Majorgator's XF20 - SPLASHED :)
Posted: Sat Jan 16, 2010 8:20 am
by majorgator
I decided to move by build thread to this section, as its more appropriate. The link to my original thread and all the discussion with it is:
http://forums.bateau2.com/viewtopic.php?f=2&t=16512
The photo gallery can be found here:
http://gallery.bateau2.com/thumbnails.php?album=963
The rest of the build progress will be posted under this topic.
Re: Majorgator's XF20
Posted: Sat Jan 16, 2010 8:25 am
by majorgator
So the bottom is completely sanded, and ready to be taped off. As you'll see in the pics, I omitted the sides and bow transom from fairing and sanding. My plans are to paint the bottom of the boat white, then at a later date, paint the sides, bow, and transom black. I'll fair those sections once I complete the inside fiberglass work. I decided to wait because the fiberglass on the inside will wrap over the edges, so it will work better for me to finish the sides later.
It really makes the boat look like one complete uniform piece, which is encouraging
I guess I forgot to take pictures of the fairing process.
I was so excited when I got done sanding...until I remembered that I have to sand after applying the hi-build yacht primer
But its OK, I know that will go a lot faster than what it took after the fairing. We're getting some good temps right now, so if this continues, I may be able to start painting within the next few days. Planning to use roll & tip vs. spraying.
Posted: Wed Jan 20, 2010 8:20 am
by Zack Attack
Looks great, I think this will be the next boat my brother and I build
Posted: Wed Jan 20, 2010 8:23 am
by Larry B
Posted: Wed Jan 20, 2010 10:47 am
by majorgator
your dog also looks like he's relieved that your done sanding
It was getting late in the afternoon, so she was relieved to know that I could take a break and feed her
I think this a fairly simple boat to build, but its extremely time consuming. It just takes a while to cover all that hull space when fairing and sanding.
Posted: Mon Jan 25, 2010 6:58 am
by majorgator
The second coat of yacht primer went on last night. It made a HUGE difference over the first coat. The only problem is that the white color really brings out some of the poorly-faired areas. Well, at least this is the bottom, and I now know how to do a little better when I fair the sides and deck.
pictures to come...
seth
Posted: Wed Jan 27, 2010 6:48 am
by majorgator
I have an opportunity to purchase a 85HP Yamaha 2 stroke at a really good price. Thoughts on using this for the XF20??? Too much motor?? It weighs about 20 lbs more than the 70HP.
Posted: Wed Jan 27, 2010 8:31 am
I think it would be fine Seth. It's got to be lighter than this 4 stroke 60! That's a big boat.
Posted: Wed Jan 27, 2010 8:57 am
by majorgator
Yeah, Larry, I checked on that. The 85HP I'm looking at has a listed dry weight of 248 lbs. Without knowing exactly what model Ken used on that boat, the general range I found for a 4-stroke 60 HP (using 2006 year make) is 237 to 248.
I only get a little concerned about pushing the limits of construction for this boat. I know that Hunch used a much larger, older motor on his XF20, but I'm typically seeing 50 to 70 HP motors when the sole is installed. The general design of the boat w/o the sole only considers using a 25 - 30 HP motor. Generally speaking, I'm not too concerned, but I just wanted to float the idea on the forum before I pull the trigger.
seth
Posted: Wed Jan 27, 2010 9:47 pm
by majorgator
OK, so I'm going to check out this 1995 model 85 HP yamaha on Friday. The deal is $1100 for the complete motor, wires, controls, & gauges. For an extra $100, I can get the 19 pitch SST prop. But I'm thinking that this pitch is no good for the XF20. Richard, Tom, thoughts??
Posted: Wed Jan 27, 2010 10:58 pm
by Aripeka Angler
Seth, great to see you are getting close to flipping your boat. It is looking good.
I am known for not being popular on here with my opinion, so I wil stay true to form and suggest buying something a little newer. A new Yamaha 50-70 should cost about 5k with controls and wiring. Check it out really good if you buy it. A fifteen year old outboard can be a big problem if it was not well taken care of. The boat can handle a big motor if you build it right
It might work with your prospective motor if it is a three blade, and it would probably be way too much if it is a four blade. I am not a prop guru but I am using a 13 pitch four blade prop on my boat. It has a little too much bite though I have ground it twice to relieve some of the cup.
Shot of the barge....
Richard
Posted: Thu Jan 28, 2010 5:10 am
by majorgator
Posted: Thu Jan 28, 2010 7:34 pm
I sure do like my 70 Yamaha. And it's warranty
Not that I've needed it. I can get the 70 Yamaha for 5K, without controls or prop.
Posted: Thu Jan 28, 2010 8:56 pm
by majorgator
My grandfather has a 2001 (2002?) model 70 Yamaha. I don't think they've changed that design in at least 10 years
They all look the same, everyone loves them, and they're tough. Hard to go wrong there Larry,
Posted: Fri Jan 29, 2010 4:17 pm
by majorgator
Here are some pics I took today. The bottom has 2 coats of primer on it now. After doing those 2 coats, there were a few spots that stood out and some other areas that needed attention, so I mixed up some quik-fair took care of them. Plan on sanding the recently-faired areas tonight, then put the final coat of primer on.
One particular note: So far, I've made a home batch of fairing compound with epoxy, microballoons, and silica. However, after using the quik-fair today, I don't think I'll ever make my own compound again.
Using quik-fair was head-over-heels better than my home batch in the "ease of use" category.
Posted: Fri Jan 29, 2010 4:18 pm
by majorgator
obviously, my picture size is out of whack again...
Posted: Fri Jan 29, 2010 4:48 pm
by Steven
This looks like a pretty good deal on a Yammy 90
http://smalloutboards.com/y9093.htm
Doesn't give the year.
Posted: Fri Jan 29, 2010 5:17 pm
by wegcagle
Steven, I'll bet it's a 93 based on the last 2 numbers of the picture URL. I contacted them about the 40 for my boat and it is a 01 and I noticed that was the last 2 numbers. I think they base the site on the horsepower as the first 2 numbers and the year as the last. Just something I've noticed as I watch that site often.
Will
Posted: Sun Jan 31, 2010 7:04 am
by majorgator
The 3rd (and last) coat of primer went on yesterday afternoon. It is evident to me that I should have done a little bit better at the fairing, but for the most part, it looks pretty good. The worst faired spots are on the dead bottom, so I'm not too concerned about them. I'll probably sand it down today, and get it prepared for S3 Top Coat. I think I've read every post from the last 2 years regarding whether to spray or roll & tip, even my own thread I started while back. At best, its been 50/50 with the people on this board, and I certainly do not want to start another discussion into which is the best method.
I've been itching to buy and HVLP sprayer anyway, so I think I'm going to go ahead with that notion. I'm going to try and spray the first coat, see how that turns out, then decide from there. If it looks nice, then I'll give it a shot with the 2nd coat, and so on. If it doesn't give me the results I'm looking for, then I'll switch to roll & tip. Regardless of how well it works, I want to spray the under-decks area after all the framing is in place. But if ANYONE asks, I'm buying the sprayer for trim work on my house
Posted: Sun Jan 31, 2010 10:40 am
by Steven
majorgator wrote:The 3rd (and last) coat of primer went on yesterday afternoon. It is evident to me that I should have done a little bit better at the fairing, but for the most part, it looks pretty good. The worst faired spots are on the dead bottom, so I'm not too concerned about them. I'll probably sand it down today, and get it prepared for S3 Top Coat. I think I've read every post from the last 2 years regarding whether to spray or roll & tip, even my own thread I started while back. At best, its been 50/50 with the people on this board, and I certainly do not want to start another discussion into which is the best method.
I'll watch this with much interest as I'm leaning the same way for paint. One thing to consider is the heat generated if you are using a turbine type sprayer. I'm planning on buying an extra length of hose and coiling it in a bucket of ice water to keep the temp down and prevent too quick a drying. I may still roll and tip the outside. It's really the inside with all the nooks and crannys and under decks that I can't stand the thought of roll and tip on.
Posted: Fri Feb 05, 2010 3:14 pm
by majorgator
Curious Thoughts:
What size bow eye should I purchase?
Drain tubes appear to be 2 3/8" in length. I assume I should buy those and cut them to fit?
seth
Posted: Sat Feb 06, 2010 7:27 am
by majorgator
First coat of S3 topcoat went on last night using a sprayer. I can't complain about the results too much, but with the temperature and humidity we're having right now, I'm going to go with roll and tip method today. As a result of the weather, the paint is not drying real fast, so there's not too many concerns about getting it "tipped" quick enough. I echo some of the comments I've seen on the forum about spraying vs. rolling: spraying may go quicker, but it takes a lot more time to clean up.
When I got up this morning, the paint was still a little tacky in some spots. The way I read the application guidelines, I'm OK to proceed with another coat based on the finger imprint test. Any thoughts on if I should wait until the paint cures a little more before proceeding? We're going to have great weather, cool and humid, this weekend, so I'd like to get it done in this timeframe.
seth
Posted: Sat Feb 06, 2010 11:38 am
by majorgator
So I now have 2 coats of S3 Topcoat Orcas White on the bottom. I'm very pleased with the roll and tip method used this morning, and it actually took less time than spraying. The coverage is better, thicker, and just plain nicer. Of course, it is the 2nd coat, so some improvements in appearance should be expected. The weather is great right now, about 60 degrees and high humidity. The 2nd coat is nearly dry enough to put on the 3rd coat. I will apply at least 2 more coats, and I believe that I will use the crosslinker in both coats.
There were a few runs from last night's application, so I sanded those down. The runs only occurred on the bow area, so for the 2nd coat, I painted this area without thinning the product.
For nearly the entire flat area, I thinned about 20% with water. I used a 6" close-nap roller and a 3" CHEAP foam brush for the tipping.
seth
Posted: Sat Feb 06, 2010 11:46 am
by wegcagle
Posted: Sat Feb 06, 2010 12:16 pm
Looks good from here
I used 4 coats of S3 on the inside of mine, every coat looked a little better.
A big one
5/16 or 3/8 X 2"
You can buy them in different lengths, but yes, you have to cut them to fit. Pastor Bob included a tubing cutter with the loaner flaring tool that's passing around. You cut it about 3/16 longer than the hole and flare the tube in place.
Posted: Sat Feb 06, 2010 1:22 pm
by majorgator
Thanks Larry. I just ordered my tubes, so when they get here, I'll go ahead and have the flaring tool shipped to me.
I definitely have some imperfections in the hull. Once all the bright white gets on there, you can see that I should have done a little better job with the fairing. Oh well, it is the bottom, and I know now how to improve for the interior.
Well, off the put the 3rd coat (1st with crosslink) on. Weather is holding tight at 60. Hopefully, it won't drop too much this evening so I can put the 4th coat on before I go to bed.
seth
Posted: Sat Feb 06, 2010 1:40 pm
by wegcagle
Seth,
I've got the drain tube flairing tool and cutter. So just shoot me an email wegcagle at gmail dot com and I'll send it to you.
Will
Posted: Sat Feb 06, 2010 2:35 pm
by majorgator
Will -
I just sent you email about the flaring tool. Go ahead and send it, and if someone else needs it before I get around to it, I'll put it in the mail. Thanks.
BTW - 3rd coat of S3 just applied, with crosslinker. Don't know why, but this coat was drying a lot quicker so I had to move much faster
Looks real good right now, but I can't wait to get that final coat on there in a few hours.
seth
Posted: Sat Feb 06, 2010 2:56 pm
by wegcagle
Got it. I will send it out to you Monday.
Will
Posted: Sat Feb 06, 2010 4:03 pm
by ks8
The xlinker speeds the S3 LPU set time, as you have discovered. I'm pretty sure it is mentioned in the S3 app notes for the product. It can be quite a challenge at 90°F and low humidity.
Will you be putting any coats of clear on the topsides?
Posted: Sat Feb 06, 2010 4:26 pm
by majorgator
I think that I will put the clear coat on the hull sides, but not the topside. I'm using Orcas White for the bottom, but it may be Whidbey White for the topsides. Already, with just 3 coats, its very bright and glossy. Anyway, the hull sides are intended to be black, in which case I may want the clear coat to really bring out the shine. Are you recommending that I put a clear coat on the topsides?
seth
Posted: Sat Feb 06, 2010 5:20 pm
by ks8
Wasn't recommending... just curious. The clear really buffs up glossy. But with black, that gloss will show every imperfection, in a very shiney way. And black will get warm, hot, when the Florida sun hits it.
Posted: Sat Feb 06, 2010 6:09 pm
by majorgator
I don't know. It may look really good, but I'm not leaning toward it because I'm going to have some non-skid areas.
And on second thought, it looks like I'm going to paint the sides white...maybe
I have about 1 1/2 quarts leftover from the bottom painting, and since I'm not using this color on the topside, it seems like a waste to buy more paint. I don't know, we'll see how I feel when the time comes.
seth
Posted: Sat Feb 06, 2010 9:17 pm
by majorgator
All 4 coats of S3 Topcoat are on, so here are a few thoughts I had.
I personally preferred the roll and tip vs. the spray. The 1st coat was sprayed, it took about an hour to apply, and about half an hour to clean up. The roll and tip took about 45 minutes to do, and about 5 minutes to clean. The coating was more even and thicker when rolled. The paint is now dry and void of any brush marks. Last 2 coats had the crosslinker.
I thinned about 20%, except for the bow area. For the last 3 coats, the only runs I had were in the tunnel.
The S3 Topcoat is EASY to use...when its 60 degrees and high humidity. I don't even want to think about doing this in 90+ degrees
Fumes were very minor. I did most of the work with the garage door closed because the wind was blowing pretty hard and I didn't want any leaves or dust settling on it.
I'm not saying its a perfect paint job, but its better than I expected. I guess its a waiting game to see how hard and durable the coating is. I'll try to roll it out in the sun tomorrow and get some good pictures.
seth
Posted: Sat Feb 06, 2010 11:12 pm
by peter-curacao
More tea? yes please! thank you!
Posted: Mon Feb 08, 2010 8:03 am
by majorgator
I rolled the boat out yesterday so that it could get some "sun cure" time. It spent all day outside, getting about 3 to 4 hours of direct sun in the afternoon. I checked the weather before I went to bed: no rain, temps in the mid to upper 30's during the night. I decided to leave it outside overnight so it could be in the sun again today. When I left for work this morning, I noticed that the entire bottom looked as if I never tipped it, kind of like little tunny bubbles all over it. At least its uniform, right
We did have a light, and very unexpected frost last night, so I figured that it caused some expansion with the moisture that was still in the paint. If I would have known it was going to frost, I would have put it back in the garage.
Its not the end of the world, but I would like to get that smooth look/feel back. What's the best route to go from here? Should I wetsand and buff? Maybe the texture will smooth out some once it heats up? Just not sure how to proceed. Thanks!!!
Seth
Posted: Mon Feb 08, 2010 9:13 am
by slvrlng
Sounds like solvent pop. Are the bubbles in any kind of pattern? Or are they very uniform?
Posted: Mon Feb 08, 2010 10:12 am
by majorgator
The pattern is very uniform...looks like it would make a good non-skid pattern
The final coat was put on saturday afternoon, and the problem occurred early morning today.
Nonetheless, or whatever the reason, I just need a solution that will work the best.
seth
Posted: Mon Feb 08, 2010 5:56 pm
by SaltShaker01
majorgator wrote:The pattern is very uniform...looks like it would make a good non-skid pattern
seth
Seth,
It is from the dew that in turn turned to frost. I am new to bateau building but have restored eight production fiberglass boats. My experience with new paint is that it doesn't like any sort of moisture falling on it until it is well seasoned. It can be sanded out after cure and then you can put another coat on. Other than that you can just leave it if it doesn't bother you.
Posted: Mon Feb 08, 2010 7:37 pm
by majorgator
Posted: Mon Feb 08, 2010 7:41 pm
by stickystuff
Knowing where you will be fishing I would hit it with some 220 or 350 then roll on a couple of coats of epoxy/graphite powder mix. I live in the same area of you and know the oyster bars are tough on hull bottoms. The epoxy will seek its own level and leave you a shiny black finish. don't worry about the UV protection because its on the bottom.
Posted: Mon Feb 08, 2010 8:39 pm
by majorgator
Ken - Do you have a good source for the graphite? I did a quick glance at the online store here, but didn't see any. Does the graphite make it stronger/more durable? Thanks!
Seth
Posted: Mon Feb 08, 2010 8:49 pm
by Larry B
majorgator wrote:Ken - Do you have a good source for the graphite? I did a quick glance at the online store here, but didn't see any. Does the graphite make it stronger/more durable? Thanks!
Seth
http://boatbuildercentral.com/products.php?cat=13
Posted: Mon Feb 08, 2010 9:09 pm
by majorgator
ahhh
Thank you kindly Larry!
Ken, how much should I purchase to get a good even coat along that big bottom? About how much extra epoxy do you think I'll use?
seth
Posted: Tue Feb 09, 2010 6:55 am
by majorgator
I have not put the wooden battens on for the rub-rail yet. Though its called out on the plans, and I've heard that its considered "structural" is it really necessary if I plan on building walk-around gunwales, full decks, and a rubber rub-rail?
seth
Posted: Tue Feb 09, 2010 10:04 am
by TomW
Yes mg the rubrails are structural on these boats. They can however with approval from the designer be replaced with an inwale of the same size. But that means cutting a notch out of each frame for the inwale so you can get the 3/4" x 1 1/2" or what ever size designated into the notch. 2nd just bring all your side decks out over the wood rubrails.
Posted: Tue Feb 09, 2010 11:16 am
by gk108
I wouldn't eliminate the rubrails, even with walk around gunwales. Tom's suggestion of moving that structure inboard and building it as a sheer clamp is about the best way keep the clean look on the hull sides and still provide strength. Think of worst case like hitting a dock piling midway between frames. Without a rail or sheer clamp, that force is localized and the deck/hull corner will tend to take the shape of the piling. Hit it hard enough and it will keep the shape of the piling. With a laminated frame behind that corner, forces are distributed to the frames and adjacent structure much more evenly. In other words, it is a vital element to monocoque construction.
Posted: Tue Feb 09, 2010 11:50 am
by majorgator
Thanks Tom. That's the info I needed. I'll go ahead and proceed with the wooden rub-rail. I wasn't suggesting that I didn't want to do it, but just wanted to make sure it was necessary. By doing the rub-rail now it will allow me to finish off the sides and paint it before I flip it. I assume that the rub-rail is just epoxy-glued to the side panels?
Now, if I could only figure out how much epoxy and graphite I need for the bottom.
Seth
Posted: Tue Feb 09, 2010 12:27 pm
by majorgator
Thanks to you too, GK. You were responding at the same time I was. Great information.
Seth
Posted: Tue Feb 09, 2010 12:45 pm
by TomW
Seth the 8oz they sell in the store should be enough graphite, mix it 2parts resin, 1part hardener, 1part graphite, for a 25% blend. Sift the graphite to get rid of any clumping. As far as epoxy you want 2-3 coats. How much did you use wetting out the cloth and go from there it won't take that near that much of course. I don't know if anyone has ever figured it out by sq ft per gallon. Maybe you can be the first and have the answer for the next guy that asks.
Posted: Tue Feb 09, 2010 1:31 pm
by ks8
Yes, the rubrails are epoxy glued to the sides. As is so often the case, mix in some wood flour to get ketchup consistency for an epoxy *glue*.
Posted: Tue Feb 09, 2010 5:10 pm
by stickystuff
Tom pretty much hit the nail on the head. Like he said , sift it and remove any clumps. If it is hot outside move quickly. If it starts to kick then stop or you will get a very gooey mess and it will not lay down smooth. If you give it a second coat wait until it is hard to touch and then give it a second coat. You can probably do the bottom with about 1/,2 to 3/4 gallon of epoxy mix.It will go a long ways when you are not mixing it with the fiberglass. It will dry to a very hard and shiny finish. Make sure you mask off the edges with visqueen so no runs will occur on your sides. Hold the masking line about 2" below the bottom. Once it tacks up and is almost set up pull the tape off so it leaves a nice clean line.You can get graphite at West marine in Crystal River or just order on line at Bateau. It is not expensive at all. All you need will cost less than $20.
Posted: Tue Feb 09, 2010 5:19 pm
by cape man
Seth, I didn't do this but read somewhere on this forum (after I coated my bottom)that it is best to add the epoxy to the graphite, making it thinner and thinner as you mix. This gives a better mix and eliminates a lot of the clumping some have had (like me!).
Posted: Tue Feb 09, 2010 5:49 pm
by majorgator
I like the idea of using graphite, and probably should have used it instead of the topcoat. However, after much deliberation, I've just decided to leave it the way it is. I'd hate to know that I spent all that time (and money) on 4 coats S3 Topcoat just to cover it with graphite. I really believe I should have done the graphite instead, but what's done is done
This won't be my only build, so I will make sure to use the graphite on my next one. I really appreciate the good ideas and thoughts from everyone (don't want to be ungrateful). I'm still on the fence, though, but leaning more toward not having the graphite at this point. This is one of those times when its just hard to make a decision.
seth
Posted: Tue Feb 09, 2010 6:19 pm
by cape man
Hey Seth,
Stop beating yourself!
I didn't read where you had already put three coats of top coat on. Heck no don't use graphite!!!! Like you said, save it for the next one.
Posted: Tue Feb 09, 2010 6:49 pm
by Larry B
majorgator wrote:I like the idea of using graphite, and probably should have used it instead of the topcoat. However, after much deliberation, I've just decided to leave it the way it is. I'd hate to know that I spent all that time (and money) on 4 coats S3 Topcoat just to cover it with graphite. I really believe I should have done the graphite instead, but what's done is done
seth
Seth, don't worry about it. I have about 2 coats on my FL14 and the beach at the lake, is sharp rock, ain't no sand just very sharp rock. I've run it up on the rock and it scuffs it up some but that about it. That s3 is pretty tough stuff. Oh and did I mention, this is some old s3 that didn't use the cross linker
Like Cape Man said, use the graphite on the next one.
Posted: Tue Feb 09, 2010 9:06 pm
by majorgator
Someone stop me before I become totally self-destructive to my budget and schedule
I had a good conversation with Ken tonight (thanks for taking the time Ken
) about the graphite. I'm going to spend a few more days just pondering it. I know I can't go wrong either way.
seth
Posted: Tue Feb 09, 2010 9:15 pm
by cape man
Posted: Tue Feb 09, 2010 9:22 pm
by majorgator
Critical case of BBV occurring in High Springs!!!!
I have to play it cool just to look normal
If only my wife knew what this was doing to my fragile emotional state
I can only use the excuse "the more I work on the boat, the quicker you can have your garage back" for so long.
seth
Posted: Tue Feb 09, 2010 10:30 pm
So....you haven't told her about the next boat, yet
Posted: Wed Feb 10, 2010 6:15 am
by majorgator
I care too much about the finer things in marriage to even bring that up yet
Besides, I'm still working on how to tie in boatbuilding with the excuse I'm fabricating for building a shop. "Honey, not only will I let you park in the garage again, but if I build that shop, I can move all the rest of the junk out of the garage so you can open your doors when you pull in."
Posted: Wed Feb 10, 2010 6:20 am
by majorgator
Wait, did I say "junk"?
Now I am starting to sound like my wife. We all know that the misc. tools, materials, and fabrication components I have are completely useful. They're meant to save money, time, and allow life as we know it to continue blissfully. I don't bring home "junk", only valuable items that assist not only my projects, but our family in general
Posted: Wed Feb 10, 2010 6:22 am
by cape man
Posted: Wed Feb 10, 2010 8:26 am
by majorgator
So regarding the rubrail:
I was looking to purchase the rubrail offered on the Bateau site, the flat dimension where it mounts to the boat is 1-3/8" wide. I'd like to plan on using 2 laminated strips of 3/8" (total thickness of 3/4") ripped to 1-3/8" width. This should allow for nearly perfect mounting of the rubrail. For a little added protection/strength, I would like to run a narrow, single length of fiberglass tape and epoxy along the bottom side, then seal off the topside when I do the interior glasswork. I hope that explains it well enough.
Thoughts??
Posted: Fri Feb 12, 2010 6:19 am
by majorgator
I need some help on figuring out what size fuel line I should buy for my Yamaha 85HP 2-stroke. Will a 5/16" line provide sufficient fuel flow? I don't see why it wouldn't, but I just want to make sure.
Posted: Fri Feb 12, 2010 7:37 am
by SaltShaker01
majorgator wrote:I need some help on figuring out what size fuel line I should buy for my Yamaha 85HP 2-stroke. Will a 5/16" line provide sufficient fuel flow? I don't see why it wouldn't, but I just want to make sure.
I personally would go with 3/8" for a short run from a portable tank in the rear to the outboard. I usually will run a 5/8" fuel line from the tank to the racor when the tank is amidship and the racor is by the transom then run a 3/8" from the racor to the engine.
Trust me you do not want to starve a two-stroke of fuel or oil. Also do not skip the racor. It is a must with todays poor quality ethanol gas.
Posted: Fri Feb 12, 2010 7:46 am
by cape man
I ran 3/8" from the tank in the foredeck to the engine with a water/fuel separator/filter in the stern starboard hatch. If I remember correctly it was 15 feet of hose total. 40hp 4 stroke. While they are very proud of all fuel lines, you don't want it to not carry enough fuel, and there's not a huge difference in total price. I wouldn't use the 5/16".
Posted: Fri Feb 12, 2010 8:53 am
Another vote for 3/8. That's also the standard fitting size on the fuel tanks. 3/8 for fuel feed, 5/8 for vent line, 1 1/2 for fill. Make SURE you buy the type A hose rated for alcohol fuels
Posted: Fri Feb 12, 2010 8:56 am
by majorgator
Definitely not! I've got about half a dozen saved on "My eBay" right now
Gone are the days of a small inline fuel filter only
Yeah, not sure what I was thinking. My other boat has a 3/8" line, and it is the size on my new fuel tank.
seth
Posted: Fri Feb 12, 2010 8:17 pm
by SaltShaker01
Are you still going to flip her this weekend?
Posted: Fri Feb 12, 2010 8:36 pm
by majorgator
Actually, I decided to go ahead and paint the sides first. They'll be easier to paint now than once its right-side-up. This comes after deciding also that I was going to install the wood rubrail, which takes care of my concerns about fiberglass wrapping over the side. Also, I'm going to put the graphite coating on the bottom. If everything goes right, I'll be flipping it 2 weekends from now.
seth
Posted: Sat Feb 13, 2010 10:35 pm
by majorgator
Got the first section of rubrail installed today. Hope to put the second thickness on tomorrow, then lay a little fiberglass over it. This dadgum cold weather makes my glue not want to dry so I can't do more than one step a day right now
seth
Posted: Sun Feb 14, 2010 1:59 pm
by wegcagle
I forgot to let you know, the flairing tool was sent out Wednesday. Just an FYI.
Will
Posted: Sun Feb 14, 2010 2:48 pm
by majorgator
Yeah, I was going to send you an email because I hadn't received yet. No problem, I just wanted to make sure it didn't get lost in the mail
Thanks!!
Seth
Posted: Sun Feb 21, 2010 6:42 pm
by majorgator
One more task complete...time to resume boatbuilding
This started slowly...
but it picked up...
he wasn't much help...
neither was she...
but somehow it got finished up this morning...
I was able to get the rubrails on last weekend...
Next step is to sand the bottom paint and prepare for graphite
seth
Posted: Sun Feb 21, 2010 7:19 pm
by stickystuff
Now for the cat on a hot tin roof.
Posted: Sun Feb 21, 2010 8:15 pm
by majorgator
Posted: Sun Feb 21, 2010 8:25 pm
by cape man
Nice roof Seth! Boat's coming along too...
Posted: Mon Feb 22, 2010 4:26 pm
by ks8
Nice x2.
Posted: Mon Feb 22, 2010 5:36 pm
by majorgator
Thanks everyone. I hope to get some sanding done after this week, then lay the first coat of graphite on Friday.
When I got to work this morning, I parked next to our's president's boat (always in our parking lot), and I thought "man, I should just hook it up and head to Crystal River." Beautiful day, mid-60's, mid afternoon shower and sunny late afternoon...maybe this weather will hang around.
Posted: Sun Feb 28, 2010 6:36 pm
by majorgator
Graphite is done, well mostly. There are a few light areas that will need a little more attention, but for the most part, I'm pretty happy with the way it looks. It definitely is very slick now
and the black is nice and shiny, very reflective
if you put your face right next to it, you can count the wrinkles (not that I have too many yet, but still...)
yet another reason NOT to own a cat
Posted: Fri Mar 05, 2010 3:59 pm
by majorgator
The jack plate I purchased was used, and thus did not come with a switch. I went to Bob's the other day and bought one, but then I started to (over)think this whole thing
Generally when running, you want to be able to control EITHER the trim and tilt or jack plate. If you have a jack plate, then that's most important to control over the the T & T
And since you want to adjust the jack plate while the boat is going to plane, it would be better to have the switch located on the throttle control near your hand. Therefore....couldn't I just re-route the wires on the control for the T & T to the jack plate, and then just use the switch on the motor for T & T??
Posted: Fri Mar 05, 2010 5:51 pm
by stickystuff
Look up teleflex on the internet. They make a double switch that mounts underneath your steering wheel. It is like a double turn signal switch except one lever is on port side and other is on starboard side. Steer with both hands and just move lever up or down with your finger while driving. One works tilt the other works trim. Very easy to hook up.Y ou can buy them online or most dealers can get one for you if they are not in stock. Hands free trim switches.Only way to go. I love them.
Posted: Fri Mar 05, 2010 8:58 pm
by majorgator
Thanks Ken...something like this is what I assume you're talking about:
Posted: Sat Mar 06, 2010 7:01 am
by stickystuff
Thats the one. You will love it.
Posted: Sat Mar 06, 2010 11:01 am
by Dog Fish
That looks like a cool set up.
Brian
Posted: Sat Mar 06, 2010 11:40 am
by cape man
You can also mount the switch for the jackplate on the side of the throttle just below the handle. secured with a tie wrap. Allows you to hold the wheel and throttle while working the plate. Not as nice as the switches on the wheel, but I had the switch and no money. Can't see it real well in this picture, but the wire comes through the console just inside of the throttle.
Posted: Sat Mar 06, 2010 3:35 pm
by majorgator
Posted: Sat Mar 06, 2010 11:34 pm
by cape man
Posted: Sun Mar 07, 2010 12:15 am
by ks8
Nice!
And now.... fun.... part deux.
Posted: Sun Mar 07, 2010 7:01 am
by majorgator
Most folks would not appreciate what that means
It was one of the best "feel good" moments I've had in this process
Fillets during the evenings this week. Interior glass and stringers next weekend. Framing over the next two weekends after that......Builder's Meet in May
Its gonna be tough
seth
Posted: Sun Mar 07, 2010 2:09 pm
by ks8
Maybe without paint?
If she isn't bashful....
Else take your time without regrets.
Posted: Sun Mar 07, 2010 2:28 pm
by Larry B
Not bad, only 1 week off
I can usually estimate a time frame if I allow myself a 6 month window
btw, boat is looking great
Posted: Mon Mar 08, 2010 11:59 am
by Tex 2009
Major G, how did you put the graphite on? Was it roll and tip or just roll on? Does the graphite make a ridge where it buts the taped off area or is it a flat edge?
Posted: Mon Mar 08, 2010 12:07 pm
by majorgator
I put the graphite on with a foam roller, no tipping. For me, it didn't turn out quite as good as I was hoping, because I put it on too thick. I spoke with Richard afterwards, and he said that it has to go on real thin. It would have made a big difference in the finished product, as I ended up with quite a few very tiny tiny bubbles. Still looks very good though, nice and shiny, but you'll never see the bottom of this boat
I put on 2 coats, plus a touch-up 3rd coat on a few spots. There is a tiny ridge where it was taped off, maybe 1/64". Its just enough that you can catch your fingernail on it. I don't see any reason to do anything about it.
seth
Posted: Fri Mar 12, 2010 10:10 pm
by majorgator
Inside fiberglass went in today. Just like the bottom, I got a few spots to fix up, but overall it looks good. And I'm most thankful that I don't have to sand it because it will generally be below deck.
I did not install the transom board yet, so that area has not been laminated. However I don't see any reason to use 1708 for this purpose. Just some 12 oz cloth will do. Now that I'm done with all the 1708 uses, I can officially say that I hated every second of working with it. Talk about some stuff that doesn't bend over ANY corner and swallows up gallons of epoxy in no time at all. Sheesh. I know we've kicked around the thought of using 2 layers of 1208 instead, so I wonder if Jacques has considered the pros or cons to that?
BTW - I've now went through 18 gallons of epoxy, which includes the graphite on the bottom. And I still have to tape the frames, stringers, and decks, as well the fiberglass on the deck and other misc. fabrications. Maybe I've been a little wasteful, but I don't I've been too bad. Looks like I'll be calling Joel soon.
seth
Posted: Sat Mar 13, 2010 12:31 am
by ks8
You think you'd bring her to the meet with only primer? The calendar is flipping fast. Enjoy the build instead of a deadline.
As soon as there's enough structure in a picture or two, go get your HIN and Regi so there are no last minute surprise delays, if you are still trying to make it.
Posted: Sat Mar 13, 2010 6:33 am
by majorgator
If she's not 100% done, she won't be at the meet
I've got to get more than the primer done, so I can hide some of the defects.
As soon as there's enough structure in a picture or two, go get your HIN and Regi so there are no last minute surprise delays...
Good idea. I'll get started with that as soon as there's a deck in place.
Seth
Posted: Sat Mar 13, 2010 7:24 am
by Larry B
seth
Seth, looks like your pretty close to what others and myself are doing with the epoxy
XF20 calls for 9 gallons, looks like you will be into the 20's
, OD18 calls for 7 gallons, CL was 21, Craig was 21 and I'll be around 25
But you know we all build these different than each others, I just figure it's going to take as much as it takes
Posted: Sat Mar 13, 2010 3:27 pm
by majorgator
Without looking at my plans, I believe the BOM for epoxy is 15 gallons when installing the sole. I might be wrong, but nonetheless...Ken told me that he used 13 gallons of epoxy on the double-layered bottom of the XF20 he built a few years back. Oh well...what's a little more money, right
seth
Posted: Sat Apr 24, 2010 7:32 am
by majorgator
So I'm trying to figure this one out...
I've got the wooden rubrail installed, and its cut so that the rubrail sold on eBoat will fit perfectly. But, I totally omitted the angle of repose that the rubrail would have (I did it when the boat was still upside down) when cut straight and laid flush. Also, I didn't put much thought into how the decks would line up with the edge of the boat. As of this moment,
I have NO IDEA as to the best way to go about addressing this issue. Pictures are below....and anyone's insight (no matter what it is) will be appreciated. And forgive me, I haven't squared up the rubrails yet
Thanks...Seth
Posted: Sat Apr 24, 2010 8:00 am
by Steven
Just fill the void with epoxy putty and then grind to the desired shape. If I recall from CrackerLarry's build, he wished he had made the joining coners vertical, as opposed to the same angle as the hull corner. This makes wrapping the rubrail around the corner easier. However, he used different type of rubrail. With the type you are using, two piece rigid with insert, you might have to miter the rail at the corners anyway.
Posted: Sat Apr 24, 2010 9:55 am
by cape man
Seth,
You have a couple of options as I see it. Build the rub rail up to the level of the deck. Take the inside of the sheer line down to the rubrail with a grinder (I don't like that idea). Round the transition over to the level of the deck. I think the latter will look the best.
Posted: Sat Apr 24, 2010 10:36 am
by wegcagle
Seth, on mine I basically did Craig's first suggestion. I found the correct angle to make the deck flat, then I set my circle saw to that angle and went to town taking it down to the shear line. It did a good job of making it flat and even, but I did have to get the sander/grinder after quite a few areas to get it right. If I had it to do again I think I would do Craig's second suggestion. I just didn't think of it at the time
Will
Posted: Sat Apr 24, 2010 11:15 am
I used suggestion 2, but used a block plane rather than a grinder. A much friendlier tool
It only took about a half hour with the plane. Use a straight edge across the sheer as a guide for level.
Posted: Sat Apr 24, 2010 11:24 am
by wegcagle
This is why I should ask more questions, and stop working so damn hard
Oh well, as long as your happy with the end result anything extra is just gravy
Will
Posted: Fri Apr 30, 2010 9:56 pm
by majorgator
Posted: Fri May 14, 2010 10:03 pm
by majorgator
Well I decided to put aside things like work and chores and honey-do's and all the other things I really need to be doing so I could work on the tower. The platform will be 12" above the rear deck, and the front legs will extend to the sole. I left them a little long because I'm not sure about the exact length right now. There will be a small round-box-like console on the front between the 2 posts, but I'm not going to cut those bent pieces until later. It will have a leaning post-type seat, foot rest, grab rail on the back with mounted rod-holders. I haven't decided what the platform will be made of, either aluminum or starboard. Anyways, we got a good start on it...we were able to put some modest bends on the 4 posts, and some really good bends on the seat supports. The material is mill-finished handrail. It will be either painted or powder-coated.
Posted: Sun May 16, 2010 5:08 pm
by cape man
That'll be cool Seth.
Posted: Sun May 16, 2010 6:40 pm
by wegcagle
Nice
that's gonna be a serious platform.
Will
Posted: Sun May 16, 2010 7:25 pm
by majorgator
I can't wait to see the finished product. Its not going to have the amount of curves like towers that are built using benders, but hey, what should I expect with a steel frame, block of wood and hydraulic jack
seth
Posted: Sun May 16, 2010 8:29 pm
by ks8
I just may have to learn how to weld. Looking forward to seeing it fitted to the boat.
Posted: Sat Jul 31, 2010 1:56 pm
by majorgator
Well, just an update here. I've got all 4 stringers glassed in and epoxy on the non-glassed areas. All of the small patchwork with the 1708 on the hull is done. I took a block plane and flattened out some of the top edges, as suggested by CLarry. It doesn't take long at all. I've got the front bulkhead clamped in place. After I fit the rear bulkhead, I'll tab them in with glue and then tape the seams along the side.
I went with the 4 stringers vs. the two shown on the plans. After they were assembled, I clamped them together and planed the edges slightly so that all 4 were identical.
Funny how some people always find there way into the picture, even though they're not really much help.
Here are the stringers glassed onto the hull. I've got a little bit of trim work to do on the excess glass that's hanging over.
Don't forget the weep holes. I glassed right over them with the tape with the intent to cut out those areas later. I have considered, though, just putting a piece of 1 or 1 1/2" pvc into a hole cut with a hole saw, then sealing up the edges with some 5200. It would be a clean option instead of just having rough-cut holes.
Here is the front bulkhead. I've got it clamped in place and leveled up (with the weight of paint cans
). I brought the bulkhead to the top of the gunwale. As a result, I will bring the decks and 8" wide gunwales to the outer edge of the boat (as suggested by Richard and TomW).
I'm still doing some figuring on space requirements before I cut and install the rear bulkhead. Contrary to some of the previous posts, I'm actually going to install a standard console. I really like the tower idea, and I was excited about the partially built one behind my shed, but I think I'll be better off with the center console.
seth
Posted: Sat Jul 31, 2010 2:48 pm
by Steven
Coming along nicely. I prefer the look of the cutouts over round holes if you are not putting on a sole. The stringer notches in your frame are pretty generously sized. Gonna eat a lot of epoxy. Just big enough not to touch is good.
Posted: Sat Jul 31, 2010 4:50 pm
by majorgator
I did make a mistake when cutting them out, but I also moved the frame to a slightly different location vs. where it started. It doesn't make any difference, though, because I'm not going to fill in those areas with epoxy or glass. I'll leave the notches open and glue a bearing strip on either side so that the frame will have lateral support against the stringers. I left the bottom portion on so that I could drill holes and use a supports for pipe chases. I'll probably remove the bottom all-together on the rear bulkhead.
seth
Posted: Sun Aug 01, 2010 12:09 am
by Steven
seth
Gotcha. As long as that is not a specified frame location that should work good.
Posted: Sun Aug 01, 2010 7:50 am
by majorgator
The bulkhead is in the general area of one of the required frames. However, I will be attaching the sides to the hull, and the bottom to the sole. There will be a full deck on the front and some level of gunwales for extra support. I know what you're thinking, but this ole girl won't be lacking in strength, that's for sure
My current thought is to put a console as shown below, with a cooler seat in front. The seating will be on the aft deck, either by way of cushion or stubbed up leaning post. I expect that I will put the livewell behind that, over top and beginning in front of the tunnel. Directly behind the front deck, I'm considering a molded-in insulated fishbox, about 18" x 42". That's what I've come up for now, but God knows that'll change within the next hour or so
Posted: Fri Aug 06, 2010 8:27 pm
by chlli willie
Hello Major,Its gettin there,lookin good . I thought i would be done by now -how about you? Did you paint over the graphite?
Thanks for posting pictures.
