Majorgator's XF20 - SPLASHED :)
- stickystuff
Re: Majorgator's XF20
Knowing where you will be fishing I would hit it with some 220 or 350 then roll on a couple of coats of epoxy/graphite powder mix. I live in the same area of you and know the oyster bars are tough on hull bottoms. The epoxy will seek its own level and leave you a shiny black finish. don't worry about the UV protection because its on the bottom.
Capt. Ken Owens
Ken - Do you have a good source for the graphite? I did a quick glance at the online store here, but didn't see any. Does the graphite make it stronger/more durable? Thanks!
Seth
Seth
http://boatbuildercentral.com/products.php?cat=13majorgator wrote:Ken - Do you have a good source for the graphite? I did a quick glance at the online store here, but didn't see any. Does the graphite make it stronger/more durable? Thanks!
Seth
Completed: FL14, OD18
ahhh Thank you kindly Larry!
Ken, how much should I purchase to get a good even coat along that big bottom? About how much extra epoxy do you think I'll use?
seth
seth
I have not put the wooden battens on for the rub-rail yet. Though its called out on the plans, and I've heard that its considered "structural" is it really necessary if I plan on building walk-around gunwales, full decks, and a rubber rub-rail?
seth
seth
Yes mg the rubrails are structural on these boats. They can however with approval from the designer be replaced with an inwale of the same size. But that means cutting a notch out of each frame for the inwale so you can get the 3/4" x 1 1/2" or what ever size designated into the notch. 2nd just bring all your side decks out over the wood rubrails.
C17ccx, Mirror Dinghy
- gk108
I wouldn't eliminate the rubrails, even with walk around gunwales. Tom's suggestion of moving that structure inboard and building it as a sheer clamp is about the best way keep the clean look on the hull sides and still provide strength. Think of worst case like hitting a dock piling midway between frames. Without a rail or sheer clamp, that force is localized and the deck/hull corner will tend to take the shape of the piling. Hit it hard enough and it will keep the shape of the piling. With a laminated frame behind that corner, forces are distributed to the frames and adjacent structure much more evenly. In other words, it is a vital element to monocoque construction.
CC, D15, V10
Thanks Tom. That's the info I needed. I'll go ahead and proceed with the wooden rub-rail. I wasn't suggesting that I didn't want to do it, but just wanted to make sure it was necessary. By doing the rub-rail now it will allow me to finish off the sides and paint it before I flip it. I assume that the rub-rail is just epoxy-glued to the side panels?
Now, if I could only figure out how much epoxy and graphite I need for the bottom.
Seth
Seth
Thanks to you too, GK. You were responding at the same time I was. Great information.
Seth
Seth
Seth the 8oz they sell in the store should be enough graphite, mix it 2parts resin, 1part hardener, 1part graphite, for a 25% blend. Sift the graphite to get rid of any clumping. As far as epoxy you want 2-3 coats. How much did you use wetting out the cloth and go from there it won't take that near that much of course. I don't know if anyone has ever figured it out by sq ft per gallon. Maybe you can be the first and have the answer for the next guy that asks.
Users browsing this forum: Google [Bot] and 18 guests
