GF12 (side console)
Posted: Thu May 13, 2010 2:53 pm
I bought the hull from SmilinMatt (his GF12 "Floundering Around) and spent around a year puttering around with it - I had written the board about removing a section of the center seat but was advised not to by Jacques - I am not sure he would approve of all the mods I have made but here it is finished.
Once I got the hull home I sanded, re-epoxied and then painted it in a two part Matthews paint and finished it off with two coats of clear coat. Then I mounted a side console to the middle seat and ran PVC pipes to the rear of the boat to carry the electrical and rigging.
Moved the battery forward under the front deck....
Moved the Gas under the center seat to better balance the load....
Installed a bait bucket and rod holder in the center seat....
Cut the cooler into the rear deck and blocked it from below. ...
Built a manual lift for the motor (15 hp) and mounted it to the boat ...
And - here it is complete. It has been a great boat - I have really enjoyed fishing it.
Cheers,
Don
Cheers,
Don
