FS17 build getting.... SPLASHED!
- chicagoross
Re: FS17 build getting underway
I've used MarinEpoxy fromo this site for the past few builds, but used AeroMarine for the presious two. 5 and 6 years later no problem with the epoxy, and the guy there is really helpful. It does blush, though so be aware - you may have some extra scrubbing and sanding.
My previous experience with epoxy was with generic stuff from US Composites. I got used to working with it (used about 7 gallons) and then bought a quart or two of MAS to finish up a few tasks at the end of the project. I couldn't tell any difference except for the price, and perhaps that the generic stuff was more clear when first mixed. Read a bit about "amine blush," supposedly that is the difference with the $$ stuff.capnmike wrote:[ I've never used any type of epoxy before but according to the specs it's as strong or stronger than anything out today.
For all those concerned about the dog, I promise I won't allow her to eat anything she shouldn't. I wish I had video of me carrying those 16' 2x6s across the yard, and her trying to drag one with her mouth. Priceless.
I'm taking it slow, learning how to use my tools again (it's been a while). I lost a bit of time and some particle board to the learning curve with my new circular saw, but I drew out my transom tonight and made my first cuts in the real stuff. It really smells good, i can see why the dog thinks it's food.
Cheers,
Matt
edit: i didn't see the previous post until after i first posted this, but thanks... i'm not really trying to be a cheapskate, just trying to support local businesses and maybe not give UPS any more of my money
"I then saw the sea as something of great mystery--of alien purpose and dark happenings" - Edward O. Wilson
It's the dust in the air that gets the dog, child, even you if you don't wear a respirator when sanding.
Daddy
Daddy
Hey, just to be clear, I don't let my dog or children or anyone else for that matter, in the garage area while sanding is happening. Actually, not until all of the dust is all vacuumed up and damp mopped. I didn't mean to infer that epoxy/fiberglass dust was ok to be around, just assumed we all knew better and didn't think to mention that. Thanks to all for clearing that up.
Hagar
Hagar
Turning epoxy into dust, eventually leaving a boat behind....
- Bowmovement
Hey Matt,
Any progress on this vessel? Interested in following this one.
Matt
Matt
"Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteers be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe."
Yep. I have a Picasa web album up of fuzzy iPhone pictures (not about to get epoxy/dust around my good camera). I built the frame for the strongbacks today, struggled with it as the beams are not entirely straight. I ended up with something I hope will work. Haven't braced the legs yet, wanted to get it upright and put a bit of weight on it before adding final bracing. I'm sure i'm running into all the trials and tribulations of a first time builder, the transom lamination isn't pretty but it's very strong . I'm pretty sore from hitting it for three days straight.Bowmovement wrote:Hey Matt,
Matt
http://picasaweb.google.com/matt.boswell/BoatBuild#
Nice looking strongback.....one thing tho' i'd brace the legs both ways, the hull gets heavy, & you want to be as stable as you can.
Steve
Steve
I plan to brace it, just ran out of time last night. I do want to put some weight on it before I brace it-- make sure it remains level, that sort of thing.steve292 wrote:Nice looking strongback.....one thing tho' i'd brace the legs both ways, the hull gets heavy, & you want to be as stable as you can.
Steve
I've got my jig mostly assembled, new pics are up on the picasa album. Used a water level to level it as well as I could and pulled a taut string across the center line; lined up all my molds to that. Need to shore them up and make sure they are lined up nicely and in a proper plane. It's starting to resemble a boat. I like that.
-M
-M
I only made a little progress today; I re-checked everything and found that I had missed my original alignment between A and B, so everything was a little off. Corrected that, lots of measuring, and threw the transom on there. It took a while, but I have gotten everything as square as I can get it, measuring from the corner of mold B to the corner of the transom (diagonal) gives me about 1/4" (137.375 vs 137.625) difference between sides. Since the plans say that's good enough, I'm gonna roll with it. Should begin stitching tomorrow.
-M
-M
Users browsing this forum: Google [Bot] and 7 guests
