The butt block gap is noted on the plans, I was just off. That old measure twice cut once and then once againquadradomus wrote:Wow!! I need to get busy! You boat looks really good John. I appreciate the photos and details. If there is anything so far that looking back you would say to "Watch out for" please sent me a PM. It looks like you did leave a little gap between the butt blocks on the side panels... and the bottom edge of the side panels. I read from another builder to leave 5/8" to account for the hull butt blocks.
I think I would hold off on cutting the seat tops until the frames are set in place. As I think I mentioned, I was a bit off and the gaps along the sides are bigger than I think they need to be. If I end up finishing the interior bright, I may make some small decorative detail pieces to glue and cover the gap/glue lines.
The other thing would be to follow the advice of others and plan/layout all the work you'll be doing with using epoxy and glue:
- making sure its properly measured and fully mixed;
- coating edges of the side panels, transom and bottom well ahead to stitching to make sure the wood is properly coated;
- having other future steps and glue pieces thought out and ready.
For example, I coated the side panel areas where the bow and transom seat cleats will go & the cleats themselves well in advance. Its fully cured now. I'll hit those lightly with sand paper before gluing the cleats. Otherwise trying to tape or clamp them will be harder if fresh epoxy coat is on the side panels.