Posted: Sat Aug 07, 2010 8:53 am
by majorgator
Quite the opposite. I sanded the S3 LPU down to the primer, and coated graphite over that. Bottom is now black and shiny...and slick and hard
seth
Posted: Fri Aug 13, 2010 5:09 pm
by majorgator
I'm preparing to tape the bulkheads to the hull sides. My first inclination is to use 2 layers of tape each side and on both ends. Before I go overboard though, would one layer of tape be sufficient? I haven't put just a single layer of tape at any joint so far, so I'm not real inclined to do it here unless I get some good feedback that its OK.
seth
Posted: Fri Aug 13, 2010 5:38 pm
What do the plans say ? Or don't say
I'm sure you've checked that. I'd go with 2 layers unless it is specified otherwise.
Posted: Fri Aug 13, 2010 6:03 pm
by cape man
Seth,
Just my $0.02...After riding through the chop down in Boca with Richard in Red Alert, I would put two layers if you can swing it. Very shallow boat, but it really is a bumpy ride in a chop. Nothing like the assurance of well taped stringers and bulkheads under that deck. Our OD18 plans call for just glueing the stringers down, but after watch CL I too taped them down and am really glad I did. Like the XF20, the OD slaps pretty hard sometimes, and I just smile knowing I am solid below. Running fast across a tight chop creates a lot of rapid force along that hull and the double tape has got to help.
Posted: Fri Aug 13, 2010 6:10 pm
by majorgator
I'm not real sure what the plans say because these are supposed to be frames, not bulkheads. Maybe it doesn't make too much of a difference. 2 layers it is! I don't know why I even questioned myself
Thanks guys!
seth
Posted: Fri Aug 13, 2010 11:14 pm
by Aripeka Angler
Seth, I used two layers of tape for attaching my bulkheads to the side panels. I didn't notch my rear bulkhead around the stringers, just the front one. I taped both of them to the sole with one layer of tape. No cracks or problems so far with the bulkheads.
The inside of your boat looks great. I can appreciate the difficulty of working with 1708 inside a hull, XF-20 builders for sure won't win any pretty lamination contests
The 1708 is a pain in the butt isn't it?
Posted: Sat Aug 14, 2010 7:11 am
by majorgator
That's an understatement
Some new XF20 builders sent me an email the other day with questions related to this build, and I suggested that he contact Joel & Jacques about using 2 layers of 1208 in lieu of the 1708. If I had to do it over again, that would be my choice.
Same here
Thanks! I'm starting to see the end in sight. Didn't I tell you guys June/July?? Darn those time frames
seth
Posted: Sat Aug 14, 2010 8:58 am
by cape man
Posted: Sun Aug 15, 2010 7:31 am
by stickystuff
............Their is nothing in writing that says you have to use 1708 or 12.. Its up to the builders discretion how bullet proof he wants the hull bottom. The 1708 is def. the way to go but more work and more costly. If you live in an area that does not have the oyster bars or rocks then it is not neccessary. This is my personal thoughts on this.I still believe in the epox/graphite bottom though.
Posted: Sun Aug 15, 2010 8:19 am
by tech_support
1708 is used to build up thickness. two layers of 1208 would use a lot more epoxt and be a lot heavier than needed. two layers of 1208 would be 40 oz of glass. Two layers of 1200 (12 oz without mat, same glass as the tape) would give just about the same amount of glass, in terms of glass weight, as 1708, but it would not be as thick as the one layer of 1708. The matt layer of the 1708 absorbs epoxy like a sponge and makes for a thicker laminate. Either way is fine, its just a matter of how much overkill you want
Posted: Sun Aug 15, 2010 9:52 pm
by ks8
Posted: Sun Aug 15, 2010 10:05 pm
by cape man
Seth,
Remember that's coming from a guy with almost 8 years (or is it more KS?) in a small sailboat....
I had a Christmas deadline...just didn't say which one.
You're getting there. Keep building brother!
Posted: Mon Aug 16, 2010 1:25 pm
by ks8
Count the laughing smilies. Ready to launch in 7 years, but I think she hit water at nearly 8. Still finishing up last few details, but remember, I planned for all sorts of swappable details, so technically she may never be *finished*.
But technically, she is finished, cept for some final interior paint and getting seals for the wood hatches. I never did a precise count, but I'm wondering if she hit water 7 years, 7 months, 7 days, 7 hrs, 7 minutes and 7.7 seconds after the first cut? Yes, it was all planned....
Posted: Mon Aug 16, 2010 9:30 pm
by majorgator
shine wrote:
1708 is used to build up thickness. two layers of 1208 would use a lot more epoxt and be a lot heavier than needed. two layers of 1208 would be 40 oz of glass...Either way is fine, its just a matter of how much overkill you want
I only went with the single layer of 1708, but I was on the fence about adding the 2nd layer. Had I have used the 1208, I would have probably leaned toward the 2 layers...but hindsight's 20/20 I guess. I figured that either way is acceptable. I believe I read where the earlier designs of this boat called for a single layer of 1208? Either way, the way we're doing it is certainly better than the original microdrafts
Thanks for the encouragement Craig, and yeah, I've been following ks8...lots of smilies there
New goal: Thanksgiving. I want to be able to fish the low-tide creeks with it this winter. But football season is right around the corner, so I'm basically screwed
Got a little more done this weekend. The bulkheads are glassed in the sides, next thing is to begin the framing (I think). Also, I took the edges down flat at the rubrail. It was suggested that I use a block plane, but why do that when a power-planer is available
Sure made short work of the edges.
Posted: Mon Aug 16, 2010 10:31 pm
by cape man
Now we're cookin' with gas!
Posted: Tue Aug 17, 2010 9:44 pm
by majorgator
Speaking of gas, I'm going to fit the fuel tank this week
seth
Posted: Tue Aug 17, 2010 9:59 pm
by cape man
Sweet. What did you end up getting (I can't remember and am too lazy to go back through your thread)?
Posted: Thu Aug 19, 2010 9:17 pm
by majorgator
Craig, I got the 18 gallon shown below. I believe its the same one that Richard has. Going to place it front of the front bulkhead.
Posted: Thu Aug 19, 2010 9:41 pm
by stickystuff
Make sure you face the fuel pickup tube to stern.I goofed when i built the one and when under power fuel would go to stern and would not pick up when fuel got low.
Posted: Sat Aug 21, 2010 6:09 pm
by majorgator
Yep
I'm going to put a very minimal slope to stern as well...I think.
seth
Posted: Sun Aug 22, 2010 9:34 am
by cape man
Yep I'm going to put a very minimal slope to stern as well...I think.
No need. Trim up the nose if you are running out of gas. Mount it level and then you can fill it all the way.
Posted: Sun Aug 22, 2010 10:26 am
Yep, mount it level. The boat will run slightly bow up anyway.
Posted: Sun Aug 22, 2010 9:13 pm
by majorgator
Yep agreed
Upon further thought, being level or slightly tilted is all relative to the seas you're in
Made some good progress over the weekend. Found some good #2 southern yellow pine, generally free of large knots. Got the clamping board cut and mounted (not permanently yet). Installed the bow eye and backer board; a 2 x 12 x 20"(L) should do the trick (again, not permanently mounted). The fuel tank is fitted, the framing boards are ripped...and the ideas are swirling in my head. I originally wanted a built-in insulated fish box, but now I'm not real sure that's the best way to go vs. a high quality, well-mounted cooler. Either way, I figure that can be mounted/built directly behind the front bulkhead. I'm pretty well decided, though, that a built-in livewell (maybe 10 gallons or so) can be placed centered about 12" behind the rear bulkhead. Now, to figure out the rod-lockers...or not
seth
Posted: Sun Aug 22, 2010 11:06 pm
by cape man
Go Seth! Now's the fun! I use the long locker on the starboard side of my foredeck as a fish locker when fishing. Not insulated, but it holds ice for a day no problem. It melted by the end of the second day down in Boca, but the water was still ice cold for the few trout me and the kid caught.
Posted: Mon Aug 23, 2010 8:59 pm
by majorgator
hmmm...fishbox in the foredeck...
With over 7 feet of deck, I think I could squeeze that in
seth
Posted: Mon Aug 30, 2010 9:38 pm
by majorgator
Gotten quite a bit done recently.
framing of the sole:
primary framing for the front deck. established anchor locker area. the bulkhead for the anchor locker is the cut-out of the hull for the tunnel:
anchor locker and bow-eye stiffener:
another picture of the front deck with fuel tank:
transom clamping board:
Nothing's glued yet...gonna wait till all pieces are cut then start gluing. Front deck framing is only partially completed. I'm going to lay out the plywood to see where the additional supports are needed. Temporary drywall screws are being used right now to hold things in place.
seth
Posted: Tue Aug 31, 2010 7:53 am
by topwater
Looking good
I guess you wont have to worry about anyone pulling your bow eye off
Posted: Tue Aug 31, 2010 4:34 pm
by stickystuff
If you hav't already planned on this just from what I see you need to add another 3/4" to the thickness of your transom. It should be a minimum of 2". Add another 3/4 ad you will have a good 2 1/2". I say this because it looks like 3/4 instead of 1 1/2. Correct me if I am wrong. Just don't want you to make ay mistakes at this point. Looks good.
Posted: Tue Aug 31, 2010 9:41 pm
by majorgator
Hey Ken, thanks for the info. What I've got on the transom now is a southern yellow pine 2 x 12. With that, plus the 1/2" plywood and 2 layer of 1708, the thickness of the transom comes out to be 2 1/4" on average. I think that should be OK, but let me know what you think.
seth
Posted: Tue Aug 31, 2010 10:07 pm
by Aripeka Angler
That should be fine. I am pretty sure that the plan calls for a 1 inch thick clamping board on the 1/2 inch thick transom. That is what I did anyway.
Your boat is looking nice
Are you planning on a self bailing sole
Posted: Wed Sep 01, 2010 5:54 am
by majorgator
Yes, actually, I've been meaning to ask you if you ever put any covers/vents/scuppers over your self-bailing holes. I was kind of planning on putting the holes at the back corners of the deck like you did and finding 2 nice scuppers to go over them.
seth
Posted: Wed Sep 01, 2010 9:38 am
by Aripeka Angler
seth
No covers over the holes yet Seth. I get spray/splash onto the sole when it's rough but it drains right out when I slow down or stop. I plan on putting a clamshell over the holes when I get a chance.
I raised the sole in my boat about 2 inches above the stringers. Unless you plan on plugging the drains, you are going to get wet feet when you come up on a plane. I would stand those 1x2s up on edge under the sole. Here is a picture of the drain holes on Red Alert...
The rear thru hull is the livewell drain. When the boat sits unloaded in the water, the water line is flush with the hole in the fitting. The way you have it framed, that hole is only going to be 5 inches above the bottom of the boat. Just something to consider since you are building a heavy version of the XF like I did. Put two guys on one side and water may come in....
Posted: Wed Sep 01, 2010 10:41 pm
by majorgator
Thanks for the info Richard. I'm going to stand the 1 x 2's up on edge to see what kind of height that gives me. I believe that I should be OK if I could get at least 7 1/2" from the dead bottom of the boat.
As I mentioned on the phone, been busy for the last couple of days. Don't know if the picture came through, but here ya go:
seth
Posted: Wed Sep 01, 2010 10:45 pm
by Aripeka Angler
I was holding my tongue to not leak the news
Comgratulations Seth
Posted: Wed Sep 01, 2010 10:52 pm
by cape man
Seth,
Screw the boat! Congrats!!!!!!
Posted: Wed Sep 01, 2010 11:11 pm
by TomW
Hey Seth you been holding out on us boy. Beautiful wife and even prettier young one. Congrats!!
Posted: Thu Sep 02, 2010 7:35 am
by gstanfield
Congrats
Posted: Thu Sep 02, 2010 8:19 am
Posted: Thu Sep 02, 2010 8:37 am
by majorgator
Thanks everyone
Momma and Baby should be coming home today...let the sleepless nights begin (again). Life is good, though, and blessings are evident
seth
Posted: Thu Sep 02, 2010 9:55 am
by wegcagle
Congrats Seth, what a happy looking family.
I gotta say your boat building time will decrease substantially, but it is TOTALLY worth it. The best parts of my day are spent rolling around on the floor with my rug rat
Glad the wife and kiddo are doing well.
Will
Posted: Fri Sep 03, 2010 4:11 pm
by BassMunn
Hey congrats Seth
Posted: Fri Sep 03, 2010 5:39 pm
by colonialc19
It just don't get much better than that, congratulations Seth.
Posted: Fri Sep 03, 2010 6:45 pm
by macs
Congratulations on your new little one.
Yep, you've probably got some sleepless nights coming, but hey, you never know. You'll manage just fine.
Macs
Posted: Fri Sep 03, 2010 9:02 pm
by majorgator
As many of you know, this little one isn't far behind is big brother. There only 14 1/2 months between the two of them, so we definitely have our hands full. Oh well, just livin' the dream
seth
Posted: Fri Sep 03, 2010 10:20 pm
by wadestep
Congrats for sure - it's good to hear the good news
Posted: Mon Sep 06, 2010 7:32 pm
by majorgator
Got a little bit more done over the past few days. The majority of the framing is completed for the front and rear decks. Its all held together right now with temporary drywall screws. Its gonna be fun to take all the pieces apart and re-assemble them like a puzzle...I'll put numbers and matchlines on each piece, maybe even a rough sketch with numbered pieces. I've chosen to paint the entire framing structure and bilge area (all the undersides) with a white 2-part epoxy paint instead of coating the individuals pieces with epoxy resin. I'll use an HVLP sprayer to make the job a bit easier. Also, I'll be using GelMagic to glue all the frame pieces together.
Notice, extra framing around where the hatches will sit.
After I get all this squared away, I'm going to set the framing for the floor/sole. I'll be turning the frame pieces on end, per Richard's wisdom. Then comes the paint when all the framing is done. I'll then place my chase tubes and other parts and pieces (livewell pump, fuel filter, jack plate pump, etc.). At some point along the way, probably before the paint, I'm going to build-in-place a livewell and fishbox).
Definitely starting to see the light at the end of the tunnel. I'll be hitting those shallow creeks this winter for sure
seth
Posted: Mon Sep 06, 2010 8:34 pm
by stickystuff
The only thing I did and you should have done is rabbit all the joints instead of butt joints. Would have been a lot stronger. japenese type pull saw is the ticket for this job. Extremely sharp and a pleasure of a tool to use. Just my 02 Other than that it looks pretty good.
Posted: Sun Sep 19, 2010 7:21 am
by majorgator
Yeah, Ken, that would probably would have been better. But what's done is done, and I'll have to live with butt joints.
Hopefully, there's enough support from the entire structure that any one joint will not come into question.
Moving along nicely now. I've move past the indecision stage (regarding layout) and I can freely work without hesitation. A few weeks ago I purchased Daytona Plastics hatches, but after playing with them for a few days, I decided I didn't like the style of the latches, and I figured that they are easily broken. Combine that with the fact that they apparently are no longer in business, I became a bit concerned with their longevity. I exchanged them for hatches made by Innovative Product Solutions. I like their design a little better, and the latches are interchangeable with several aftermarket manufacturers. They were the same price as the others ($49.95 for the 13 x 17 and $39.95 for the smaller ones...they had some of the smaller ones for $29.95 that had some scuffing on them, so I was able to save a little there)
Here is the back deck framed and glued. I'm going to add a few more vertical supports, but the big piece of work is done. The livewell is in the middle, completely glassed. I'm going to water test it today. It goes about 17 gallons and has a slight tilt to port for draining. Since I have some extra foam insulation, I'll glue some to the exterior sides and bottom for good measure.
Here is one of the two battery platforms.
This is the insulated fishbox. It goes about 36" in length and is slightly smaller than a 120 quart cooler. It slopes to the center for draining. I purchased a sheet of R-5.0 foam insulation from Lowes, and it will be attached to all 4 sides, top and bottom. I don't know a lot about foam insulation, but this should be enough to keep ice for at least a day of fishing.
Here's the box framed and fitted with the hatch. This is a Rabud pull-type hatch I picked up for $20 because it has a small chip in the interior flange. It goes 20" wide, so plenty of room. Also shown is the layout and fitting for the other bow deck hatches.
And for my last line here, I need some help in figuring out how to securely fasten/attach/fit the fuel tank. I didn't leave enough length on the supports to use the recommended Moeller tie-downs, so I'll have to go in a different direction. Here are the pictures of how it will sit. Please help with any thoughts on an effective way to secure it.
seth
Re: Majorgator's XF20
Posted: Sun Sep 19, 2010 7:56 am
by macs
Hey Seth,
When I ordered my tank from Moeller, I thought it had a mounting kit, but it did not, even though it shows one on the web sight.
I made stops out of 1x2's with rubber strips glued to the sides
The stops prevent any forward or latteral motion(within mollers tollerances) When I installed the forward deck, I ran a support under it that helps support the deck and acts as a stop for the tanks verticle motion as well. It has rubber on the bottom of it to protect the tank from the wood if it makes contact. Again with moellers tollerances.
Hope this helps with yours, I know I struggled with my tank installation.
I thought it would have been one of the simplest parts, but I was wrong. I remember getting a lot of help from CL, Tom, Craig and several others.
I'm sure they'll have some good advice.
Good Luck
Macs
Posted: Sun Sep 19, 2010 8:11 am
by Aripeka Angler
Seth, that looks like the same tank I have in my boat. In fact, I think it's in the same location. There wasn't much meat to screw the brackets into for me either, but it did work. My supports must have been a tad wider. The idea that Macs suggested will work great or you could add a strip of wood to each side of the stringers and use the aluminum Moeller brackets....
Edit, I forgot to say I love the layout. Maybe Red Alert will have some company next year in Boca
Posted: Sun Sep 19, 2010 8:21 am
by tech_support
You can strengthen up those butt joints a lo by gluing blocks on either side, you triple you glue area
Posted: Sun Sep 19, 2010 8:38 am
by ks8
Great tip Joel. Certainly easier than to biax all those corners with thin strips, and then to have to trim it up afterwards.
Posted: Sun Sep 19, 2010 9:18 am
by cape man
Nice price on all the hatches! That'll look great! The r-5 is not a lot, but will keep ice for a day no problem. I have no insulation and I loaded my locker with ice on Friday afternoon, and Sunday still had ice cold water with a few cubes left in it at Boca.
Couple of comments on where you're at. Some you may like, some you may not...
In this picture I see where you haven't removed all the drywall screws yet, and the one in the center is going to be a bitch to get out. If you don't/can't remove all of the them, at least make sure you cover them completely before sealing that deck down. Remember the whole discussion on Clovis rusting
In this case I would agree and not want a bare screw head on the cleats...
Rounding out the corners of the baitwell will really help in keeping them happy, especially if you use any of the Gulf herrings (threadfins, scaled sardines, "green backs". etc). If you want to do it I can post how I made fiberglass rounded corner inserts for mine. TJredfish also did the same on his FS18 up in Tallahassee. Not a huge deal, but now's the time to do it if you want.
The XF20 is probably the shallowest running outboard driven boat I have ever been in, but does pound significantly when running into a chop. I would take the time and add the corner blocks as Joel suggests to all your cleat joints. I also would add more support under the fuel tank to fill in the gaps between the slats you have, put a piece of neoprene under it, and strap that baby down as secure as possible. If these are the hold downs that you don't have enough wood for, can you cut the lower, horizontal ends off and drill new holes to get them to fit?
Moeller also has kits like these which you can easily make yourself.
We just installed a 27 gallon tank under the console of the boat at work and used heavy duty nylon ratchet straps to secure it to simple "U" brackets using the "S" hooks on the bracket. Need about an inch of clearnace on the sides for that. The console is wide open so we can replace the straps in a few years if needed, something you will not be able to do...
Whatever you decide, just keep thinking about all the forces created, especially up front as that boat is hauling ass across a tight chop. You don't want anything moving under that deck or it will for sure come loose after prolonged use.
Looking good man!
Posted: Sun Sep 19, 2010 9:47 am
by majorgator
This is Joel's diabolical plan to get me to purchase more gelmagic
Take a look at the first picture on my last post of the rear deck. If you look real close, you can see a few blocks placed beneath joints. Upon further thought, though, I think more strength can be obtained by placing the blocks on the sides, as you suggest. Hey Joel, another order coming this week
Thanks Macs, but the vertical area between the tank and deck is actually quite large. I could build a wooden frame for it, though, with the same concept. However, sometimes the easiest answer is right in front of you..
...you could add a strip of wood to each side of the stringers and use the aluminum Moeller brackets....
