Panga 22 Curacao
- Fonda@kauai
Re: Panga 22 Curacao
Looks good Bart Me likey the stitch and glue leaning post. Where did you decide to run your scuppers? I'm still debating wether to run them out the stern lockers or through the motorwell just on the other side of the motorwell dividers
Aloha
Bart, it looks great man!
Those gunwhales are smooth, console and leaning post look great
whats the holder in the motor well for?? flag pole, green stick, center rigger???? just wondern'
Daniel
Daniel
Bart she sure looks sweeet! Won't be long till you launch her!
C17ccx, Mirror Dinghy
She's looking great. Like the console and leaning post. They are made for each other.
@fonda: im running my scuppers tru the motor well
@colonialc: the pole is to do some surfing behind the boat if she is fast enough
i have a question about the scuppers. These are the scuppers i bought
I have my doubts about the scuppers because the transom in on a angle the ball is not above the hole but at the end of the scupper. anyone experience with these scuppers? also what kind of hole should i make tru the transom i was thinking about putting in a pvc pipe wit a diameter of 4cm does that sound oke?
thanks in advance
thanks in advance
- peter-curacao
Bart I know this kind of scuppers a friend of mine had them on his Dusky, they work oke i.o. the ball will close of the hole when water enters because of driving backwards for example,although because of this ball they drain a little slow did you buy those at the Freedom machine? that shop also sells the rubber flap scuppers i think I would trade them in for those, but first wait for the opinion of others.
Your boat is looking great btw can't wait to see it drive the turquoise
Bart/Peter, Larry and I will both disagree with you on those scuppers, as far as we are concerned they are not worth a d***. Both of us had wet feet to often with them. The ball wil get off center and not seat or a little peice of junk will get in there and they won't seal. They just don't work right more than they work wrong. There was an other scupper discussion a couple of weeks ago when we discussed these.
Bart yes exchange them you'll be happy you did.
Look for something like this http://store.hamiltonmarine.com/browse. ... ,8104.html and these even have a shim so they set straight up and down or you can build one http://store.hamiltonmarine.com/browse. ... 15293.html
- peter-curacao
Tom I think we do agree I wrote "they work oke i.o",oke isn't good or great I also wrote "that shop also sells the rubber flap scuppers i think I would trade them in for those"
Peter I don't like a plain rubber flap either they tend to get twisted out of shape over time and not seal. Want something I can count on in a following sea or backing down on a fish to seal up.
- peter-curacao
We don't have that much choice here Tom It's either trade those in for those rubber flap things or buy others over the net and stay with those or trade them in for a complete different item
Users browsing this forum: Ahrefs [Bot], Yandex [Bot] and 12 guests
