texasrds wrote: On a slightly different subject - I am planning on using the rigid rubrail/flexible insert sold here at BBC and the question is should I go ahead and do the full laminated rubrail per the plans (1/4" ply in 3 layers) or would that possibly change due to using the commerical rub rail sold here on BBC? One or two layers instead of three or something entirely different to support that system. I know the rubrails are structural so that is why I'm asking.
You need to still use the laminated plywood per the plans, it is structural. The plastic rubrail is not structural, it will not stiffen up the boat, so you need the laminated wood one, and you can add the plastic for protection and looks
