MICKS FL12 BUILD
thanks dogfish, it's nice to walk in to the garage and see something that looks like a boat, instead of a stack of cut up plywood, people are starting to take me a little more seriously now!
part of me wants to slow down and not finish this one too quick and part of me is itching to get to the next one!
thanks for the reply, Mick
- Hope2float
- chicagoross
Joel, I am assuming that you drill the holes in the rub rail slightly larger than the screw so the rail can float on the screw so you don't squeeze out to much glueshine wrote:you can also use drywall screws while the epoxy glue cures. Fill the holes later with epoxy.
I did not use any clamps on the two layers of my FS17 rub rail ...
Just be careful to not over tighten, or you will be left with flat spots - same applies for clamps
