fishin' wrote:drawings show one layer of 3/8 on one side of the daggerboard and two layers of 3/8 on the other side. That is a problem because I don't have any 3/8 since the bom only calls for 1/2 and 1/4. Should I just make out of 1/2". The problem then becomes that the mast step area becomes to wide. Using 1/2 for the daggerboard trunk the mast step ends up at 2 3/4' instead of 2-1/4 I guess I could just block it back down with a piece of 1/4" on each side? keep in mind when you look at the measurements that the 1x1 block near the daggerboard needs to be more like 1-1/4" because the daggerboard needs 1/8 clearance on both sides according to the notes on that page.
found the same thing on my plans....even more so when I put into cad
here is a rough mock up of what I planned.
was going to get some 3/8 scrap from someone
since you dont need a lot and buying a whole sheet for these 2 little pieces didnt make sense
Bradley
yellow 3/8 ply
black is 1/8 gap around the board
purple is 1/16 or so for glass and resin coating
