Getting closer, got my light installed today. Have most of what I need, just waitting on another shippment and it'll be wrapping time.
OD18 in Arizona..SPLASHED..
Re: OD18 in Arizona..SPLASHED..
Completed: FL14, OD18
- timmydafool
So where did you get your design from? what kinda drying motor and chuck did you go with?
it looks awesome I've been wanting to do this for some time now.
-tim
-tim
OK, Not perfect and I'll probably redo it as I move up the rod and get better (Hopefully )
But thought I'd post a picture to show off my first wrap
- gstanfield
I like it
Current build: FL14 (+10%)
Thanks George, I do believe the hardest part is this first learning curve, it's a real bitch and with my aging eye's it's even harder.gstanfield wrote:I like it
Building my own rods is a hobby i never had the time to commit to it as much as I would want to, read alot about it, just wish if i could practice it enough.
really like your wrap, and your wrapper , does it have various speeds?
That ain't a bad first wrap, it takes some practice and developing a feel for it. You'll probably want to strip it and do it again before you are finished. My problem is only building 1 or 2 rods a year, I forget what I learned last time and have to learn it again
Larry, are you power wrapping, or spinning the rod by hand? I usually just hand spin it for the wraps, the motor makes me screw up even faster I just use the motor for drying.
Thanks, and not various speeds, only one speed, slow for drying.really like your wrap, and your wrapper , does it have various speeds?
Larry, I'm spinning the rod by hand, time consuming and tiring but I'd really screw it up with a power wrapper. I'm not in a hurry anyway so it don't matter much. Just use the motor for drying.Larry, are you power wrapping, or spinning the rod by hand? I usually just hand spin it for the wraps, the motor makes me screw up even faster I just use the motor for drying.
I took the guide off and finished doing the under wraps and put a coat of epoxy on that, tomorrow I'll start wrapping the guides again with Black Thread size D
Those are looking good. You might want to use a color preservative on the threads before you epoxy them, to keep the colors from bleeding through or fading, although on the last rod I built I used several coats of color preservative and it's already fading. Doesn't matter much I reckon. Metallic colors seem to go the fastest in the sun.
Are you sure? Those under wraps look like size A? Size D might look like rope on top of them. If you ain't in no hurry, it would look better wrapped in size A Just saying...tomorrow I'll start wrapping the guides again with Black Thread size D
Well it ain't perfect, but it's a great rod. Don't plan on selling them, so I only have to make myself happy. I used the Eva Foam Grips because they are tough.
Anyway here are some pictures:
