FS17 build in central Texas
- gstanfield
Re: FS17 build in central Texas
Very nice
Current build: FL14 (+10%)
Good to see another hit the water. Nice pic of Mansfield dam. I think it is, anyway looking forward to see that beauty close up at the meet. Don
Wafeg, You now have 2 beautiful builds. Great job. John
very nice, that may be the best gloss I have seen from S3 paint.
I'm looking forward to hearing about which prop you end up with, so i can copy you (I have the same boat/motor). I never did install a tach on mine, its a tiller, so Im just guessing I have it right with a 10.5 x 14 3 blade stainless prop.
EDIT: I see now your is a 50hp, mine is the older version and 40hp.
Wade great boat! Like the color.
Joel have you ever looked into TinyTachs. I think they have been brought up before, but are good where you don't want to run a regular tach. http://tinytach.com/tinytach/gasoline.php#
C17ccx, Mirror Dinghy
That is a beautiful boat, and I really like that color green
Those are great little devices. We used to use them on ultralight planes, and I used one on my 25 Merc. to get the prop pitch right.Joel have you ever looked into TinyTachs.
- gstanfield
They are good for things that have more or less continuous RPM's like boats and airplanes. I tried to use one on a dirt bike once but the bike revved a lot faster than the tach would keep up. They just don't have the ramp rate to match a high performance bike engine that goes from 2,500rpm to about 11,000rpm in a matter of a second and a half or so as they only update a couple of times a second. Otherwise they are great tachs.
I'll chime in with everyone else on saying that is a gorgeous boat you built. I love everything about it
Great job on the boat. I agree about the color. I really like it. That's what I was originally going to paint mine, but I got scared away after everyone said Georgia is too hot for that dark of a color.
AWESOME
Will
AWESOME
Will
Wadeg, that is a super nice looking build, love the color. I think the first prop I had on my boat was the same as yours after jumping through the hoops what we wound up with is a Powertech PTSWC3R10P-TN40. This prop is a semiweedless prop that has an incredible hole shot and will run 29 at 5700rpm. I think your boat is a little lighter than mine so you might need a little more pitch on yours. If you want more speed the have a semi cleaver blade that is supposed to be faster. We have the same motor.
Wade a thought. When you add cup you effectively add pitch. The water pushes on the prop more effectively. You also normally get more rake when you get more cup again making the prop more effiecent. You'll see your rpm's drop at WOT.
When you went down an inch in diameter you effectively went down an inch in pitch. Thus why you had more throttle left with the smaller prop.
If it was me I would probably start with the smaller prop or it's equivalent for cupping and go from there. But you make the call, every boat and motor combination is different.
Good luck and again you have a beautiful boat.
