Well, I started fairing with Quickfair today......wish I would have bought the 1.5gal kit instead of the 1.5qts. I love this stuff.
I can offically call this a boat now.....
Quickfair is great.....
I wish I had enough to get the bottom completed.....
OB17 Build in Oklahoma
Re: OB17 Build in OKC
viewtopic.php?f=12&t=19337
OB17 - Will White, Broken Arrow, OK
Looking good. Just keep sanding. Sanding, sanding.
- Lucky_Louis
Yup - it's great stuff, costs a little more but my time and frustration is worth something too
A little tip for the the future - if you do a quick sanding while the epoxy is still green, you can knock down the selvage (the threads binding the biaxial strands together). That will save a lot of QuickFair. I can tell you didn't because the lines showing in your glass run parallel to the keel instead of 45°. Just take care not to damage the glass. And remember - at this point, you're not sanding, you're fairing. The goal is fair panels and covering all the glass with fairing compound. The only abrasive touching the hull as this stage should be attached to a long board otherwise you'll just end up following the existing contours wasting time and materials. Keep a long straight edge handy, keep laying it against the hull sides and bottom to look for high spots, hollows, rocker and hooks. The most critical surface on your boat is the last 5-6 feet of the bottom to the transom. You should see QuickFair building up on both sides of the original panel splices and beside the corner tapings.
You're doing great. Before you know it, you'll be splashing primer. That's when sanding serious starts.
OB17 Splashed June 2007
So should I sand down the threads binding the biaxial strands together(selvage) before I continue to fair? I want to make this as painless as possible!!!Lucky_Louis wrote:Yup - it's great stuff, costs a little more but my time and frustration is worth something too
Thanks,
Will
If you can Will where you don't have any QF and havn't put any fairing material. It will go easier for you as you go along. Looking at it you have already filled in between the salvage and it won't be worth your time.
C17ccx, Mirror Dinghy
Just wondering if I screwed up..... So just keep on fairing and sanding....and sanding....and sanding.....
I'm out of town until next Friday and can't wait to get back and get at it again. This is really quite addictive.
Nope no screw up you'll just use a little more fairing material.
TomW wrote:Nope no screw up you'll just use a little more fairing material.
Good thing I just bought 1.5gal of Quick Fair today. Should be there on Thursday.
Fairing is torture, but well worth it. I spent more than 120 hours fairing my hull, lost a few pounds and gave my cardio vascular system a real treat All well worth it. I agree with LL. Use only a long fairing board (torture board) keep filling the lows and wearing down the highs, and your best friend is a good straight edge about four foot long.
Just keep going till it is perfect.
My fairing tools
My trusty straight edge, I use this thing all the time, it is very handy for all sorts of jobs, but really good for checking fairness especially when rested on one of its corners.
Slippa
My fairing tools
Slippa
Or spend 60 hours doing it and use the other 60 for fishing. Course it won't look as purty.
