (bonding)fillets I would use 406
Ciao
Peter
I though my lamination might be overkill. I did try to do it with weight by placing five tractor batteries on it but I got a bit paranoid because I was not getting a good ooze and the weight made the lamination and workbench ( which is quite solid) flex a bit. Only a bit, say about a milimeter I think that is about 1/16 in inches.I think I used 4 in total and a couple of 5 gallon pails...
Anyhow I got worried so I screwed it together. Because I have never built a boat before I do not know how carefull I have to be with stuff like that. I literally spent hours and hours just on getting the stringers dead straight...and they are...now.
I have been infected with a obsesive compulsive perfectionist Gene. It is a curse sometimes
Slippa