I think this would be the easiest method...just not sure why I didn't think of that
Hey, I've got plenty of plywood scraps
I could just fill in the gaps completely, and maybe place a few pieces of 1x2 SYP on edge beneath that. I agree with you that this boat beats the water hard and should have plenty of support and good fastening. I was planning on putting some neoprene in the anchor locker to prevent damage to the hull, but neoprene under the tank would probably be nice too.
Thanks for the compliment. The layout has consumed me for the better part of the summer, I'm just happy to have it figured out now. And Red will have some company in Boca for sure. I'll be fishin' the criks with 'er in the winter
Thanks to Marine Surplus in Sarasota. Its one of those places that has just about every nick-nack you need to "outfit" a boat. No plywood, epoxy, glue, good paint, etc. though. They have about a million hatches though. I even picked up a seat from there the other day that I will use in lieu of a leaning post. More on that later, but it's gonna be sa-weet. About the R-5, I read a little about the "fancy" coolers that are being produced now. From the best of my research, it looks like they're getting a rating of about R-7. I know their technology is going to be better than mine, but whatever, I might just put two thicknesses of of the foam on. This will make for R-10...theoretically.
There you go again with those darn clovises in crevices and push-button winterization theory
Yeah, I haven't glued the front framing yet, so those drywall screws are all that's holding it together right now. I will remove them all eventually, and for those that are hard to access, well, I'll just switch over the clamps.
Yes, please do post that, or send me a link to the page that describes it. The majority of the bait that will be swimming in there will be pinfish, and those jokers are as tough as any bait I've ever seen. But I do want to keep my fishies lively
edit - I just re-measured the livewell and fishbox.
Livewell = 17.5 gallons
Fishbox = 121 quarts (approx 30 gallons)
seth
Posted: Sun Sep 19, 2010 11:13 am
by cape man
The corner inserts start here and about 3 pages later there's more on installing them.
http://forums.bateau2.com/viewtopic.php ... &start=420
Posted: Sun Sep 19, 2010 11:50 am
by Aripeka Angler
Dang, I should have been paying more attention. I have some quarter round ply that would have worked great on the corners of your bait tank. You could probably still use it if you backcut the ends....
Posted: Sun Sep 19, 2010 5:28 pm
by stickystuff
On fuel tank fastening I used on my now boat some nylon strap material 2" wide. had velcro sown on it so when you fold over strap it sticks together with the velcro. Just screw the straps down on the floor and fold over the tank and fasten with the V-cro , or you can use some battery type straps. Very simple solution and don't have to worry about steel straps. I have some Moller tank straps and they aren't worth a dime in my opinion. Will take some pictures of my tank and send them to you.Send me your e-mail address.
oken@bellsouth.net (my address)
Posted: Mon Sep 20, 2010 11:21 am
by pole-position
As a suggestion, I would take extra care making sure the gaskets @ the bait tank are completely leak-proof---it's not a lot of fun sitting on the top of one and getting your butt / back of your legs soaked.
Posted: Sun Oct 03, 2010 7:20 am
by majorgator
Not much posting lately, but been taking care of plenty of little things that aren't really picture worthy. Here's a little update:
I'll start with a goof-up. What's the quickest way to paint your boat? I was working on another project and sat a quart of paint on the boat for just a second. When I reached for it, my fumbly fingers didn't disappoint. So there's now about 1/2 quart of banana yellow in the bilge/anchor locker. I got most of it picked up with a paper towel, but just smeared the rest of it around. Its house paint, so it should mostly sand off in about 10 minutes.
Here's the livewell with 1 coat of hi-build epoxy primer. Its not Sterling or System 3, but rather a different brand of primer. Goes on thick, has HIGH VOC's
and retains its odor better than any other paint I've ever used
Anyway, sorry to Craig, I didn't go with the rounded corners. I had a piece of 3" pipe and began the process as you described. Either my impatience or incompetence got in the way, and it didn't really work out. Oh well. I'm going to compensate with some LED's in there, so maybe the bait will be able to see around
Most of my baitfish are pinfish, you can throw those jokers on the deck in the hot sun for an hour and they'll still be able to swim on a hook
The fishbox was easily removed from the boat, so I did all the fiberglass work on it while on sawhorses. I was able to flip it upside down to get the top work and sides done, then only had to tape the bottom seams through the hatch hole. It too is painted with a single coat of primer. I coated the outside too just for good measure, even though the foam insulation will cover it. I did some fairing for both the livewell and fishbox, and that turned out well. Both boxes are going to have a finish coat of epoxy paint, light blue in color. I recently saw a livewell that was painted light blue on the inside, and I just couldn't help myself. Even though the epoxy is hi-build, I'm still going to add a 2nd coat. In the 2nd picture, you can see the backside of the front bulkhead has the primer. All of the bilge area will receive this coating, including the framing.
Here's the transom. I placed 2 boards on the transom for mounting things like jack plate pump and fuel filter, plus anything else. This will save me from having to mount anything directly to the transom.
Here are the chase tubes. I've got a 4" pipe for the steering and throttle/shift. I had a bad experience one time with a chase tube that I couldn't get a steering cable through...won't be a problem here.
Running along side the 4" chase is a small 2" chase for the fuel line. On the other side is a 3" tube with a "wye" fitting in the middle. All electrical wires will run through here. I ran it to the front for things like bow light, fuel sender, and anything else I feel like doing in the future.
For the upcoming week, I plan on (plan being the theoretical word) finishing the small amount of framing left to do. When that's done, I'll coat the bilge with the primer, then begin to drill some thru-hulls and mount some equipment. Hopefully, I'll have a chance to fit the decks next weekend. Also, I put some primer on a small spot of the exterior of the bow. I did this so I can test a paint product that I acquired. The product should be OK, but I will certainly be testing it on a small area so I'm not sanding the whole boat if it doesn't work out
seth
Posted: Sun Oct 03, 2010 8:09 am
by macs
Just curious, what are you painting banana yellow?????????
Macs
Posted: Sun Oct 03, 2010 2:19 pm
by majorgator
Haha, kinda shown in the picture below, its part of a changing table for my babies.
seth
Posted: Sun Oct 17, 2010 7:44 am
by majorgator
Still moving along, doing all kinds of little things that don't really appear significant. Kind of reaching that point where I go out with a good plan, then deciding that something else needs to be done first, and at the the end of the day, I don't feel accomplished
But such is life
I'm still working on the final touches of the framing, so I decided to go ahead and fit my sole so I could mark out the last bit of framing. I took all the measurements for the sole and drew it in AutoCAD so I could be more precise. This big sole takes 2 sheets of plywood. I marked several locations, then curved a 1 x 2 over the radius to make the final mark.
The next few pictures show the main decks fitted, but not installed. It really gives you an appreciation for just how much deck space there is on this beast.
While I was drawing the sole in AutoCAD, I also drew up a console that used just a single sheet of plywood. This is a 28" wide by 36" tall console. Its a touch wider than most standard consoles, but that's what I wanted. It'll fit this wide boat just fine. The top shelf is 6", enough for a radio and other instruments. The Instrument panel is also 6", which is enough to flush-mount most Humminbird machines. I cut the pieces out, but haven't fitted them together yet. There's no front seat on this console, because I'm going to be using a cooler seat. If anyone's interested, I can send you a scaled drawing of this.
Question/Thought/Inquiry:
With the decks going in place, I'm going to need to make the cutouts for the hatches. Each hatch has framing around its opening, so the cutout needs to be precise. I'm hesitant to make the cutouts prior to installing the decks, but I might also have a hard time doing it once they're installed. Any simple tricks or ideas to see this task not become more complicated than it needs to be??
seth
Posted: Sun Oct 17, 2010 9:13 am
by cape man
Seth,
Cut them out before you install the deck and just measure twice and cut once. Your fit looks dang exact so you shouldn't have a problem. Maybe mark out the frame and cleat pattrern on the ply just to feel safer. Shouldn't take long. If hesitant, I'd cut out one with the most leeway (i.e. most space between the frames and cleats) and see how it goes. Cutting it after will work but I think it would be easier to cut them first...that's what I did.
Posted: Sun Oct 17, 2010 9:18 am
by macs
Craig posted in before I wrote this, I agree, your measure ments look great on the edges of the sole, so you should be able to cut them out first. or............. you could .......
Your using the manufactured deck hatches, so I'm assuming you will not need the wood you cut out to use as a hatch. I would just make sure you find the middle of each hatch or at least not close to one of the edges and cut a large hole with a hole saw bit, then you can accurately mark the edges of each hatch and cut them out with a jig saw, if that makes since.
The conole looks good BTW. I made mine wider than I Probably needed to. If I had it to do over again I would have shaved off an inch or so on each side to make walking around it a bit easier. We made our helm seat 36" wide so we could both sit comfortably on it. She's not big but my but sure is.
That determined where the sterring was to be centered on the port side of the console which in turn decided how wide the console needed to be, sort of
The cuts for the sole look good, you did that with a cad, that's cool. I made cardboard template to do mine. I was too scared to trust the measurements
Looking good
Macs
Posted: Sun Oct 17, 2010 9:21 am
by macs
I cut mine out first also, but the edges of my hatches weren't close to any under deck supports, not very close anyway. I made my hatches out of the peices that I cut out, so I had to make the cuts as straight an smooth as possible.
Posted: Tue Oct 26, 2010 1:08 pm
by majorgator
Thanks Craig and Macs, I'm going to give it a shot this weekend. Since the decks are so large, more than a single sheet of plywood. All of the frame openings have relatively precise framing around them, so I think I can reach underneath and scribe at least one location, then flip the panel back over, lay the hatch in the extents of the markings, lay out the corners, then cut. When I lay the deck panel back in place, I can reach through the opening I just cut to scribe the next, then so on with the other openings. Hopefully, that sounds good enough to visualize.
I ordered some heat shrink fittings the other day, then realized that I didn't order nearly enough. I'd rather have a surplus of heat shrink fittings so I'm not tempted to grab a standard terminal fitting in a pinch if I were to run out. Here's the 2nd order (free shipping, so it doesn't matter how many times I order). On the left are the hot and ground posts. The battery and motor ground (and main ground for accessories) will run to a single post. The hot wires from the batteries will go to the switch then the opposing post, and the hot wire for the motor and other accessories will run from that post.
seth
Posted: Tue Oct 26, 2010 1:46 pm
by cape man
Good thinking! Wish I had thought like that...
Posted: Tue Oct 26, 2010 3:54 pm
by Uncle D
majorgator wrote:I ordered some heat shrink fittings the other day, then realized that I didn't order nearly enough.(free shipping, so it doesn't matter how many times I order).
Where did you order from?? Don
Posted: Tue Oct 26, 2010 4:34 pm
by majorgator
http://www.bestboatwire.com/
You will have to redirect to:
http://genuinedealz.com/
To give credit where credit is due, I believe this site was originally recommended by Cracker Larry. I placed the order last Thursday, it arrived today. My first order was about 1 week shipping time. The splices I've already installed shrunk down real quick and cleanly with nothing more than a lighter. They appear to be good quality.
seth
Posted: Sun Oct 31, 2010 9:17 pm
by majorgator
Posted: Sun Oct 31, 2010 9:47 pm
by sitandfish
"Hatches? We don't got no hatches. We don't got to show you no stinking hatches!"
Did I get that quote right from
The Sierra Madre?
I like that seat (not shown in this picture), too. Looks real comfortable. Great idea.
Posted: Mon Nov 01, 2010 11:58 am
by Dog Fish
Looking good Seth, your little one sure makes your build look huge. a giant marine playpen, Very cool
Could you do me a favor and give me the measurement from the sole top to the top of your rear deck. Thank you. Also did you use the same stringer and sole height and hull sides as per the plans, Thanks again Seth. Looking good.
Brian
Posted: Mon Nov 01, 2010 8:15 pm
by majorgator
He just runs around stomping his feet on it, totally amusing to himself
FYI -
The sole to the top of the rear deck is 11 1/2". From the sole to the ground, its 8 1/2". I used 4 stringers instead of the 2 called for on the plans. I placed the original 2 in the locations shown on the plans, then split the difference on the other 2. The stringers are built as shown on the plans, and I put a 3/4" x 1 3/4" (really a 1 x 4 ripped down the middle) on top of the stringers and going across. Hull sides are per plans. The deck and sole are not really as shown on the plans, I just made it up as I went along at that point. The rear deck is approx. 5'0", then the sole is about 7'-6" and the front deck is about the same. The transom is different vs. what's on the plans. If you need info on that, let me know. See the pictures below for more info on stringers and framing...
Framing on the above picture was not complete, but I think you can get the idea
seth
Posted: Mon Nov 01, 2010 8:46 pm
by Dog Fish
Thanks much Seth, That's the info I was looking for, good deal. I think you will be glad you went with that little extra sole height.
Brian
Posted: Tue Nov 02, 2010 7:29 pm
by majorgator
Richard actually recommended it to me in order to help with proper deck drainage. It does make the rear deck a little easier to step up to
Posted: Tue Nov 02, 2010 11:39 pm
by Uncle D
majorgator wrote:Where did you order from?? Don
seth
Thanks, Seth. Someday I'll get to the point to where I can order some. Don
Posted: Mon Nov 15, 2010 9:26 am
by majorgator
Had a little fun this weekend...got all the preliminary wiring done...
The larger cluster goes to the stern end and the smaller goes to the front. Each cluster has about 8 additional spare wires. Battery switch installed (connected via option 1 in my other thread
Front deck glued, second half of sole glued...
seth
Posted: Mon Nov 15, 2010 9:43 am
That's a serious mile stone there, looks great
Did you have those battery cables made up by the Genuinedealz site? That's what I did, and they sure did a nice job. Much better than I could do for sure
Posted: Mon Nov 15, 2010 2:16 pm
by SmokyMountain
Looks great Seth... I know you are excited. Are you going with pre-made hatches or making them yourself?
Posted: Mon Nov 15, 2010 2:19 pm
by cape man
Whoooo HOOOOOOO! Looking great man! Boca Grande here you come!
Posted: Mon Nov 15, 2010 4:33 pm
by majorgator
Cracker Larry:
Yep, they made them for me, and sent me all the heat shrink fittings, the stud post shown in the other picture, plus a few other things. I think I've spent about $300 with them over the last few weeks
Its not that I need all that heat shrink, but even in 10 and 25 packs, they still have the best prices.
Thanks Andy. I'm going with the pre-made hatches. Scroll back a page or so and you'll see them, but here's a taste...(warning, I like me some hatches)...
Thank you thank you...she will see some nice water in Boca Grande
Hey, I picked up a job right off the interstate @ exit 240 Sun City Center. Not far from your workplace. Wanna do lunch soon? My treat
seth
Posted: Mon Nov 15, 2010 5:35 pm
by cape man
Send an email and I'll give you my cell number "cawatson at ufl dot edu". I'm always good for a free lunch!
Posted: Thu Nov 18, 2010 6:50 pm
by Aripeka Angler
Hey Seth, you are making good progress. You are on the downhill now, you will get her done by Spring for sure
,,,,and the way the our Gators are playing now, you should be getting alot more done on Saturday too
Keep it going now, Red wants some company next year at Boca
Posted: Fri Nov 19, 2010 7:41 am
by majorgator
I'm going to try to fit the jack plate today or tomorrow. There's nothing stopping me from getting the rear deck glued down this weekend.
...and the way the our Gators are playing now, you should be getting alot more done on Saturday too
Aint that the dang truth
After sitting through that misery last weekend, I think I'll just turn on the radio in the garage to listen to this week's game.
Oh, she'll get it alright. The only thing that might put that in question is if I don't quit dreaming up new things to do on it
seth
Posted: Sat Nov 20, 2010 9:01 pm
by majorgator
Posted: Sun Nov 21, 2010 7:27 am
by Aripeka Angler
Looking good Seth, your boat will easily be ready for Boca
That is some serious rock in the picture
I also copy/posted the picture to remind you to notch the deck back and join the gunwales somewhere other than at the bulkheads. That is a popular spot for cracking on XF-20 boats....
Posted: Mon Nov 22, 2010 5:30 am
by majorgator
Haha...I actually had a good plan for that. I remember the conversation you and I had about this when you were refinishing your XF20. The gunwales are going to be 8", so I went about 8" past each bulkhead and put in some extra framing. What I didn't realize was that the theoretical cut for the gunwale would be in excess of 8' (more like 8'-10") which would then mean I would have to have a splice somewhere along the way. I decided to glue the decks in place to the edge of the bulkheads, and when I get ready for the gunwales, I'll just take the skill saw and notch out about 1/2". It won't be much, but still better than nothing. I'll make sure to get a cleat glued onto each bulkhead for extra support.
I'm currently trying to devise an "under-gunwale" rod storage design. Maybe I'll enclose the front half of the gunwales and put tubes in place for the rods with racks on the back end
seth
Posted: Mon Nov 22, 2010 6:57 am
by chopperman
Seth,
I really like your livewell window/hatch. Well designed
Posted: Mon Nov 22, 2010 6:53 pm
by cape man
That's what I did on the starboard side for three rods. Wish I had done the same on the port side. There I didn't install the tubes. On the list when I go back and do some "redos". Used heat gun to gently bend the pvc tubes.
Posted: Tue Nov 23, 2010 8:53 pm
by chlli willie
You are making great progress! I'm about 2 months behind you.Would you mind recommending where to buy the fuel tank?
Also are you building your center console or buying one? Thanks ,and keep your momentum going your doing great.
Posted: Wed Nov 24, 2010 8:40 am
by majorgator
Thanks chopperman. I was planning on using a simple hatch cover, then I came across that clear window hatch in the discount aisle. It has a rubber gasket on the bottom and all the hardware. It should work out pretty well.
I've got nearly 8' between front and rear bulkheads, so I planning on enclosing about 4' of that...I think
I'll only be able to get 2 rods on each side due to the height of the side-wall.
Chilli Willie wrote:
Would you mind recommending where to buy the fuel tank? Also are you building your center console or buying one?
I got the tank from BassPro. I had a gift card and coupon and free shipping (I think) so all together it was only a little more than $100 to the best of my memory. Its the 18 gallon Moeller tank. Richard used the same one, I believe. For the console, I couldn't find an affordable one that I really liked, so I decided to build my own. I drew up a design to utilize 1 sheet of 4 x 8 plywood and then cut the pieces out. Its about 28" wide by 36" tall. Here's the picture I design I posted a while back. If you're interested, I'll be happy to email you the dimensioned drawing.
seth
Posted: Tue Nov 30, 2010 10:13 am
by chlli willie
Thanks for the offer, I'm in the design layout stage right now ,so you know what mental tug of war is going on inside my head.
I'm leaning towards a leaning post and a taller center console right now and the positioning of the various hatches ,baitwells
coolers and everything from conduit sizes to fuel tanks.
Posted: Tue Nov 30, 2010 4:22 pm
by majorgator
I'm leaning towards a leaning post and a taller center console right now and the positioning of the various hatches, baitwells, coolers and everything from conduit sizes to fuel tanks.
I can't even begin to tell you much time I've just sat there, thinking, mind wandering, dreaming, coming up with crazy thoughts. I might be done by now had I just focused in on one thing and did it. I like my baitwell where it is, but the only problem it created during the design stage was the routing of the chase tubes. Because the baitwell sits so close to the tunnel, I had to run the chase tubes on either side of the middle stringers. I would have preferred them turn straight up under the console, but hey, what's it matter. IMO, though, there's enough room in this beast to run all of your chase tubes straight vs. having to insert any bends.
seth
Posted: Mon Dec 13, 2010 6:41 am
by majorgator
Posted: Mon Dec 13, 2010 11:03 am
by cape man
WOW! Now you're cooking with Gas!!! Looking good!
Posted: Mon Dec 13, 2010 2:02 pm
Excellent progress Seth! Nice work on the gunwales.
Posted: Mon Dec 13, 2010 8:58 pm
by Aripeka Angler
Picked up my boards last week from Richard. He joined a an 8' piece of ply with a 15" piece to make one long panel for my gunwales. Thanks again Richard!
You are welcome
You have made some great progress too
You are in the home stretch now, keep up the good work...
I like this picture...
I love to see scrap under the saw horses. You can be sure that that some work is getting done
Posted: Tue Dec 14, 2010 8:46 am
by topwater
Nice work, i am learning something new every day here.
Posted: Tue Dec 14, 2010 2:17 pm
by majorgator
Thanks everyone
You'll also notice the laundry basket right next to it. I throw all the garbage scraps, mixing cups, chip brushes, and other related stuff in there...then off to the burn pile. If I didn't do that, I'd have a mountain of scrap material
seth
Posted: Sat Dec 18, 2010 9:17 pm
by majorgator
Posted: Sun Dec 19, 2010 7:10 am
by TomW
Nice work Seth!
Posted: Sat Dec 25, 2010 9:04 pm
by majorgator
Posted: Sun Dec 26, 2010 6:03 am
by cape man
shelf-riser-hump thingy
I always wondered what they called those things...
Posted: Sun Dec 26, 2010 6:17 am
by AussieBoater
That needs to be added to Jacques' boat terms thread.
Posted: Sun Jan 09, 2011 7:18 am
by majorgator
I thought that most of this cold weather was gone, but its in the low 30's when I woke up this morning. All that REALLY cold weather we've been having has surely slowed my progress
Either way, I was able to sneak out late last week and lay the fiberglass on the sole. It went on real good, but I did end up with some tiny air bubbles. My guess is because the weather was still a bit on the cold side, it made the epoxy run a little thicker, which led to me putting a little too much on, which led to the outgassing bubbles. Just a little frustrating, but that's why they make sandpaper
Just a shot of the floor at the chase tubes...
The gunwales are now complete and glued in place. While they were still upside down on the sawhorses, I wrapped some 6 oz tape over the edge. Now that they're installed, I wrap another layer of 6 oz tape over the top edge.
After sanding the sole and the gunwales glued in...
In an effort to get this thing done faster, I figured that I'd get started on the console. That way, I can work on it while epoxy and fiberglass is curing on other areas of the boat. Its lined up on the bottom, but not on top yet
I'm trying to determine (advice requested) if its necessary to tape the inside seams of the console
My guess is "no".
Hey, I'm starting to get the hang of this fiberglass work
seth
Posted: Sun Jan 09, 2011 12:49 pm
by wegcagle
Seth
I asked a similar question about not fiberglassing the inside seams and the overwhelming opinion was to definitely fiberglass the inside and outside seams. The console takes a good beating . Plus people have a tendency to hold on to it. So it needs to be built strong. I fiberglassed the inside and outside seams and put 6 oz cloth on the outside (probably overkill).
Will
Posted: Sun Jan 09, 2011 9:53 pm
by chicagoross
I'd filet and tape inside, then router a big bevel on the outside and tape that too. Looking good!
Posted: Sun Jan 09, 2011 10:50 pm
by SmokyMountain
Looking great Seth!! I concur with the other opinions, and I looked at my console plans and it says tape the inside on a 3/8" fillets. Can't wait to see it in Boca!!
Posted: Mon Jan 10, 2011 8:01 pm
by Aripeka Angler
Nice progress
Think overbuild on the console, you won't be sorry...
Posted: Tue Jan 11, 2011 9:07 am
by majorgator
Thanks everyone. I'll go add a single layer of 6 oz tape to the inside seams, I think that should be enough. The outside seams are one layer of 12 oz tape and one layer of 6 oz tape.
seth
Posted: Tue Jan 11, 2011 10:00 am
by Prarie Dog
Majorgator, what kind of ply is that you are using on your console? On my console I used half inch Meranti and filleted and taped the inside seams. This console was built early on and I really wasn't that pleased with it, so I tried to break it. Couldn't break it. I jumped on it - 220lbs, my kid jumped on it, backed into it with the pickup, finally gave up and put it in the boat. I think our natural tendency is to overbuild but we should remember that a fillet and a layer of 12 ounce is a really strong joint. Especially when it is in a unit that has multiple planes of shear any way it can get loaded. Haven't had a collision with my boat yet where the console gets hit by two or three fattys, if that caused it to break that might be a good thing and save a broken bone or two.
Regards, Paul
Posted: Tue Jan 11, 2011 11:51 am
by majorgator
This is just a standard, run-of-the-mill 1/4" marine plywood. I used Meranti everywhere else, but didn't see the need to get an entire sheet just for this. Its not nearly as good as the Meranti, but it will work just fine for a console
seth
Posted: Tue Jan 11, 2011 12:01 pm
by Prarie Dog
Cool, if it's quarter inch it's probably a good idea to tape both sides. That's good looking ply but not available here. Is it fir?
Posted: Tue Jan 11, 2011 12:40 pm
by majorgator
Yeah, I'll tape both sides then a run a 12 oz biax mat over the exterior. I would run 6 oz, but the 12 is what I've got
And actually, the plywood looks good but its pretty crappy. There's lots of knots and voids in it (compared to the meranti). I'm not sure what the species is, but I don't think its fir.
seth
Posted: Tue Jan 11, 2011 12:46 pm
Yes, tape both sides.
There is a lot of stress on a console: imagine one big guy hanging on to the wheel and another one to a grab handle when the boat hits a wave.
Consoles have to be very strong and should be strongly bonded to the sole and/or framing.
Posted: Tue Jan 11, 2011 3:51 pm
by mrtwrrt
Seth,
I really like the way your boat is coming together, I tried sending you an email don't know if I sent it correctly or not. I would like to talk with you and possibly see your boat if OK with you. I have the plans and a partially built xf20 hull that i plan to get started on soon. Would like to pick your brain on things that you would do differently if you was starting over. I see your in the High Springs area so it would not be to much as I am in the Ocala area.
Troy
Posted: Tue Jan 11, 2011 6:39 pm
by stickystuff
I live in.d unnellon. Their also is a Dunnellon XF20 builder here also. He goes by Chillywilly. I know the XF20 inside and out. e-mail me if you have questions and I will give me my ph. #
Posted: Tue Jan 11, 2011 6:41 pm
by stickystuff
Posted: Wed Jan 12, 2011 1:04 pm
by majorgator
Hey Troy...
I'd be happy to talk with about my build, and let ya take a look too. Sorry, I didn't get an email from you, but either way, just shoot me another one: sethgs0982 at gmail dot com. You could also talk to Ken. Since he was the co-designer, he should be a pretty good source
I think chilly willy is slightly behind me on progress, but he doesn't post too often. I may not be as good of an example as some of the other guys, but I'll be happy to help you however I can.
Seth
Posted: Thu Jan 13, 2011 9:30 pm
by chlli willie
majorgator wrote:I'm leaning towards a leaning post and a taller center console right now and the positioning of the various hatches, baitwells, coolers and everything from conduit sizes to fuel tanks.
seth
I"m still here 2-3 months behind,having the"Visions of Gandeur" The hull is done ,3 layers graphite,sides primered,flipped, stringers glassed, framing in the stern, just got my fuel tank yesterday ,I need to layout the hatches and baittank, Ken came over last week and answered so many questions I don't know what to do next. Like you said If I just picked one thing and done it ... Thats the irony of a first build i hope.
I'm thankful to you Major for posting frequently,that keeps me on track. If I can help any builders new or old my e.mail is
willieo at live dot com.
Posted: Fri Jan 14, 2011 7:27 am
by majorgator
chilli willie wrote:
The hull is done,3 layers graphite,sides primered,flipped, stringers glassed, framing in the stern, just got my fuel tank yesterday, I need to layout the hatches and baittank...
Man, sounds like you're cranking it out
Will she be done by Boca time?? This cold weather has really set me back. I've been moving my epoxy indoors overnight when I expect to use it the next day. Are you going with a similar layout as most of the other people (fuel tank up front, full rear and front decks, etc.)? What did you decide to do about the bait tank?
seth
Posted: Tue Jan 18, 2011 9:53 am
by chlli willie
The cold weather,flu season,NFL,teenage daughters, there's lots of things that take up time and money. As far as the baitwell
goes I'm leaning towards building my own CC and puting the well at the front of it, that way it will will even the weight and
be easy to get to from the front deck . If there are any negative effects from this anyone knows of please tell me. I'm thinking Boca might be out this year unfortunately ,maybe next year.
Posted: Tue Jan 18, 2011 10:13 am
by pole-position
chlli willie wrote:The cold weather,flu season,NFL,teenage daughters, there's lots of things that take up time and money. As far as the baitwell
By locating the livebait tank that far forward, I'm afraid you would beat them to death, especially in a flat-bottomed boat.
Posted: Tue Jan 18, 2011 10:20 am
Yep, especially white bait and other fragile species. I wouldn't do it myself. The XF has a ton of room to put it somewhere else.
Posted: Tue Jan 18, 2011 11:34 am
by chlli willie
Well ,I guess I could put the well just above the front of the tunnel like Major, and put a cooler seat in front of the CC.
Posted: Tue Jan 18, 2011 5:02 pm
by majorgator
Yep, that's what I'm doin alright, with the livewell and cooler seat. If you read through some of the earlier posts on my thread, I went over the same dillemma about where to locate the livewell. I personally don't think that placing in directly in front of the console is a bad place, that's where Richard has his. If you're willing to sit someone in front of the console without being concerned over their comfort, then I wouldn't worry about the bait
I toyed with putting it in the bow, but then came to my senses realizing the rough-ride that area sees. Another factor in my planning was weight. I have a large insulated fishbox in the box, plus a large, long-shaft, heavy trolling motor with 2 batteries (though they'll be small trolling batteries) and a 18 gallon fuel tank. The console is close to the middle, and the livewell is just in front of the tunnel. If anything, my boat may be a bit bow-heavy, but I'm not too concerned about it.
seth
Posted: Sun Jan 23, 2011 5:51 pm
by majorgator
I taped the transom a week or 2 ago. There are several overlapping layers between the rear deck and transom, plus a few strips to act as a "cleat". Don't know whether that makes any difference, but the epoxy was spread out there, so why not
I fiberglassed the rear deck too, but didn't get any pictures of it before I moved stuff onto to it:
Today, I taped the inside seams of the console...
For my switch panel, I bought the individual rockers from genuinedealz then found this blank panel on eBay. I only need 6 switches, but its got 8 slots so I purchased to plugs...
Found these little gems at the Marine Surplus. They're used on Scout Boats, but they'll be a nice addition under my gunwales. I got 2 sets.
Its starting to look on the up and up. The only fiberglass work left (besides touch-ups) is the front deck (easy), the console, and a strip down each gunwale.
seth
Posted: Mon Jan 24, 2011 5:33 am
by stickystuff
If you need more switches like those I have a bag full of them. some are lighted.
Posted: Mon Jan 24, 2011 9:52 am
by cape man
It's the home stretch now man!
Posted: Sun Jan 30, 2011 10:18 pm
by majorgator
Really gettin' it done now. On Friday, I completed all the fiberglass work on the main part of the boat (console is the only thing remaining to be glassed). Didn't get any pictures of that, but ironically enough, my last lamination turned out to be my best. Heck of a time to get it figured out huh
The console is now built, holes cut in the front and back for hatches. I still need to finish the fiberglass tape around some of the seems and laminate it too. There are some temporary screws in place in the areas where I doubled up the thickness; the screws are there to hold it together until the glue dries, then I'll remove them and fill the holes.
With any luck, I can get the trailer configured correctly and the boat placed onto it before the end of next weekend. I've got to get it out of the garage, according to SWMBO
Really though, I don't want to do any more sanding in the garage due to the dust, and I'm going to move it to my shop in town for painting.
seth
Posted: Mon Jan 31, 2011 9:50 am
by TomW
Seth nice CC! Any reason you didn't router the edges before taping it down?
Posted: Mon Jan 31, 2011 10:32 am
by majorgator
Thanks for accolades Tom. The only part of the console that is currently taped are the front and sides to the sole, and the exteior and interior seams for the front panel and 2 side panels...that's the easiest way to explain it, so hopefully it sounds understandable
I had previously taped those 3 panels (which have rounded edges) to the sole to establish the framework, then came back this weekend and pieced the rest of it together. After the glue sets up and the screws are removed, I'll take the router to all the other edges before any further taping.
seth
Posted: Mon Jan 31, 2011 11:14 am
by Aripeka Angler
Looking nice Seth
You have 4 months, you are going to make it easily. Have you decided what you are going to paint it with yet?
That is the way it always works
I didn't really figure it out myself until I rebuilt/repainted my XF-20. That is why you need to build another boat now
Maybe a really big one...
Posted: Mon Jan 31, 2011 12:22 pm
by majorgator
A long while back I purchased the S3 LPU whidbey white for the inside, so I'm just going to stick with that. For the outside, I purchased a paint product manufactured by a company we use frequently for industrial coatings. Its a high quality, durable, super high VOC (
) epoxy paint. I ran the product info by Joel, and he said it should be fine. I painted a sample patch on my bow transom a few months back and its REALLY hard and scratch resistant now. While the product has extensive test data, we're not real sure how it will react on a boat, but all indications are its going to be good.
When the other fellow on here began his CS 25, I looked long and hard into the study plans for it. But based upon the duration of this project and my wife's waning interest, it might be advisable for me to pursue another one anytime soon
seth
Posted: Mon Jan 31, 2011 1:52 pm
by SmokyMountain
Its a high quality, durable, super high VOC ( ) epoxy paint.
Is it TNEMEC paint?? We use that stuff at work for water tanks, bridges etc.. It's real durable but finicky.
Andrew
Posted: Mon Jan 31, 2011 2:37 pm
by majorgator
Andy, yes it is Tnemec. We build water and wastewater treatment facilities, and use Tnemec on about 90% of our coatings. The product I'm going to attempt to use is the Series 290 CRU. Its listed as semi-gloss, but its better than that...not as glossy as Sterling, though. Our rep told me that they did a test project with it in a sludge tank, and after a few weeks of total submersion, it still maintained its high-gloss look. We'll see....
seth
Posted: Tue Feb 01, 2011 8:14 am
by Aripeka Angler
Seth, the prop you were asking about on my boat is a Powertech model # FS4R12PYM90. If it will fit on your Yamaha motor, I will let you use my prop for your splash. I think it should fit, give the Powertech guys a call. Might be a good way to get dialed in without the buy and exchange, pain and suffering method.
I think it would be pretty cool if we had a prop loaner/trader/seller/barter exchange thread somewhere on the forum. Of course, if it was ok with Joel...
Posted: Tue Feb 01, 2011 8:18 am
Great idea Richard
Posted: Tue Feb 01, 2011 8:38 am
by Aripeka Angler
Thanks Larry
Maybe someone with an extra prop will pick up on this and get it rolling.
Posted: Tue Feb 01, 2011 11:02 am
by majorgator
Thanks Richard! I might very well take you up on that offer!
That's a great idea too! I've got an extra aluminum prop sitting around that I can add into the loaner system
I'll check it out when I get home and maybe get a thread started.
seth
Posted: Tue Feb 01, 2011 2:50 pm
by thb
Great idea on the props. I have several good evinrude/ johnson props which are not being used.
SS Rebel 15-1/2 x 17 RH for 250 etec with 15 splines
SS 14-1/2 x 19 LH for older evinrude 140 v-4, 15 spline
SS SST 13-7/8 X 19 RH for newer etec's 13 spline
Al 13-1/4 x 17 RH for newer etec's 13 spline.
Tom in Steinhatchee
Posted: Tue Feb 01, 2011 6:56 pm
by stickystuff
Seth, E-mail me at
okenatbellsouthdotnet. have some info for you
Posted: Tue Feb 01, 2011 7:48 pm
by TomW
Great idea I can run the numbers on the boat and motor, then borrow one of the props if there is one close, to see how close we are then get what you really need if it isn't right on.
Let's see if Shine can start up a Sticky on this subject depending on how many props we can put up for borrowing. Would want at least a dozen to make it viable. Thanks THB for your input!
Richard wouldn't have had to have prop repitched so mutch, Larry would not have had to have had to have had to gone through 3 props only one, Sorry Hiwsee you went the wrong way on CL's prop. It's still not right for what he uses the boat for most of the time for. Kurt got up with one prop change on his modified FS17 and F60 Yamaha.
Can you get it exactly right everyright no. These boats are not standard boats everyone is made different and are loaded different and powered different. So I always want the owner to have the option to make that one change to do the final tuneup. It maybe a 250 or so change that increases the rpms up a little higher into the range, even though the motor is in the proper range we just fine tune it a little. Here's an example: Motor optimum upper operating range 5000-6000. 1st prop 15 pitch 5500rpm's, 2nd prop 13 pitch 5900rpm's. Every 1" in pitch is about 2-250 rpm's.
Posted: Tue Feb 01, 2011 8:03 pm
What would you know about that? You've never even been on my boat
I bet it runs a lot better than yours
5800 rpms, 36 mph, 8 mpg
I was propping boats when you were a Navy ensign, doing accounting, copyright law, chemical engineering, green house farming, cabinet making, and all the other things you are an expert on. Go build a boat, Tom, then show us a picture of it.
Posted: Tue Feb 01, 2011 8:09 pm
by TomW
Cracker Larry wrote:Sorry Hiwsee you went the wrong way on CL's prop. It's still not right for what he uses the boat for most of the time for.
Give me a chance and you'll not even believe the difference in performance in your boat.
Posted: Tue Feb 01, 2011 8:11 pm
How about I run mine against yours?
Posted: Tue Feb 01, 2011 8:35 pm
by TomW
Soon!
Posted: Tue Feb 01, 2011 8:50 pm
Yeah. I'm waiting. Show us some pictures. Show us some of those boats you have built. Show us some you've restored. Show us the one you are building now. Show us some fish. Show us anything. And don't tell us again that the forum is screwed and you can't post pictures. Too much talk and not enough action.
Tom, I over look a lot of things, but for you to come here and tell everyone that my boat isn't propped right, when I've run it 400 hours in every condition you could imagine and some you can't, from Cape Fear NC to the Bahamas, and tried 4 different props, and you've never even been on my boat, it just boggles my mind
And you've already told everyone that my Yamaha was a piece of shit anyway, not sure how you know that, since you've never owned one, or any other outboard that we can tell
Uh-huh. Send me a prop, I'll try it.
Edit: Sorry Seth. My patience has it's limits
I'd give Ken a call, he invented the XF20
And Richard and a few other guys have been through some props too. Richards runs like a scalded ass ape in 6 inches of water, and I've run it myself in 4 " of water. It threw a little mud
He's got the same POS Yamaha that I do
Posted: Tue Feb 01, 2011 11:30 pm
by Doc_Dyer
Larry,
What exactly is an ASS APE
Sorry Seth
Posted: Wed Feb 02, 2011 12:48 am
It's not an Ass Ape, it's an ape with a scalded ass. They run pretty fast I'm told. No personal experience to back that up.
Posted: Wed Feb 02, 2011 2:31 am
by Ankle Deep
Larry:
Thank you!.........the bluster is very tiring....
Posted: Wed Feb 02, 2011 2:51 am
by TomW
Larry I can't let the above go unanswered. Sorry Seth for this getting into your build site. I'm going to try to be as objective as I can. Hopefully it will help some people. There are a bunch of numbers that go into the calculation of the prop recommendation that I do. Some the builder provides, some I get from the plans, some I get from the motor manufacturers.
Yes, but he had to have the pitch reduced by 3 to get it to work on his lack of torque 70HP Yammi. That same prop would have worked fine on an Evinrude 75 or Suzuki 70 without any reduction in pitch. The difference in weight would be meaningless with the XF20. He bought more cup than he needed to and then had to pay to have it reduced. Something to watch out for when your buying a prop.
Here are the torque at the prop for three motors:
Suzuki 70: 154
Etec 75: 139
Yammi 70: 122
As you can see the Yammi 70 has less than 88% of the torque of the Etec. and 80% of the Suzuki.
Larry since you started this discussion your big old black 17pitch prop with little cup or rake works fine for you but I'll tell you right now it isn't the right one for your normal flats fishing endeavors. 400 hrs is just getting the motor broken in good
The prop you have is a great all around prop especially for offshore use and probably saved your lives offshore in those big waves off the NC/GA coast.
If I were keeping a daily prop on for both fishing offshore and the flats I would keep it. If I were going to keep the boat for the flats I would change the propulsion system
Don't ever, ever tell me you know your prop is right for your boat. The only problem I have with your boat is the motor and the lack of torque. Get an Etec or Suzuki, or Merc and we'll discuss torque. Let's get real Larry some motors are made for some things some for others. Yammi's are fine for offshore, not for flats boats. Well maybe the 4st can be used for flats boats.
Heck I have put a 13 pitch on a Yammi 60HP 4st and it worked great. Much better prop than you have that gives better grab and fuel economy in the mid-range, better hole shot and top end.
Posted: Wed Feb 02, 2011 3:05 am
by chicagoross
I suspect CL will tell whatever, whenever, to whoever he feels like...
I also suspect he has enough boat, motor, and prop experience to determine if the combination is performing as it should.
Posted: Wed Feb 02, 2011 3:16 am
by Ankle Deep
Suzuki 70: 154
Etec 75: 139
Yammi 70: 122
You have no idea what goes into selecting a prop or what prop should be used in certain situations. Yep your big old black 17pitch prop with little cup or rake works fine for you but I'll tell you right now it isn't the right one for your normal flats fishing endeavors. 400 hrs is just getting the motor broken in good
....yawn!
Posted: Wed Feb 02, 2011 5:53 am
by majorgator
That's quite alright. I enjoy the banter from time to time
I too was perplexed by this combination, so I turned to google images...
My search for a simple "scalded ape" yielded an odd parody of Dog the Bounty Hunter and Michael Jackson...
OMG
Here we go again
I guess my only option left is to spend today searching Craigslist for an old Sears Gamefisher or Chrysler motor. Haven't heard anything bad about those, and if anyone has a weight/HP/torque charts let me know.
Nah, I've known him to be a more bashful guy about his opinions
Suzuki 70: 154
Etec 75: 139
Yammi 70: 122
Tom, at what RPM are those torques found
The E-Tec is the only motor I know of that advertises torque. Random torque numbers at unknown RPM's are useless. Also, since torque is a derivative of power, those numbers don't mean much unless the HP at that level is listed too. And once my boat is on plane and cruising, the amount of effective torque doesn't matter much anyway. But back to our argument from the other thread...apples to apples. My guess is the Yamaha you're using is a 2-stroke, the suzuki is a 4-stroke, and the E-Tec is, well, just different in a variety of ways.
seth
Posted: Wed Feb 02, 2011 6:12 am
by cape man
Get one of these and prop it with a 24 pitch 7 blade reverse cup titanium prop.
Posted: Wed Feb 02, 2011 7:07 am
by majorgator
Let me check and see if our new prop loaner community has one...
seth
Posted: Wed Feb 02, 2011 9:58 am
by TomW
Seth those torque numbers are calculated by the main prop program I use. It uses a percentage of top rpm so that it is more indicitive of real world numbers. There are some simple prop programs out there but this one runs 4 pages.
That is why I can tell CL he doesn't have the right prop for his primary fishing of his flats in SC and GA I can say so without an ounce of regret and why he needs his current prop for when he goes offshore. Why I can tell someone else he needs a different prop for his needs and someone else what he needs for what he wants to do for his primary use. There are so many props out there now that it is hard to keep up with the technology. Even some of the better aluminum props are thinner and cupped for better effiecency.
Oh yea Craig I may just have one of those setting back on the farm in Iowa!
Posted: Wed Feb 02, 2011 10:59 am
Unbelievable
I'm sure you've had a lot of experience fishing them on the flats too? Funny, but Yamahas are what you see on 95% of the guide boats on the flats. You'd know that if you'd ever been. And I'll tell you any dang thing I feel like when you are spewing this kind of crap about my boat, that you've never even been on.
Don't be expecting any fishing invitations, I'd hate for you to have to ride in a POS like mine.
Posted: Wed Feb 02, 2011 11:52 am
by cape man
Seth, sorry to add to the clutter, but need to post for others that might be reading this "discussion"
I thought a 4 stroke had less torque than a 2 stroke
But yeah these numbers are awful...
http://www.yamaha-motor.com/assets/prod ... 04_flt.pdf
http://www.yamaha-motor.com/assets/prod ... 10_flt.pdf
Imagine taking a whole 2.6 seconds to get on plane and another 4.6 to hit 30mph. I am so happy I didn't get a Yamaha...oh wait...I do have a Yamaha! Well just glad I don't use it on the flats...Oh wait...I do use it in the flats! Well then I'm just glad I never take it offshore with the same prop...Oh wait!!! I have run offshore!!
Tom, Slow down the next time you feel like you need to talk about motors you have no experience with. Your help with running prop numbers for folks here is greatly appreciated, and has helped many, including me, get close to where they need to go to optimize their engines performance. But you gotta get away from thinking that your calculations and theoretical numbers will ever replace real world experience and reality. For example, I started with a 13 pitch and only 4800 rpms. You recommended:
Craig go with the Yamaha Black Steel prop and raise the motor up 2 holes. This is the prop and height we ended up on Larry's. Make sure you can exchange the prop because you may even have to go to a 9 pitch. Each inch of pitch is about 200 rpm's so to go from 5100 to 5900 you need 4".
The prop tuner I used took 2.5" out and I picked up almost 1000 in rpm. Here's the discussion from my thread...
He also said (and the second prop person to say it) that he is finding the 200rpms/inch of pitch rule doesn't apply to the new 4-strokes, especially in the midrange like a 40 hp. He has seen as much as 500rpms/inch, but typically 250-300. All encouraging news. I am hoping for that magic 6000 @ WOT with two people on board. He'll be done Thursday, but I won't be able to pick it up till Friday at the earliest. Wish me luck!
Again, theory is great, the ability to crunch numbers and get close is helpful, but reality is what it is...real. You often post with such authority that someone new here might take it as gospel, and miss an opportunity to learn from others with more real world experience.
Posted: Wed Feb 02, 2011 1:45 pm
by TomW
Craig theory is useless if I didn't have the knowledge to make adjustments based on the type of boat and the main use it would be used for also. Will the guy be using it for the flats or offshore or a mix and how much of each. Does he need hole shot or top speed or good cruise? This is why I quit doing the prop calcs on the forum they are for each individual boat and individual motor and use. You have a general purpose prop and it works okay for you. I'll give a guy a speed range within 3-5 mph depending on the weights he supplies and then start the prop calcs from there. I'll run 3 different prop calculators and come up with a concensus. Then look at what his needs are and give him some options for props. Normally I have a couple of sources of Hi quality props that are $150-200 less than the dealers price so I give them those if they want to go that route. Some one like Kurt with that beautiful FS17 and F60 Yammi, how do you prop it. He had two baitwells in the stern. Was he going to use them all the time were they going to be empty most of the time, how do we account for that 25 gallons of water. That's 250lbs at the stern of the boat. We ended up assuming they would be full all the time, went with a smaller prop with stern lift. It ended up working great and worked out great also for tubing with his kids.
During this process I'm working with the guy from start to finish to make sure we are on the same wave length. And never do I let him think that the first prop may be exactly right and the sources given always have an exchange program.
You are right I am finding that the old 200-250rpm's has expanded to 300-400 in the 40-60HP 4st engines. I had to be careful of some of the older engines also as they also had an extended range up to 300rpms. The big 2st Merc's are one I can think of, the ones made here not the Yammi made ones.
I am always willing to learn from anyone that is willing to teach not preach
I admit I'm not as familiar with salt water fishing as I would like to be, but when it comes to propping a boat a bassboat and a flats boat are about the same, a jonboat and a GF/OD are similar and yes there are pointed bow jon boats. A Pursuit in the Great Lakes is the same as the ocean only the Great Lakes gets a lot rougher a lot faster so the prop has to be to be more capable in the lower speed ranges. Richard's Pursuit would be propped up one size in all likelyhood, he'd loose top end but gain low end control. Might also change prop design.
I'm no expert just someone that trys to help and knows his limitations, but isn't afraid to say that someone has the wrong prop on his boat. If Larry spent 50% of his time offshore and 50% flats fishing I'd have no problem with that but he doesn't. Last time he was offshore and he can correct me if I'm wrong and I'm sure he will
was with Dori in the Keys. I'm betting he spends 80% of his time on the flats or running to or from them or in the rivers around them. If he doesn't like that I said it, so be it, no skin off my hide.
I'm just stating an opinion, he has plenty of them!
I'm not the know nothing CL seems to make me out to be, I've owned plenty of boats and motors with or without my dad and father in law from Ohio to Iowa, 12-21' outboards and inboards plus ran a few in the navy up to 40' on my own plus a whole lot larger. Do I have pictures, no those were fishing trips no one took a camera. We went fishing and came back and cleaned them and ate them. Or if they were Lake Erie Perch had the 400 cleaned and came back split them up and ate part of them and froze the rest.
Pictures never have meant much to me or Deb's family.
Posted: Wed Feb 02, 2011 2:29 pm
by cape man
Never mind...
Posted: Wed Feb 02, 2011 2:32 pm
by TomW
cape man wrote:Never mind...
Yep
Posted: Wed Feb 02, 2011 2:45 pm
by Aripeka Angler
Don't drag me into this. You have absolutely no facts or reason to make the above statement.
Re: Majorgator's XF20
Posted: Wed Feb 02, 2011 2:55 pm
by Prarie Dog
Kinda glad we couldn't figure out what kind of prop my pos has on it.
Posted: Wed Feb 02, 2011 3:16 pm
He seems to know everything Richard, even how often I go offshore
The last time I was offshore was last Friday night, I went to Daufuskie at midnight by myself. And about 10 other times since the Keys. I'm a fishing guide Tom, and have been since the 1970s
You can BS all you want, maybe somebody will believe you, but you don't know crap about what I do, or how my boat runs. Please keep my name and my boat out of your future fantasies. I'm certain you know nothing about either.
Posted: Wed Feb 02, 2011 3:22 pm
by cape man
Hijack over!!! Last picture that Seth posted.
Quick Seth! Do something, anything! I am about to say something really ugly!
Posted: Wed Feb 02, 2011 3:27 pm
by Aripeka Angler
cape man wrote:Hijack over!!! Last picture that Seth posted.
Hey! Is that a stakout stick handle over by the epoxy jugs
Posted: Wed Feb 02, 2011 3:31 pm
I can take care of the through-bow bracket like Richard has
Posted: Wed Feb 02, 2011 3:36 pm
by TomW
Posted: Wed Feb 02, 2011 3:49 pm
Group hug
Posted: Wed Feb 02, 2011 4:04 pm
by cape man
Group hug
Yuck!
Posted: Wed Feb 02, 2011 4:26 pm
Well, now that you mention it
Seth, you might want to think about that stake out bracket and incorporate the backing plates into the build now
Posted: Wed Feb 02, 2011 4:55 pm
by TomW
cape man wrote:Group hug
Yuck!
How about beers in the bar at your place Craig!
I like group hugs on the internet though since it's hard to get together!
Posted: Wed Feb 02, 2011 5:03 pm
by TomW
And don't forget to figure out what type of jackplate you want. Hydraulic or manual. I picked the Jack's manual that can be converted to a hydraulic until I get a feel of how much I will use it. You can't use it in motion but you can adjust it on the water unlike some of the others.
And don't forget to buy them through Shine as we get 10% off.
Posted: Wed Feb 02, 2011 7:21 pm
by majorgator
I step away and look what happens
I'll just add the "prop" discussion to banned topics, along with any mention of outboard manufacturers, liberals, and sterling paint.
Been workin all day, on the road to Ruskin (no time for lunch, sorry)...up early tomorrow mornin and back on the road again to Naples for a few days. But now, I'm gonna go home and play with my babies, does that count
Sure nuff. Got it from some guy who has poor taste in outboard motors and props
Its got 2 coats of epoxy on it and probably another 1 or 2 to go. Even the wife commented on how pretty it looks. Thanks again Richard!
I am tempted...but I've a got a lot of stuff going on in the bow area. It's doable, but would be tight fit...
Already got a hydraulic Bob's jackplate. No point in going the manual route...I'm expecting to use the up/down function frequently.
seth
Posted: Sun Feb 06, 2011 8:19 pm
by Aripeka Angler
Do you have anything to share with us
Posted: Mon Feb 07, 2011 8:49 am
by majorgator
Why of course
Now that I'm at work again, I have some time to goof off and post some pictures
Got the beast loaded up on the trailer yesterday afternoon. I know she looks big sitting in the garage, and I've surely seen other renditions of this boat, but geez, this is one big machine...
It was actually quite easy. Using the rollerskates in the last picture, we lifted the stern corners to get them underneath, then placed another 2 about half-way up. We then pushed it to the trailer bunks, connected the winch, and pulled it on up. It was a big day for my wife, considering its been over a year since she's been able to park in the garage.
One thing I did notice is that it sits on the trailer a little bow-heavy. It doesn't actually touch the bunks on the very back. Next weekend, I'm going to build some bunks on the front to support the bow, which should help it quite a bit. Also, I may buy some shorter tires, but I'm going to wait to see how well it launches first. It sits up pretty high, but I've seen higher, and with the shallow draft, it shouldn't take much to float it off.
BTW -
I was excited to see how strong this thing is. When we were lifting, I expected to see some twisting, but it stayed true the whole time. Also, I'm happy I went with the 2 x 12 backer in the bow transom. There was ZERO flex in the bow transom when we were winching it up, and overall, the whole things seems rock solid.
seth
Posted: Mon Feb 07, 2011 8:54 am
by gstanfield
Wow, she is a large girl that's for sure
You said your wife gets her garage back, does that mean you are taking the boat somewhere else?
George
Posted: Mon Feb 07, 2011 9:03 am
by SmokyMountain
Looks great Seth!! I know you're excited. I'm putting mine on the trailer soon too.
I was thinking aircraft carrier.
Plenty of room to cast, have a party, land small aircraft or helicopters, drag huge redfish on deck...etc.. ..... and most importantly the kids have room to play while you fish
Posted: Mon Feb 07, 2011 10:35 am
by majorgator
...does that mean you are taking the boat somewhere else?does that mean you are taking the boat somewhere else?
Well, I'm going to leave it at home until the sanding and fairing is complete. Then for painting, I'm going to bring it to my shop at work so I can leave it indoors and have a large work area. Also, it will allow me to sneak out there whenever I feel like to work on it. We're going to start having "painting and rigging breaks" at work.
...and most importantly the kids have room to play while you fish
I can strap down a pack 'n play on the rear deck...
seth
Posted: Mon Feb 07, 2011 12:51 pm
by cottontop
Seth, tht is one bigggggg boat. You shouldn't hve to worry about running out of space to store. Great job!!!!! John
Posted: Mon Feb 07, 2011 3:04 pm
by cape man
Does the drive point towards Boca, cause she looks like she wants to go...
Congrats! Big step in the build!
Posted: Mon Feb 07, 2011 3:11 pm
Very nice Seth. She looks great outside where we can see the entire flight deck at once
I would support that bow section a little more. The GF16 had a similar overhang and I built a cross brace for support.
Posted: Mon Feb 07, 2011 8:27 pm
by majorgator
Thanks, everyone, for the compliments. I'm in that stage now where all I want to do is go outside and work on it, just wanting to see it finished.
Hey, all I got to do is plug up the holes, throw a motor on her and hit the road. Who needs sanded surfaces and paint? Hec, if I didn't do any fairing, it would have a natural non-skid finish
...the entire flight deck...
Aint that the understatement of the month
Yeah, I've seen how Richard did his, and now I've seen how you did it. Both ways work just well. Right now, it kind of teeter-totters. Its OK until next weekend, but I don't want to let it sit that way for long.
And about the Sterling:
The tutorial on here says the primer goes about 160 SF and the finish coat about 300 SF. Is that accurate compared to what ya'll have experienced? I guess I could just text Richard and find out, seeing as he has a pretty good example of a comparable boat
seth
Posted: Mon Feb 07, 2011 9:26 pm
by Aripeka Angler
Seth, here is a photo of how I supported my bow. I think it would be easy to do with the u-channel or a bracket like Larry used...
And about the Sterling:The tutorial on here says the primer goes about 160 SF and the finish coat about 300 SF. Is that accurate compared to what ya'll have experienced? I guess I could just text Richard and find out, seeing as he has a pretty good example of a comparable boat
I don't remember how much primer I used for some reason. The Sterling is easy, I used 22 ounces of the red paint and 50 ounces of the cream. That doesn't include the catalyst or the brushing thinner. I used almost 2 gallons of S-3 on the original paint job and I still wasn't happy with it.
Congratulations on getting her on the trailer!! Can't wait to see the finished boat
Posted: Sun Feb 13, 2011 7:09 am
by majorgator
Didn't get as much done yesterday as I had hoped, but still, moving toward the goal.
I decided that before I do too much walking around and standing in the boat while on the trailer, I needed to install the bow support. I went with this, similar to Richard's trailer, and I'll decide later if more is needed...
seth
Posted: Sun Feb 13, 2011 7:19 am
by macs
I agree, that boat looks a hell of a lot bigger outside in the open. I don't think she'd fit in my garage. Mines 19' and a break-a-way trailer tongue was the only way to make her fit. Looking good!
Posted: Sun Feb 13, 2011 7:15 pm
by wadestep
Hey Seth - the boat is looking great. What a big step - the boat is now mobile (albeit not on it's own bottom yet). looks like you're closing in on the home stretch!
Hope to see you in Boca Grande again!
wade
Posted: Sun Feb 13, 2011 7:53 pm
by majorgator
Posted: Sun Feb 13, 2011 8:16 pm
by Aripeka Angler
That is great news
She is looking great! I like the trailer support, nice work on that!! It won't be long now....
Posted: Sun Feb 13, 2011 8:34 pm
I propose a toast
That is a monumental milestone
There are good ships and wood ships, and ships that sail the seas. But the best ships are friendships, and may they always be.
Here's to ya
Posted: Sun Feb 13, 2011 9:36 pm
by cape man
Tipping my drink (coffee)!!!
Posted: Sat Mar 26, 2011 7:56 pm
by majorgator
Well, nearly a month and half since I last updated this thread. Doing so brings to memory a comment I made a while back:
Seth to Richard: "I'm not going to be one of those guys that spends a month fairing and sanding my boat."
I can't say that the last month and half has been all fairing and sanding, but its pretty much all I've done on it. Its an exhausting task on a boat with this much square-footage
I've been moving it back and forth between my house and my shop to try to keep it out of the sun, so here's some pictures of it in that setting...
I stiffened up the bow support bunk; I don't think its going anywhere...
Here's a shot of the boat with most of the topside fairing done. This was taken right before I sanded the sole.
Had to take a break from the fairing and sanding, so decided to fit my steering and throttle.
seth
Posted: Sat Mar 26, 2011 8:27 pm
by gstanfield
Looking very nice Seth, you're going to have one fish slaying, fisherman impressing family fun boat when this is done
Posted: Sat Mar 26, 2011 10:42 pm
by SmokyMountain
Seth,
Looks great!! Fairing that aircraft carrier is a major accomplishment.
It will look even better in primer.
Posted: Sat Mar 26, 2011 11:31 pm
by cape man
Clock's ticking...
Posted: Sun Mar 27, 2011 7:35 am
You've made a lot of progress since I saw it 2 weeks ago! Looking good
Posted: Sun Mar 27, 2011 9:09 am
by macs
Looking good Seth
Posted: Sun Mar 27, 2011 12:01 pm
by welyjr
I love this boat! I can't wait to start mine.
Posted: Sun Mar 27, 2011 4:48 pm
by Joe H
That is a lot of surface, looking good!
Joe h
Posted: Mon Mar 28, 2011 12:14 pm
by semperfly
I am very impressed with your build, so impressed that I am starting my search for some shop space to start mine. I have one question for you or any of the other experienced builders...I have looked at a few of the other builds that are being done and am curious. Did you pour any foam into the cavity or did you leave it hollow to shave weight or cost? I have some other qustions in general about the XF20 but will ask those questions in another thread. I dont want to hijack your thread with newbie questions.
Posted: Mon Mar 28, 2011 1:06 pm
by majorgator
semperfly - feel free to ask as many questions as you'd like. I'm not the most experienced, and probably won't have the best "finished looking" boat, but I think I'll be happy with it. I'm glad to help you out however you'd like. I did not pour foam under the sole. Some of the folks on here recommended it, but I'm lazy, cheap, or just didn't care (maybe all 3). It might have been nice for the sound deadening aspect, but according to the rules & regs, vessels 20' and longer are not required to have it. I think the XF20 goes about 20'-3" on the plans. Mine measures 20'-2"...of course, there's a story about mis-measuring that goes along it
seth
Posted: Mon Mar 28, 2011 6:05 pm
by semperfly
yeah the foam is a little pricey no doubt but I saw the diference it made in a Panga I had and am sold on the sound deadning capapbility not to mention the shock absorption that the flat bottoms going to give out in the chop. Either way Im sure your boat will look great, hell it already does! Thanks again for offering to help.
Posted: Fri Apr 01, 2011 12:53 pm
by majorgator
Big day coming tomorrow:
FWC officer to be here at 9 AM to do the inspection.
With painting and rigging being all that's left, I figured its "done enough" and I didn't want this to be the one thing that keeps me off the water.
seth
Posted: Fri Apr 01, 2011 3:25 pm
by Steven
majorgator wrote:Big day coming tomorrow:
seth
I did mine while primed. They had to apply the sticker and I had to paint around it. Big pain.
Posted: Fri Apr 01, 2011 4:31 pm
by cottontop
Steven, I've spent several hours over the last few days reading all of your thread. What a fine job you have done. Your wife and young children are going to love your new ride. I can remember when the FWC came to look at mine. He spent 3 hours checking out my boat. He couldn't believe i built it myself. He took time to read my journal and look at pics. Congrats. John
Posted: Fri Apr 01, 2011 5:54 pm
That's a milestone date for sure
Like Steven said though, in GA the inspecting officer is required to place the hull ID stickers himself and it's a real pain if he does it before you finish painting. I made that mistake on my GF16.
Posted: Fri Apr 01, 2011 7:34 pm
by Steven
Cracker Larry wrote:That's a milestone date for sure
Yup. That was my GV11. Learned. The OB will be painted then inspected.
by Steven
cottontop wrote:Steven, I've spent several hours over the last few days reading all of your thread. What a fine job you have done. Your wife and young children are going to love your new ride. I can remember when the FWC came to look at mine. He spent 3 hours checking out my boat. He couldn't believe i built it myself. He took time to read my journal and look at pics. Congrats. John
Thanks John.
Posted: Sat Apr 02, 2011 10:39 am
by Aripeka Angler
Looking nice Seth!!! I think got it whipped now. If you are like me, I whipped it just before it whipped me
How did the inspection go?
Posted: Sun Apr 03, 2011 7:15 am
by majorgator
Hooray! It took a whopping 10 minutes and a largely uninterested FWC officer, but I got my paperwork and can now go visit the tag office to get my registration
It kind of disappointed me; I was looking forward to telling him all about the build process, but he apparently had better ways to spend my tax dollar. Oh well, I'm thankful that there was no problems. And no sticker in FL, just have to get the HIN engraved on something and apply later.
Aint that the truth. As of last night, the fairing's about 95% complete. If I don't run out of quickfair, then it should be 100% done today.
seth
Posted: Sun Apr 03, 2011 9:44 am
by macs
When the officer came to do mine, he didn't even walk all the way around the whole boat
It sure makes you feel good to have it Id'd
Posted: Mon Apr 04, 2011 5:08 pm
by Uncle D
WTG Seth. Congratulations!!!
Posted: Sun Apr 17, 2011 7:41 am
by majorgator
Got the first coat of primer on yesterday. Sure is a "feel-good" moment. A better man would do some more fairing, but since its pretty dang good anyway, and this project started in January 2009...
I didn't put as much fairing effort into the areas where the KiwiGrip will be applied or where the rubrail goes. These areas aren't rough, but they're not as smooth and pretty as the other areas that just gets a smooth finish.
seth
Posted: Sun Apr 17, 2011 10:03 am
by Aripeka Angler
Man that looks nice!!! I think you are going to make your deadline
Posted: Sun Apr 17, 2011 10:16 am
by cape man
Awesome Seth! Go Baby Go!
Posted: Mon Apr 18, 2011 1:19 pm
by majorgator
3 coats of primer on and looking sweet! Got the last coat on yesterday afternoon. Should have temperatures in the high 80's this week, so I'm planning on starting the paint on Friday to stay on schedule. The recommendation is to wait 7 days, but with I'm taking a gamble, betting that the temps and low humidity will accelerate the cure a bit. Won't be long now...
seth
Posted: Mon Apr 18, 2011 3:30 pm
by wegcagle
NICE
You gettin' there now Seth. She sure does look good
Will
Posted: Fri Apr 22, 2011 3:09 pm
by majorgator
Just a little teaser...
Last night (primer sanding):
After 1 coat of (totally awesome) Sterling paint...hmmm, seamist green, hmmm...
more tomorrow...
seth
Posted: Fri Apr 22, 2011 5:04 pm
by sitandfish
The boat is better looking than I even imagined.
Posted: Fri Apr 22, 2011 5:55 pm
by Aripeka Angler
sitandfish wrote:The boat is better looking than I even imagined.
I have to agree with you, Seth's boat is looking nice! I like this shot too...
Looks like Red will have some company in Boca after all...
Posted: Fri Apr 22, 2011 6:09 pm
by TomW
Wow Seth looking great!
Posted: Fri Apr 22, 2011 7:08 pm
by gstanfield
Congrats on getting some paint on her, that Seamist looks good to me
Posted: Fri Apr 22, 2011 8:15 pm
by tech_support
looking good!
Posted: Fri Apr 22, 2011 8:57 pm
by Steven
Looking good. I like the Seamist. What are you doing on the inside?
Posted: Fri Apr 22, 2011 11:51 pm
by Doc_Dyer
Wonder if Craig will give him any homebrew with such an ugly color on his boat???
Posted: Sat Apr 23, 2011 12:20 am
Yep, I believe she just might make Boca this year yet
Wow, only a few weeks away! Yall done real good today
Posted: Sat Apr 23, 2011 8:31 pm
by cape man
Alright.... She's a beauty and sea mist green is my new favorite color.
Seth you gotta be feeling good. Major step.
Posted: Sat Apr 23, 2011 10:15 pm
by majorgator
Thanks everyone. Painting is done, except for the kiwigrip. I'll get some good pictures on Monday when I can drag it out into the light. Total usage was about 1 quart of the cream and a little more than a pint of the green. I know this is hard to believe, but man, that Sterling is some AMAZING stuff.
Seth
Posted: Mon Apr 25, 2011 12:34 pm
by majorgator
Posted: Mon Apr 25, 2011 1:10 pm
by gstanfield
Looks good Seth, but I think you missed a couple of spots on the topsides
What color kiwi grip did you decide on?
Posted: Tue Apr 26, 2011 12:37 pm
by Uncle D
I really like that shade of green. Excellent job Seth.
Posted: Wed Apr 27, 2011 12:45 pm
by PeteS
Seth, looking good how was the Sterling applied? (Roll and Tip or sprayed on)
Posted: Wed Apr 27, 2011 1:34 pm
by majorgator
Pete -
It was roll and tip, very easy. There are NO brush marks or lines.
seth
Posted: Wed Apr 27, 2011 2:25 pm
by cape man
Posted: Wed Apr 27, 2011 2:26 pm
by Doc_Dyer
yea feels great,
can I hear you say it again please
Posted: Wed Apr 27, 2011 3:51 pm
by majorgator
There ya go Doc! Just in case you forgot
seth
Posted: Thu Apr 28, 2011 10:15 pm
by majorgator
Posted: Thu Apr 28, 2011 10:40 pm
by Aripeka Angler
Looks great
Another big step. I am very happy to see your build coming to completion, can't wait to see her splashed. The paint looks great, fine work Seth...
Posted: Thu Apr 28, 2011 10:50 pm
Mighty fine work! Nice engine too
Posted: Thu Apr 28, 2011 11:04 pm
by SmokyMountain
Looks great Seth!! Can't wait to see her in Boca...
Posted: Fri Apr 29, 2011 10:39 am
by Capt.Adam Valle
Sweet!
Posted: Fri Apr 29, 2011 11:13 am
by Prarie Dog
Seth, looks great. Looks like Sterling for me the next time around. Richard, you might check Red Alert that motor on Seth's boat looks very familiar.
Posted: Fri Apr 29, 2011 11:38 am
by cape man
SWEET!!!!
Posted: Fri Apr 29, 2011 10:18 pm
by Aripeka Angler
Prarie Dog wrote: Richard, you might check Red Alert that motor on Seth's boat looks very familiar.
Can't be mine, it had a prop on it when it disappeared
Posted: Sun May 01, 2011 7:28 am
by majorgator
Posted: Sun May 01, 2011 10:02 am
Today, the T & T decided to begin working again (ask Larry
I'm telling ya, it's my magic wand. That Yammi knew I had the manual out
Posted: Sun May 01, 2011 7:25 pm
by stickystuff
I don't remember what that motor weighed. The owner I built it for bought it. Forgot how purty it was. Of all the XF's built and me being a codesigner, I still haven't been on one fishing. Go figure.
Posted: Mon May 02, 2011 10:48 am
by majorgator
I think me or Richard can rectify that for you this year in Boca
Got a lot of wiring completed yesterday. I need about 2 more good days and she'll be ready for the water
Got a problem with the jack plate, though. It won't work on the switch, but I can operate it up and down with a jumper. Just spoke to a tech at Bob's Machine Shop, and it sounds like my solenoids are bad. Its a used jackplate, so some of the connections on the solenoids were corroded. The connector studs are apparently connected to a soldered wire within the housing (unlike some other solenoids that simply need to make contact). When I was messing around with the solenoids, I turned the studs, which likely broke the wires off internally. I'll go to Bob's tomorrow to get some more, then I should be back in business.
seth
Posted: Mon May 02, 2011 10:55 am
by Aripeka Angler
majorgator wrote:Of all the XF's built and me being a codesigner, I still haven't been on one fishing. Go figure.
seth
The least we could do is take him for a ride. I don't think he has ever been aboard one in the water
Good luck on finishing up your rigging, see you Thursday when you stop for the prop...
Posted: Mon May 02, 2011 11:23 am
by cape man
Before you replace the selenoids check the power/hot line to the switch (there are three wires to the switch, one hot). I had a similar problem (would work from a jump, but not the switch) and found a break in that line.
Posted: Mon May 02, 2011 11:47 am
by majorgator
Thanks Craig. I'll put a meter on the line tonight to see if there's power. I'd say it would be easier to replace the solenoids rather than pull new wire, but I ran a bunch of spares so that fix would take about minutes, most of which would be doing the heat shrink.
No big deal if its just the solenoids. At $15.00 each, that's the probably the cheapest part on there (well, other than the oil cap
seth
Posted: Mon May 09, 2011 10:23 am
by majorgator
Posted: Mon May 09, 2011 10:44 am
by Aripeka Angler
I don't remember if I told you about the extra quart
That is a big deck, it takes what it takes
Can't wait to see the pics
Posted: Mon May 09, 2011 11:04 am
by majorgator
You did tell me about the extra quart. I'm going to need a full gallon though
I used the middle-sized notched spreader because the I was still seeing some of the primer with the smallest notch.
seth
Posted: Fri May 20, 2011 10:59 am
Waiting on a splash report, with pics
Re: Majorgator's XF20 - SPLASHED :)
Posted: Fri May 20, 2011 3:28 pm
by majorgator
Dang, should have put a belt on...
Might be helpful to disconnect this...
No leaks. So far so good.
So how close are my drain holes to the water?
I promise he's just hot, not sunburned
The holes are too close, apparently. "Daddy I'll steer while you plug those holes."
Curiosities/Thoughts/Surprises:
1. The quickest way to add water into this boat is full-throttle reverse with the motor jacked up about 3 inches. That put about 5 - 10 gallons in there in about 3 seconds. Backing up in general sucks.
2. I just couldn't capture a good picture of my wife's joy that the boat is finally (nearly) done.
3. Using a borrowed 12 pitch 4-blade Powertech prop, there was some significant slippage. My tachometer is not connected yet, but at the higher throttle ranges, you could just tell that the prop was having problems grabbing. Minor slipping coming out of the hole, though. Max speed (by GPS) was about 25 MPH. Obviously, this will require more discussion.
4. The livewell pump did just fine. Had to close down the spray nozzle quite a bit because the overflow couldn't keep up. Livewell timer (1 min on, 2 min off) didn't work, but its probably just corrected wrong. That silly TH Marine scoop thingy I bought (suppose to keep water flow constant while boat is running) didn't work worth a flip. Good thing it was cheap and its not screwed into the transom.
5. Draft = 5" - I knew she was built heavy, but I still expected 4". Oh well...
6. Drain holes allow water to rocket into the cockpit. I plugged them temporarily, but it looks like I'll be making some covers for them.
7. Little bit of motor trouble, but that's to be expected for a used motor that's sat on a shelf for over a year. Looks like a little maintenance work is in order
8. The turbulence coming out of the tunnel is pretty rough. I can only imagine that's what was the causing the motor to have a little excessive shaking from time-to-time.
9. Even with the motor full jacked up, there was still plenty of water directed to the motor.
10. While she does slide in a turn, it wasn't as bad as expected. A sharp turn at cruising speed still requires a lot of space, but overall it was very responsive.
11. The transom-mounted transducer makes water shoot straight up. Of course that water comes straight into the boat
Overall, this was a great day. A few kinks to get worked out, a bit deeper draft than expected, but overall I'm pleased with the results.
edit - just looking at some of the pictures again, it appears that the draft may have been closer to 4" right after launch, but in the black water of the river, it definitely changed
Different water densities perhaps
seth
Posted: Fri May 20, 2011 4:17 pm
by gstanfield
Congrats on the splash. Don't worry over the little bugs, there will always be bugs to work out. That's why a plane's first flight isn't full of passengers
Posted: Fri May 20, 2011 4:28 pm
by Larry B
Congrats on the splash, she sure looks good
Thanks for sharing the pictures, they were cool
Posted: Fri May 20, 2011 4:37 pm
by tobolamr
Congratulations! She looks GREAT in the water!
Could a person make a mini spray rail to mount above the transducer to cut that spray?
And in my bass boat, the drains don't keep up with the pump, either. Well, unless I'm filling both live wells at the same time... Amazing how much water that can actually pump, isn't it?
Posted: Fri May 20, 2011 4:58 pm
by stickystuff
Seth. prob. need to pull the carbs down and give them a good cleaning. I can do that if neccessary. i just finished a 40Hp Yammie that has been sitting for a year. Over all looks beautiful. The prop might have to be up one size. Getthe tach. working to find out.Yours is a two stroke ,right? I think richards is a 4 stroke. Two will churn up quicker than a 4 stroke.Minor fixes for the rest. If you need help call me 342-6619
Posted: Fri May 20, 2011 5:12 pm
by steve292
Fine looking boat Seth....& a fine boy too
congratulations,
Steve
Posted: Fri May 20, 2011 5:33 pm
There it is
Looks great
but couldn't you find a river with some water in it
Like they said, minor fixes and fine tuning
See you in two weeks at Boca Grande
Posted: Fri May 20, 2011 7:25 pm
by Hope2float
Great looking boat and a lot of hard work behind you. Good luck with her and the family. I do agree with Larry you need more water!!!
Dave
Posted: Fri May 20, 2011 7:55 pm
by majorgator
Plenty of water...that's just a small creek with a ramp right before the big Suwanee River...more comments later.
Posted: Fri May 20, 2011 8:12 pm
by Brettitt41
Minor problems are to be expected. Looks like a successful splash to me. Great looking boat congratulations.
Posted: Fri May 20, 2011 9:10 pm
by cape man
Awesome. Just awesome! Congrats! All the little stuf can be worked out. You can stand proud!
Posted: Fri May 20, 2011 11:22 pm
by Aripeka Angler
Congratulations on the launch, the details and minor bugs you described should be easy to fix
You will figure 'em out.I sure wish Red's prop would have worked out a little better for you, I have another you can try if you don't want to buy one before the meet...
Posted: Fri May 20, 2011 11:28 pm
by Prarie Dog
Great job Seth, looks really nice, those bugs will be gone in no time. SWMBO and I were talking on the way home tonight how many of the same problems we had. They're mostly gone now. Great looking build, you can take pride in her.
Posted: Sat May 21, 2011 6:44 am
by macs
Awesome job Seth. That's a fine looking boat and crew.
Posted: Sat May 21, 2011 7:25 am
by majorgator
Thanks for the comments everyone. I sure am proud of what's been accomplished over the course of the last 2 years. It was certainly an experience to be cherished and something I look forward to doing again.
There's still a few little rigging things left to do (stern light, rub rail, rod holders), but she's very fishable at this point. Another observation is that she sits down fast when you let off the throttle, presumably because of the 15 gallons of fuel sitting in the front. Also, we had a heavy rain last weekend, and the hatches had very little leakage. I'd say there was about a quart of water in the bilge...and we got close to 3 inches last weekend.
Ken, mine is a 2 stroke and so is Richard's. I should have cleaned the carbs before this trip but I simply ran out of time. I don't plan on doing much boat work today, but I intend on cleaning the carbs. Fortunately, its a Yamaha and the carbs are extremely accessible
You might be right about the prop. I think a little more testing may be in order to get it right
Thanks Steve!
To those of you who commented about the water in the river
, like I said earlier that was just the small creek before the river. I chose to launch there because there's no current, and I figured loading would be easier. The price I paid for that, though, was a shallow ramp = more trailer in the water = less turning room for loading (with boat that doesn't turn) = painful loading experience. I got frustrated with it and just tossed a rope to my dad and let him pull me on.
Might take you up on that offer. Red's prop fit pretty good, and sure does look pretty on there. As I sit back and reflect on it, I shouldn't be so quick to claim prop slippage. With dirty carbs, its likely that the motor was struggling which effected prop speed. Dang, where's TomW/Alabamajo(h)n when you really need him
Yeah, its funny Paul how we might expect that a homemade boat (by an amateur nonetheless) should hit the water and be perfect. I'm just proud of it all, and happy to know that she floats well and doesn't leak. We didn't hit any rough water, but I felt comfort in knowing that she's built well. And to make it better, there's a pile of room on there. There were 3 of us adults and 2 babies, and at no point were we running out of room.
I've been thinking about this. Obviously, if I stick with a transom mounted style, its going to have this problem no matter where its mounted on this boat. I believe I could even come up with something that can utilize the same screw holes the transducer bracket uses.
On a separate but related note, the unit itself worked really well, including the GPS features. You can see the antenna mounted on the grab rail (next to the brown packing paper I haven't completely removed yet). I'm happy I went with the external mounted GPS antenna. And a word of wisdom: a lot of people use an expensive RAM mount for their GPS antenna, and while that works well, the Humminbird units have the same threads as a VHF antenna, so for about $12 I picked up a plastic fixed-position VHF antenna mount at Bass Pro.
seth
Posted: Sat May 21, 2011 7:37 am
by Steven
Congrats Seth. It looks great.
Posted: Sat May 21, 2011 10:43 am
by topwater
Congrats Seth, the boat looks great on the water
Posted: Sat May 21, 2011 10:58 am
by ks8
Great picture of the vigilant flotsam spotter. Enjoy!
Posted: Sat May 21, 2011 11:34 am
by SmokyMountain
Congrats!!! Very nice, can't wait to see it in Boca!!
Posted: Sat May 21, 2011 11:38 am
by wegcagle
Congrats Seth,
That's one beautiful boat you got there.
I know you've got to be one proud man seeing her in the water. Just an FYI it won't be your boat for long. I'm bettin' by next week your boy will start to claim it as his own
Will
Posted: Sat May 21, 2011 4:45 pm
by steve292
Nice feeling ain't it? Mines been built over a year, & I can still sit & look at it for an age
Steve
Posted: Sat May 21, 2011 9:19 pm
by Prarie Dog
Seth, I had the same problem with the transducer making a vertical spray. Grandpa kept moving it up until it quit. He had to drill and fill two sets of holes to get it right. It wound up being mounted about an inch above where the instructions said to put it.
It ain't going as fast as it looks.
Posted: Sun May 22, 2011 8:21 am
by majorgator
I really think the water spray is coming up through the hole shown in this pic, between the transducer and mounting bracket...
That has a pointy end toward the bow that would probably be perfect for digging into the water and directing spray straight up. If I tilted it downward more, then it would probably direct the spray away from the boat. I'm going to experiment with some small thin plastic pieces that I bolt to each other top and bottom of the bracket. That will at least keep the spray from coming though there.
seth
Posted: Sun May 22, 2011 9:11 am
by macs
I had the same problem on my jon boat. I mounted the transducer accoring to the instructions and it kicked up spray badly. I moved it up like Prarie Dog and that solved the problem. When I transfered it over to the Dory we built, I mounted it higher and had no problems.
Posted: Mon May 23, 2011 8:48 am
by PeteS
Seth, quick question concerning your comment about this,
What exactly did you mean by this, can I assume that the water is returning up through all of your drains even as the boat sits (not under power)
Posted: Mon May 23, 2011 10:18 am
by msujmccorm
Beautiful Boat Seth! The first mate looks really comfortable on the boat.
Posted: Mon May 23, 2011 12:44 pm
by majorgator
No, the only time water comes in through the holes is when the boat is underway. The holes are above the waterline while the boat is at rest.
Posted: Mon May 23, 2011 12:47 pm
by Uncle D
A little late seeing the launch pics. Boat looks great and a fine looking first mate. Congrats on both Seth!!!
Posted: Wed May 25, 2011 6:50 pm
by cottontop
Seth, I just got back on this site today. Been a little busy. My what a fine looking boat. I've followed your thread for quite some time. She sure is a beauty. You and your family are going to enjoy many, many fine days on the water. Seeing your son on there reminds me of having my grandson on board on the "Silver River". He was about 13 months old the 1st time. He's 4 now. He loves being on the boat. I live in Sparr and would love to come up and see her some time. John
Posted: Thu May 26, 2011 1:02 pm
by majorgator
Thanks for the continued comments. I really appreciate the kind words from everyone.
John - I work in Gainesville, right off the Williston road exit. I'd be more than happy to give you the dime tour of my XF20. Let me know, and I'll bring her in with me one day
seth
Posted: Thu May 26, 2011 6:59 pm
by cottontop
Thanks Seth. I sent you an email. John
Posted: Fri May 27, 2011 1:45 am
by semperfly
Dude you'e getting 5" draft and complaining? LOL! VERY VERY COOL. Thanks for keeping us all updated and please keep us updated post build on getting the bugs worked out, a good after action report helps us all less mechanically inclined knuckle draggers not make as many mistakes
Posted: Sat Jun 11, 2011 6:47 pm
by majorgator
Just thought I'd post these pics on my thread...
Posted: Sat Jun 11, 2011 9:24 pm
by FOSTER
Looks like you did a great job building that boat if it can handle all that weight. That is impressive.
Posted: Sat Jun 11, 2011 9:44 pm
by Prarie Dog
Great job Seth, beautiful boat and family.
Foster, this pic demonstrates the load carrying capability of an XF20 better than anything I've seen or heard.
Posted: Sat Jun 11, 2011 10:52 pm
by majorgator
And if I remember right, the only structural damage done to the XF20 was to the gunwales
seth
Posted: Sun Jun 12, 2011 9:55 pm
by chopperman
Ouch
That's still painful to look at
Posted: Sat Jul 09, 2011 7:32 am
by majorgator
Interesting to report that, while on the water yesterday, the XF20 had yet again a different draft. However, I'm now believing this is a matter of weight distribution rather than overall weight or buoyancy. Yesterday, it was drafting a true 3" - 4" at rest. This was with a tank of fuel (bow), fish box half full of ice (bow), 54-quart cooler full of ice (mid-ship), EMPTY livewell (stern). In short, it appears that the boat drafts as expected, with the correct weight distribution.
seth
Posted: Sat Jul 09, 2011 10:40 am
by chlli willie
Congratulations your boat came out great,just the fact thats its done is a huge accomplishment.How is the ride? And would you do anything different with the layout ?
Posted: Mon Aug 01, 2011 5:33 pm
by hooter
Any updates on the performance nummbers?
I am interested in this as my next build but am a little suprised at 25 MPH with a 70 2 stroke. According to the building notes, a 25 hp will push this boat 25 mph and 30 HP will push this boat 30 mph. I realizre this is not a linear relationship and would not expect 70 hp but I am curious if a tweaking of the setup or maintenance on the motor has boosted your top end.
Not trying to medle but I am trying to get performance numbers before I saw the wood.
thx. hOOt
Posted: Mon Aug 01, 2011 8:56 pm
That sounds about right with a load in the boat. Actually, I think Seth has an 80 hp 2 stroke, but it's a huge 20' boat. Have you seen one?
My OD18 loaded light (relatively speaking, with a T-top and all her normal stuff) will hit about 33, trimmed up with a tailwind, with the 70 Yamaha 2 stroke. The XF20 is a much larger boat, much wider, a couple of feet longer, a lot more bottom surface and deck area. Heavier. You could land a helicopter on the front deck and play half court basketball on the back deck of the XF20
It's a BIG flats boats.
This is my OD18 tied up beside Richard's XF 20, before Red Alert was red...we both have the same 70 Yamaha, but you can see the difference in boat size.
Posted: Mon Aug 01, 2011 9:19 pm
by hooter
I'm going to admittedly cross post. Sorry but I need answers
No I have not seen one of these.
After the Texas meet I am revisiting this performance idea and am perplexed...
If you look at a Majek Redfish line 20(which anybody who visited the Texas meet will recoginze it as there is one around every corner in Port O'Conner) the dimentions are almost identical to the XF20. 20 feet by 8 foot beam roughly. Tunnel.
The draft is a function of displacement which is determined by shape, weight, balance and volume. Everybody I've read seems to caution about putting too big a motor on the XF20 as it is "way too heavy". How is it that production manufacturers routinly put 150 HP motors on these boats (which weigh much more due the their noncomposite nature) and get speeds of 38-45 mph (and still run super skinny) but the fastest XF 20 I have seen is pushing 28 mph. I'm not a speed freak but am thinking put a little bigger motor and balance weight forward and go faster. why is this wrong?
I guess I am intrigued by DavidTX and his upgrade from a 60-90hp 4 stroke on the sled (and the resultant perma-smile). If you have a boat that is 8 feet wide and 20 feet long, what's another hundred pounds? 1/4" if properly balanced? why is this "way too heavy"? prove me wrong! Would the addition of sponsons adjacent to the motor help balance this increased motor weight by providing greater surface area and therefor bouyance (but thereby increasing weight and decrasing draft in the stern? )
I'm not a nautical engineer but I want everything in a build. Enough HP to "get it" but the skinniest draft possible. Just trying to figure out how the production boats do this but we can't seem to get the speeds they are generating.
all input appreciated.
hOOter
Posted: Mon Aug 01, 2011 9:28 pm
by D2Maine
nm
Posted: Mon Aug 01, 2011 9:53 pm
So that probably means you haven't rode in one either
That big flat hull with that big square bow, in any kind of chop, I mean any chop higher than 6" if you are running directly into it, will rattle the fillings out of your teeth at 28 mph :help. You can't do it. Unless the water is flat smooth that boat won't be comfortable for the passengers at anything over20-25. It is not a speed boat, it is a skinny boat. You can't have both unless the water is very calm. And the lighter the engine, the shallower the boat will float.
David's sled is a twin V, it isn't a powered floating dock like the XF20. The hull design of the TX18 is made for decent speed in a good chop, and still run fairly shallow. The XF20 is made to run very shallow, that is it's program, and it sacrifices all other qualities except load capacity to achieve it.
You can make most boats go faster with more HP, but each design reaches a point where the captain and crew, or the hull design, can't stand it no more.
Posted: Mon Aug 01, 2011 10:20 pm
by gstanfield
The Majek Redfish 21 has an 8" draft, which is about twice the draft of an XF20. It's also a tunnel hull, not a big flat bottom so it sacrifices draft for comfort in a chop
There was a guy on here a while back that put a big 4cyl OMC on an XF20. I think it was a 140hp (or something like that) and the results were scary speed for a flat hull that slides instead of turns
It's all about compromise. Do you want 4" of draft and 30mph or 8" of draft and 45mph?
Posted: Mon Aug 01, 2011 10:36 pm
I meant to mention that quality also. If the water is flat enough that you can run over 30 mph and still keep your teeth in your head, you won't be able to turn the boat inside of a football field
When running flat out you turn the wheel and at first not much happens, then it eventually starts sliding sideways, then it starts skipping sideways, and eventually her @ss end begins to point in the same direction as her front end but it takes a while, then her @ss end might even pass her front end
A lot like an air boat. Not a problem at 30, but at 45 it might be quite a challenge. Collision avoidance could be a problem. No doubt you could push it very fast in flat water, in a straight line, once in a while, but it isn't made for speed, it's made for shallows. XF= Extreme Flats
Posted: Mon Aug 01, 2011 10:47 pm
by gstanfield
I searched and found that it was an older 110hp 2 stroke the guy had.
I also found these:
From "brian in cc"
I agree with Hunch on this one ,my Xf20 with a 50 hp yamaha turning 5500 wide open runs about 27 mph.I recently went up to a 70 horse and I'm getting about 34mph not alot of difference in speed but the larger prop all but eliminated the prop ventilation issues.I would suggest going bigger than a fifty if for no other reason than to get the larger gearbox.
and from "Hutch" (the guy with the 110hp)
The larger gearbox and prop diameter definately helps with the problem of venting that the tunnel creates.
I can run a 13.5 x 17 x 3 blade to around 39 mph at 5200 but the hole shot sux rox and making a turn is a joke with the jack plate up even 3". Switching to a 13.5 x 14 x 4 blade makes for a much better hole shot and reduces venting X 200 % With the way my XF is rigged now and with a 8'x9' Bimini top up I can just about hit 30 at 5200 if I have a tail wind. Ideal crusing with the 1986 dinosaur Evinrude is around 3800-4000 and 20mph.
and Jacques input about Hutch's boat:
Two years ago, I strongly disagree with Hunch's approach but I changed my mind.
While the boat will work with a small engine, 25 to 50 HP, a big engine will strongly reduce cavitation problems through brute force.
He tested props and seems to have found a good combination.
If you use such a big engine, you will have to increase the scantlings.
I would double the glass on the bottom and the transom and pay attention to the transom knees: they must go all the way up
for what it's worth that's what I found
Posted: Tue Aug 02, 2011 6:43 am
by majorgator
As an update, I'm still maxing out at about 25 MPH with a 85 HP 2-stroke. I can go from 0 - 22 MPH in the blink of an eye with very little bowrise. I'm running a 4-blade 12 pitch SST prop. At some point, you have to come to the realization that with a 12 pitch prop, you can only go so fast. Now, that being said, I'm still having a couple of hiccups with the motor. I'm going to be replacing the head gasket soon, because I have a tiny water leak between the upper and middle cylinder. Also, I based upon my inspections of the spark plugs last week when I replaced them, I have a suspicion that my middle cylinder isn't firing like it should. My carbs and all other parts of my fuel system are clean.
I would debate that hooter
I checked out the website, and that boat is a good bit different than the XF20. As George mentions, 8" draft on the Majek and my XF20 with a moderate load in saltwater is a true 4". The Majek is like a hybrid twin-vee-flat-bottom
Don't get me wrong, that's a nice looking boat, but its not the same.
Don't feel alone, I expected a little more speed too, but every time I get a bit discouraged (which isn't often
), I try to think of the point of this boat: SUPER SKINNY draft and for me, family fishing comfort. The past 2 weekends, I've had it on the water with babies, wives, dogs, and all the crap you have to carry to keep those things happy
At no point did we ever feel crowded or uncomfortable, and at no point did we ever get in a hurry. This boat is based off of a popular design in our area that has been fished for decades in some of the most treacherous waters, so speed was not needed as much as a shallow draft and overall toughness. Speaking of toughness, here I am 2 weekends ago pulling my rig over some rocks in the Santa Fe River. Trust me, there was nothing intentional about this...
seth
Posted: Tue Aug 02, 2011 8:38 am
by hooter
I appreciate the discussion! I am still wrestling with what to do next. My wife says I need a project...
We'll figure it out. I'm just stuck between the XF20 and the PH18 with a few mods.
I need a boat for the wife and kids in a couple of years but also something that I can take out and fish the waters I love to fish.
hOOt
Posted: Tue Aug 02, 2011 11:53 am
by SmokyMountain
Hooter,
What would you modify with respect to the PH18? Also, I was really impressed the the TX sled. (Seth don't mean to hijack your thread.)
Andrew
Posted: Tue Aug 02, 2011 2:06 pm
by Uncle D
hOOt, as soon as I can I'll give you a demo ride in a modified PH. Probably be after winter.
Try to help make up your mind.
BTW, Did you leave the meet early, didn't see you at the cook-out. Don
Sorry Seth, didn't mean to hijack.
Posted: Tue Aug 02, 2011 6:42 pm
by hooter
As far as mods to the PH18...see also Uncle D!!! I'm quite intrigued by the build.
This is not the thread to discuss but tunnel/sponsons to support more power!
Yes had to leave early...long story but sometimes you have to burn some logs on the home fire!!
hOOter
Posted: Wed Aug 03, 2011 1:33 pm
by 1HAMMERHEAD
I have an xf 20 with a 2 liter 150 merc...it still floats high enough to see at least an inch of tunnel...will run stupid skinny and does everything I built it for...it is way too fast with this engine but is fun on flat water when there is plenty of room.
Posted: Wed Aug 03, 2011 5:21 pm
Posted: Wed Aug 03, 2011 5:38 pm
by hooter
1HAMMERHEAD wrote:I have an xf 20 with a 2 liter 150 merc...it still floats high enough to see at least an inch of tunnel...will run stupid skinny and does everything I built it for...it is way too fast with this engine but is fun on flat water when there is plenty of room.
You should NOT have told me that!!!!
Posted: Wed Aug 03, 2011 6:43 pm
Well, we know it can handle the weight of the engine
Posted: Thu Aug 04, 2011 8:44 am
by 1HAMMERHEAD
originally I had a 75 hp johnson 2 stroke on there, cleaned it up, and got it running good...motor was old but had great compression, I ran a 19 pitch sst with a ton of cup I beat into it, speed was probably mid 30's to 40...I was never happy with the prop...too much cavitation but only at certain times, the boat creates a ton of suction on slick water...it is very obvious when it breaks the suction and frees up, the cavitation went away as did the steering...I will eventually in the next few months go back to the smaller engine after i get it going again ...I have not vented my tunnel yet but I think its a must especially when ya want flat out straight line speed on flat water, just make sure you have plenty of room to steer.
Posted: Sat Jan 21, 2012 10:35 pm
by Steven
Hey Seth,
How much sterling did you use? I'm trying to decide how much to order. I'm going to do the cream on the inside and either Fleet Blue or Empress Blue on the outside. I really like the Empress Blue, but not sure if it's too hot for our Texas sun.
Thanks,
Steven
Posted: Sun Jan 22, 2012 11:48 am
by majorgator
Steven, I used approx. 1/2 quart of the Seamist Green (hull sides) and almost a full quart of the cream (topsides). However, it should be noted that most of my topsides are KiwiGrip (cream) which 2 almost 2 full gallons. The key, though, with the Sterling is to understand how to correctly use the brushing catalyst and the brushing thinner. Richard helped me through that, otherwise I probably wouldn't have gotten that figured out.
I just checked my garage, and it looks like I have a little less than 1/2 gallon of the catalyst and a little less than 1 quart of the thinner left over, which leads me to believe that for your OB19, you're likely to need 1 gallon and 2 quarts respectively.
Its hard for me to judge the amount of cream you'll need, but you should have no problem if you purchased 1 quart for the sides and transom. I'd safe its safe to say, though, that you'll need more than 1 quart of the cream no matter how you go about it.
FWIW, there's a lot of boats in the hot Florida sun that have a darker color than that on the sides
Posted: Sun Jan 22, 2012 10:43 pm
by Steven
Thanks.
Posted: Mon Mar 12, 2012 9:35 am
by majorgator
Well, here I am preparing for a busy spring and summer fishing/boating season. I was in a rush last year to wrap up the work on my XF20 in time for the builder's meet, and as a result, I was unable to do some of the things I wanted. That's all changed now...
(forgive me, the boat is in need a good washing)
Installation of 2 flush mount rod holders on the aft deck (30 degree). BTW - KiwiGrip is a total pain in the butt to remove...
I never got around to adding the stern light...until now. Its mounted in the center, and it does not conflict with the control cables.
I mounted the trolling motor a few months ago (just to get it out of my garage). Now, I've completed the installation with batteries, wiring, and plug. The batteries are mounted in the front anchor locker, 1 on the port side and 1 on the starboard side. The are standard Wal-Mart Deep Cycles, Group 24. I have a 60 Amp circuit breaker wired in line. The trolling motor is a MotorGuide 82lb thrust 60" shaft.
As previously mentioned, the holes at the back corner of the sole used for drains allow water to "rocket in" while underway. I fixed that with some SST clamshell covers and a little bit of gel-magic.
Having never seen enough rod storage on any boat, I added some under-gunwale rod holders (with some help from gel-magic again)...
Finally, I've had a problem with the heavy gas fumes building up beneath the aft deck. To help alleviate this, I added some vents along the bulkhead.
For this upcoming weekend, I will be installing this bracket for my stake-out stick.
Posted: Mon Mar 12, 2012 10:16 am
by peter-curacao
Very nice,I bet those were all fun "little" projects to do.
Posted: Mon Mar 12, 2012 11:05 am
by Dog Fish
Seth, your extra projects look good.
I know you said (forgive me, the boat is in need a good washing) but you should be penalized for letting that great looking boat get so dirty......shame on you.......
Brian.........
Posted: Mon Mar 12, 2012 4:11 pm
by cottontop
Always something to do. Why did you mount your trolling motor on the rigt side(just curious: I mounted mine there on my OD18 because I liked it. Have noticed most boats on left side.) Sent you and email about a possible visit.
Posted: Mon Mar 12, 2012 6:56 pm
by majorgator
Thanks all!
Why did you mount your trolling motor on the right side
2 reasons:
I cast easier to the left quarter of the boat, so putting it on the right helps keep it out the way for me.
The decket on trolling motor mounts is intended for a V-Hull, left-side mount. Unfortunately, that means it has a funny angle if you put it on the left side of a flat-bowed boat. The angle fits better on the right side (you'll see when you come by).
I understand that trolling motors are typically mounted on all boats. The bow-mounted style were first used on bass boats, where the driver sits low in the boat and on the right side. The motor is installed on the left so its not in the line of sight of the driver. When deployed, though, it doesn't matter what side its on when installed on a V-Hull, as it will come down almost in the middle.
Posted: Tue Mar 13, 2012 8:23 am
by Aripeka Angler
Great to see you getting her finished the way want! I like the plugs on the rod holders, perfect for the location. Looking good, now it's time for some Spring fishing
Posted: Tue Mar 13, 2012 8:48 am
by stickystuff
I believe the reason for mounting trolling motor on Port side is that most trolling motors on bass boats have a tendancy to stick out past the hull.Most boats when you pull along dock side are to starboard and ,thus, the trolling motor hits the dock. Askme how I know. I broke the cover on my PH16 trolling motor when pulled along side the dock in our first bateau Rondezvois in Port StJo. Something to think about.Seth it looks great. I was a little dissapointed that you didn't finish the interior sides up to the gunnel. I .am sorry but it is a shame to see the final finish underneath.
Hope I didn't make you mad.
Posted: Tue Mar 13, 2012 7:44 pm
by majorgator
Posted: Tue Mar 13, 2012 11:37 pm
I believe the reason for mounting trolling motor on Port side is that most trolling motors on bass boats have a tendancy to stick out past the hull. Most boats when you pull along dock side are to starboard and ,thus, the trolling motor hits the dock.
I call BS to that, Capt. Ken. In good humor of course
The "port" side of the boat was the side always put to the port, or the dock. The "starboard" side originated from "steerboard", the steering oar that was on the right side of the ship.
Starboard
The origin of the term starboard comes from early boating practices. Before ships had rudders on their centrelines, they were steered by use of a specialised steering oar. This oar was held by an oarsman located in the stern (back) of the ship. However, like most of society, there were many more right-handed sailors than left-handed sailors. This meant that the steering oar (which had been broadened to provide better control) used to be affixed to the right side of the ship. The word starboard comes from Old English steorbord, literally meaning the side on which the ship is steered, descendant from the Old Norse words stýri meaning "rudder" (from the verb stýra, literally "being at the helm", "having a hand in") and borð meaning etymologically "board", then the "side of a ship"
Port
An early version of "port" is larboard, which itself derives from Middle-English ladebord via corruption in the 16th century by association with starboard. The term larboard, when shouted in the wind, was presumably too easy to confuse with starboard[1] and so the word port came to replace it. Port is derived from the practice of sailors mooring ships on the left side at ports in order to prevent the steering oar from being crushed.
Larboard continued to be used well into the 1850s by whalers, despite being long superseded by "port" in the merchant vessel service at the time. "Port" was not officially adopted by the Royal Navy until 1844 (Ray Parkin, H. M. Bark Endeavour). Robert FitzRoy, Captain of Darwin's HMS Beagle, is said to have taught his crew to use the term port instead of larboard, thus propelling the use of the word into the Naval Services vocabulary.
Hence, it don't really matter which side you put it on, because those folks didn't have trolling motors and Yamaha outboards anyway. I always approach a dock either against the wind, or against the current, whichever is stronger, so it's just as likely to be either side to the dock, whatever works best for the conditions. No need to smash your trolling motor into it, whichever side it's on.
Posted: Wed Mar 14, 2012 5:46 am
by stickystuff
Just a thought on my part. After I thought about it it could happen on either side.. Hey, No bodys perfect. i am far from it. Good info Larry.
Posted: Wed Mar 14, 2012 5:54 am
by stickystuff
If I remember right Stan Sloan was one of the first to mount trolling motors on the bow. This goes way back when bass boats really got popular. One of his quotes if I rember right was why push a chain when you can pull it. thus the first trolling motor was bow mounted. Stan Sloan was one of the first to to start marketing lures for bass fishing commercially. I know lots of lures were made by others in the past before BASS was really getting started. He just happened to be one of those that capitalized in the business. The rest is history.
Posted: Sat Mar 31, 2012 9:56 am
by majorgator
Posted: Sun Apr 01, 2012 8:03 pm
by cottontop
We enjoyed the visit to your worksite to check your boat out a couple of weeks ago. Shella and I really love your boat. You've done a very fine job. John
